I posted immediately after but didnt show up.
Yes I just added as a 2nd controller, get node info from primary controller, get node info for device, basic on/off test, OTA get and load the file. Upon completion I set it to white and it worked, checked IDE and it was updated Classic app confirmed the update on screen. I tried this with my LZW42 last week but I was on the Beta Hub Firmware so wanted to wait for the release before I tested again and noticed this update and it worked.
FYI
ALEXA sets to Red
GOOGLE sets to an off Yellow
webCore sets to Red
EDIT: ST HUB V3 Firmware v31.4
*I have also noticed I have lost dimming control via the app using the dimmer with the associated bulbs after the LZW42 update to 2.30. It is still not working via programmatic only physical interaction with the switch, the switch reacts to both but is only sending multiLevel value, no setLevel via app.
You are talking about the LED correct? This needs to be modified in the device handler to translate whatever color values get sent to the switch when you use the voice command. Since there is no āwhiteā in the Hue Color values we are using is why the colors are coming across different. I am currently re-working the device handlers for the switch / dimmer line so I will fit it in with that release.
Iām confused about the edit part of your comment. Which association groups do you have set on the dimmer to the bulb? Do you mean when you tell the dimmer to adjust to x% it doesnāt forward that to the bulbs?
@EricM_Inovelli I have tried 2 & 4, 3, and 3&4, Association 3 was working with small delay but synced the group nicely in a fan light combo. Yes when I use voice or control level through the app the dimmer isnāt forwarding the level to the bulbs. I have other associations that are operational, just this set up started acting up after updating the bulbs and ST Hub Firmware updates last week. The dimmer is receiving setLevel, reporting BasicReport. It only appears to send SwitchMuliLevel with Off/On to the bulbs.
SETUP: I have 3 LZW42 in a fan/light combo, powered via a dummy switch, always on. The dimmer is Neutral install in the same box with no load.
So far so good here. Upgraded both firmware then did a hard reset via the air gap switch. Also changed the max level back to 99. Iāve had my Hue bulbs on a dim setting for 2.5 hours now, and theyāre still on! Thatās longer than itās been able to go before, so Iām hopeful we finally have a fix!
Well, @EricM_Inovelli, I spoke too soon. Power cut off after a few hours. Repeated the test and the Hue bulbs only stayed on for ~20 min. So, doesnāt appear to be a meaningful improvement.
You need a separate z-wave usb stick that you can add as a secondary controller. Then using the Z-wave controller software you can select from target 1/0 and update the bin file. I use the z-wave.me usb stick with hubitat.
I had a thought that perhaps Iām dealing with a faulty device. So I swapped it out for another, previously unused Red Series Dimmer. It exhibits the same behavior with the power cutting off after some time. Both before and after the firmware update to 1.45. It was from the same 09/19 manufacturing batch as the other one though. @EricM_Inovelli do you think itās worth trying a device from a more recent manufacturing run to see if there is a possible defect? Or are you pretty sure this is something thatās solvable via firmware?
If thatās what the root of this is, any way we could get a firmware release that fixes this thing for Load Only configurations? I donāt use the 3-way configurations on the Inovelli switches/dimmers.
So Iām curiousā¦does the power cut out and then right back onā¦or does it stay off? Iām seeing what sounds like something similar on a Red Series switch (non-dimmer), where it seems to power offā¦and then right back on. Seemed to get better with FW v1.17, but it still happens.
It stays off. The funny thing is that the dimmer doesnāt even realize itās off. In order to get power back, I have to tell the dimmer to turn off first, then tell it to turn back on.
Interesting⦠now that sounds like the exact OPPOSITE of what I experienced with the dimmers on the original FW (v1.35). At certain points, with the fixture onā¦it would stay on and couldnāt be powered off without first telling it to turn on (even though it already was) and THEN back off again. (without smart bulbsā¦Iāve never had any luck combining smart switches/dimmers with smart bulbs).
@EricM_Inovelli ⦠not sure if this is a problem or not, but when I repaired after the FW update ST assigned as a āSecure Dimmerā. I changed to your DTH and so far so good, except I noticed the āRaw Descriptionā information is blank, except type and address. I normally went here to validate the FW installed, but itās blank. (attached)
So I just flashed another dimmer and the Raw Description is coming in fine and it recognized it as a LZW31-SN and applied the correct DTH. Hmmmmā¦so why the inconsistencyā¦
@Jbaskerville, the device didnāt include properly. Can you exclude and try again? It will likely have problems in its current state.
@wsdavis, man, I had high hopes. What are the specs on your bulbs (generation / model number)?
@GrantsAuto Group 2 should forward on / off and Group 3 should forward level changes. Group 4 is used when holding the button down at the physical dimmer. Honestly, I canāt think of anything in the firmware that would have changed this. Did you update the device handler around the same time?
