I updated my LZW36 via the modified Hubitat Z-Wave Firmware Updater to 1.36 and enabled the Disable Physical On/Off Delay, it now turns on/off much faster than I was able to get it by just changing the ramp rates to 0 before! Thanks for the update, I think my wife will appreciate it!
I asked our engineer some time ago and they were not able to convert the binary file to hex. Iāll ask again but you might want to check if Homeseer plans on supporting gbl files. I believe they are the standard going forward with Z-Wave 700.
Iām having the same update problem as @jessie.sissom.
This is on the latest Hubitat firmware (2.2.3.119).
In my case, I had the switch added with all of the security options off (i.e., I un-checked the S2 and S0 boxes when adding it).
Sorry, Iām still on 2.2.2.129 because it is working great for me and Ive heard to many issues with not being able to boot after upgrading and my hub is a C-3 so I donāt have any experience with the C-7 hubs yet.
@jvm33@jesse.sissom I donāt think there is a problem with the update file as Iāve used it a couple times in Hubitat. Is it possible that you are not using the Binary version of the z-wave updater. There are two versions floating around now.
I installed the this firmware on my device but cannot see the new parameters. I have excluded and included the device multiple times, but still no luck. I have confirmed that the application version is in fact 1.36. Any ideas? I am using Zwave2Mqtt.
I may be offā¦not a user of open zwaveā¦whenever a new firmware comes out with new features, usually (for Hubitat/SmartThings etcā¦), we have to upgrade the drivers to support the new features. Open Z wave may be different, but here is the link to the latest 36.xml file.
Iām not sure how you import or if you do. It may be automatic.
I have added it to our personal config file location but havenāt had a chance to test it yet. @Myztillx can you test it out and I will submit it to open-zwave as a PR?
I was unable to try the config. I run Zwave2Mqtt through the Home Assistant add-on, which re-downloads the OpenZwave DB by default. Turning this off, I was still not able to get the new config file I moved to the database location to be saved through restarts. I am not yet familiar enough with docker to figure out this problem. Sorryā¦
I did test it out and it seemed to work for me. I added the change to a pull request I submitted a while ago. They are usually pretty quick on merging my requests, but this last one is taking a while.
