One last question I think this brings up, since osram hue ect are zigbee I know they can’t talk to zwave directly. However with a hubitat wouldn’t that act as an interpreter? Allowing the communication to pass and translating it to the correct protocol?
I don’t have a hubitat yet so I could be way way wrong here.
I have a Hubitat HE and love it. Although I can control my Hue lights via a Z-Wave dimmer, the lag between the dimmer and light changing is a bit too long for my liking. I don’t believe this lag has anything to do with the hub. It has more to do with the loop timing… i.e the time it takes the dimmer event to go from the switch to the hub and then to the light. Kind of why I am excited to see these: Z-Wave Smart Bulbs Packaging. I think Z-wave association will fix the delay issue.
I left my computer at work, so apologies in advance if this is short or I miss something!
@Ma2J - ah makes sense on the fan setup. So, theoretically you could definitely use one of our existing switches and use tap sequences to control the fan and lights. The drawback would be that you’d have to remember what tap does what and there also may be a slight delay (Z-Wave to HUB to Zigbee).
With the new fan/light switch, the main buttons will have scene control on them so you could setup the switch to have the fan button do the following:
Tap 1x = Turns fan to last level
Tap 2x = Turns fan to 25%
Tap 3x = Turns fan to 50%
Tap 4x = Turns fan to 75%
Tap 5x = Turns fan to 100%
However, there would be some drawbacks such as the LED bar wouldn’t reflect the proper fan or light level and you wouldn’t be able to use the dim buttons on the side to smoothly transition the lights.
But you’d have 4 speeds
Yeah Hubitat, ST, etc speak multiple languages and can interpret some things, however some things just do not translate properly. One of those things is the Dimming in real-time command. I can check with our CTO on the more technical answer, but that’s my understanding.
What support is there for the fan switches in regards to developing plugins for home automation systems. I currently am using Domoticz and find it a rather easy system - the software supports z-wave but I assume all things z-wave are not the same. Any insight would be helpful.
Hey great question @moengiant! I’m not super familiar with Domoticz, but I’ve got this question out to our CTO for a more thorough answer.
So, the great thing about Z-Wave is that it’s a very standardized protocol and all devices have to go through a rigorous certification process to ensure forward and backward compatibility. In addition, Z-Wave is brand agnostic in that all brands should work with each other (this is different than ZigBee and WiFi in that they were not standardized until recently).
The issue lies in the HUB/Gateway that controls the various devices. Some companies choose to block certain manufacturers due to strategic partnerships. While others simply are not advanced enough to support all the various Z-Wave commands.
This is why you see asterisks by a lot of our products – there’s a lot of advanced firmware inside these devices and not all HUB’s have caught up to the advancement in firmware. As noted above, the devices will be forward and backward compatible, and this is true for all the basic functionality (ie: On/Off/Dim, etc) but advanced functionality may vary.
I believe Domoticz, from what I’ve heard, is pretty good at keeping up with the latest and greatest Z-Wave has to offer, but again, I’ll double check.
I’ll check around the plug-in scenario for Domoticz, but for other HUB’s, yes, you can definitely write plug-ins and Eric (CTO) has written many different ones for SmartThings, Hubitat, etc.
I did not see any option to not have a controller in the fan/light housing. we installed one of our fan/lights using the existing dual slider switch the other three we used the Inovelli dimmers for the lights and the hunter remote for the fan. I guess it would not be a big deal to rewire the Family room fan/light but a lot of fan/light combos are wired with dumb slider switches.
Read through all the comments, but unsure if this was covered indirectly.
Currently have a Maestro Fan/Light Control MA-LFQ35M with an Accessory Switch MA-ALFQ35. There was originally a basic 3-way switch set up, on main floor and one upstairs, to control all power. The Maestro allows either switch location to control the canopy and the fan or lights independently.
Would we (I) be able to use 2 of these switches to control the canopy module in the same way?
Hey @EAN2007 – excellent question. Let me follow up with the manufacturer to see how they plan on laying this all out. I know we had the disable relay function in the PRD (Project Request Document) – and for them to be separate, but I never got a definitive answer on if we could do this.
I put a note out to them the other day and the PM said they had to check with the firmware engineer – but I haven’t heard back, so I just sent another message.
@EricM_Inovelli – you may have an idea here on the parent/child device? Or at least what you submitted to them?
@MKITGO2 – this is actually another great question. I would think, in theory, this would be possible as the RF part of the switch can be paired to the module (via push pins) and you should be able to set both to pair to the module.
At the very least, you could associate the switches together so that Switch #2 would be able to send commands directly to Switch #1 and then #1 would send the RF command to the canopy.
Hope that makes sense? I’ll look for a clearer answer from the manufacturer as we start to work on firmware, but I do know my workaround via Association would work.
@Eric_Inovelli - That makes complete sense and would satisfy my needs for sure!! Not sure if you plan to sell a version with just an additional switch or not, but would certainly help in this situation. Thanks for the quick reply.
I just bought my first Inovelli Red on/off switch. I’m (im)patiently waiting for the dimmers to hit amazon. I’ve been searching for a switch just like this. From my understanding, in a new construction scenario, there is no way to just wire the fan and light to the switch and skip the RF. You are currently hoping for that in V2. Is that correct? For the time being, when I build my new house, should I throw in a Lutron MA-ALFQ35, wire it up like normal and then hopefully a V2 will come along that’s compatible?
Thanks a ton for the support @MarkH, that really means a lot. Also, welcome to the forums!
Yes, that’s correct
If it’s new construction, you could just have two separate switches and run a separate line up to the fan. But yeah, if you just want one switch, then unfortunately yes, we’re targeting V2. But that may also be a ways away.
Thanks @Eric_Inovelli. I figured asking about the timeline on V2 when V1 isn’t released yet would be ridiculous. I’m sure there are many more projects in the pipeline that you would like to do before spending the money to redesign the switch.
In the 8/22 update you mentioned that you are planning dual switches in 2020. I would suggest one like the Dewstop FS-325 switch for bathrooms. My wife never wanted to turn the fan on in the bathroom when she showered. I finally convinced her to do it, but now she leaves it on ALL DAY. A switch that can sense the humidity would be awesome! Auto on and off at specific thresholds would be nice, but as long as the switch can report the humidity, then we can automate the fan ourselves. Obviously we could just wire the fan to a switch and put a humidity sensor in the room and accomplish the same thing, but this would be cleaner.
You could do that with a Fan & Light switch as long as they are both z-wave controlled, of course you’d need to provide a humidity sensor and have a home automation hub but it would be much more flexible. You could use something like the Iris v3 motion/humidity/temperature sensor or other options and have the light come on to a set level at night with motion and the fan come on with high humidity. You could also put restrictions in to keep the humidity from turning the fan on at night.
We have a Dewstop FS-325 switch in our downstairs bathroom and there have been a few spring nights where we had the windows open and the sensor decided it was humid enough to constantly run and we’d turn it off and it would just come back on. The humidity wasn’t condensing so it wasn’t an issue otherwise.
It’s all good! The more ideas the better honestly. Heck maybe our friends from NJ and OK are monitoring this and can get some ideas as well - better for the market overall!
That Dewstop is pretty cool looking actually, thanks for sharing!
I feel ya brother lol
Yeah, I agree - and surprisingly, as picky as I am, I actually like the design of the Dewstop!
As soon as I can figure out how to fix the product poll page, I’ll definitely add this to the list. We’re definitely looking at a dual switch (outside the fan switch) in 2020, so I’m loving the inspiration being shared!
@Eric_Inovelli Quick question for you. Will these buttons be used to communicate to the hub via z-wave (I’m thinking Button commands) as well? Or will they just communicate to the fan via the fans RF?
This is actually a great question. I’d like there to be the ability to have it send Z-Wave dim commands so you can control smart bulbs if you’d like, but I need to double check.
I know there will be Scene control via the main rectangle buttons, but the config/favorite buttons I need to double check.
Not sure how others feel but I absolutely wouldn’t mind a 2 gang switch if that’s what it took to up some of these features that are.making the switch too deep. Just throwing it out there.
That’s what I was referring to when I was talking about wiring it to a switch and putting a sensor in the room. That’s obviously pretty simple, but as I said, this would just be cleaner. I would assume most people who are purchasing one of these switches have a hub. Otherwise, the extra expense of the z-wave would be a waste.
That’s exactly why I would want to automate it myself. A simple window sensor to disable the fan from kicking on would be easy enough.
Those dewstop are adjustable. Maybe you just needed to adjust it higher.
