Might be easier to move to a new house! ![]()
2 posts were split to a new topic: LZW36 Fan/Light Switch PR Submission to OZW
Random question re: two fans. I have one switch that controls two fans with lights. Would it be possible to have one of the fan and lights switches to control both fans? Assuming the power load is ok- would you do it with a master fan module and a secondary fan module that would mirror the master? If I already have switches that use RF currently activating the fans (MinkaAire brand)âŚany possibility of reusing those? or a way to purchase an innovelli fan module solo?
Is the instruction manual link dead for anyone else? Itâs sending me here to nothing:
Edit: was trying to ensure if I needed any child DTHâs or anything to be prepped for install.
@kreene1987 - Try Knowledge Base Redirect â Inovelli
There will be drivers to download for your Hub for sure.
Worked perfectly. Thanks! @Eric_Inovelli might want to update your website link.
Got the âparentâ DTH but didnât know if there were any child handlers. inovelli.com/lzw36/setup/smartthings had the answer (there is!)!
Perfect. Man I am so excitedâŚ
LOL just made it out actually ![]()
Gotcha ![]()
Itâs updated with the correct driver now lol!
Yes, but there are a few limitations and we did not test this through UL â see a few threads up ![]()
My bad â just updated! Thanks @harjms
Got mine just now! Seems like Iâm the first, or at least the first person excited enough to post about it!
Love it â thanks for posting â canât wait to see the after pictures ![]()
Got my just a moment ago⌠they look greatâŚ
I HATE THE USPS, they said the deliver was attempted and no access to Porch, Driveway, or mailbox! THATâS BS! COVID-19 we will see how long mine takes hopefully tomorrow or Monday! Every package for the last month has been late due to the virus.
Switch already mounted and purring along. Love itâŚnow to have some fun with Hubitat.
One minor issue so farâŚwhen turning the light off it fades all the way off, but then turns back on and stays on (super dim though) Assuming itâs a LED power draw issue?
Shoutout for the oneplus @adriang809 . I loved mine!
@Eric_Inovelli and @EricM_Inovelli might agree too.
hey its on par with the switches
ive owned all since the first one came out⌠brand loyalty is something Iâm not on when the customer service nd products are good.
Currently a Smartthings & Google assistant userâŚgoing to switch to hubitat once itâs back in stock, got my switches today and have been setting up.
Anyone have any tricks to have Google Assistant only use either the light or fan via voice control? Seems like every time I try and get it to activate, it will activate both switches
EDIT:
And just like that I figured it out. Renamed the Main device in Google Home to a bogus name, without this Google would turn the âmainâ switch on or off when asking it to turn the fan or light on/off which would turn everything on/off.
Renamed the light to âBedroom Lightâ and renamed the fan to âBedroom Fanâ. Works now!
Same here, parameter 5 for minimum light level is default to lowest setting.
Iâve had this same fixture on a Hampton Bay Zigbee switch and a Sonoff flashed with Tasmota without seeing the dim lightâŚ
edit1: also Iâm not seeing entity updates in HA if toggled from the switch
edit2: canât seem to get dimmer to slide below 3 (same dim as powered off?)
Anyone figure out Breeze Mode yet? I saw it in the OP post and the YouTube video but I canât find any information on how to actually activate!
Has anyone got this working in Home Assistant? It shows up as a singe entity (light) and turning it on or off also turns the fan on/off. Raising/lowering brightness also raises lowers the fan.
Edit: It looks like their own instructions shows it as a single entity⌠Need a work around here.
