Would it be possible to expose current readings directly?
It makes sense that non-neutral installations can’t produce valid power/energy readings, as there is no voltage reference. But presumably the current sensor still works
Exposing current readings would allow external energy trackers to make estimates of power/energy given their own voltage data, and would allow for maintenance/error detection by showing when a bulb is busted or malfunctioning (assuming some current path still exists so the switch is online)
I’m most interested in this for non-neutral installs on the VZW31-SN, but I suspect it would be more or less the same on all your energy-sensing devices with or without a neutral
