Firmware v1.45 (Beta) | LZW31-SN | Dimmer - Red Series (Gen 2)
@EricM_Inovelli , yes updated both firmware and DTH for the bulbs around the same time, that day or day before ST sent the first Beta out too,around the 15th or so, v31.3, then v31.4 the next day(current rel.). I reset the bulbs but didn’t want to reload the switch’s automations until I get the new fan/light combo to install(got the ship notification a couple days ago!). I have the latest GitHub versions of the DTH for both and have v1.45 on the dimmer but also experienced it with 1.44.
For the most part everything works with voice as we set “the dining room” to a level as they are included, I just noticed this bug by accident as I requested just the dimmer set to level, but the bulbs stayed at 100% and didn’t respond to dimmer app adjustments either, new or classic. There is nothing in the logs for the dimmer forwarding the level adjustment just the switch rec’d and completed. My network consists of 30 Z Wave devices (only Zwave+), no S2 active, 6 battery operated and quick reaction time. I am still trying to understand some of the topography just not sure what a great systems would look like in PC Controller lol. This seems to be the only associated ones that aren’t responding.
@EricM_Inovelli That solved it. Now I know what a bad inclusion looks like. Thanks!
@EricM_Inovelli On this lighting circuit, I have 6x Hue BR30 Color (LCT011), 3x Hue A19 Color (LCT016), and 4x Hue GU10 Color (LCG001).
@wsdavis Are you sure that you have the local control off and are sending the dimming only through scene/lighting group/hue control? This sounds to me like you are dimming the physical switch, which is a no-no with smart bulbs.
Have to ask the obvious questions first…
Just an observation, I’m noticing a flicker at full brightness but only when parameter 13 is set to 255 (white led bar). If I set it to any other color, I don’t notice a flicker. Perhaps there is some correlation to the led bar settings?
Thanks for trying to help. But I have my house filled with Hue bulbs and a mix of Inovelli switches and dimmers. Just this one circuit is giving me trouble, and it’s the one with the most bulbs. For what it’s worth, if I were dimming with the switch, the bulbs would either be flickering or not on at all.
@EricM_Inovelli this makes even less sense- spent some time today and loaded HA onto a pi (venv running in the background) and integrated with ST and the dimmer sends set level to bulbs(and quick) with HA but still not ST???
Btw rolling through the color wheel with HA and the LZW42 was much more reactive than ST as well without backing out to refresh.
So just to clarify, on Hubitat…
You can update the otz file from hubitat, but you then still need the stick and the windows app to update the .bin file?
Also, is there any advantage to just updating the otz file as opposed to both, or are they like PB&J, not as good without each other?
Thanks,
Charlie-
Hi Charlie,
Yeah, you need to update both and use a separate stick as you indicated due to the .bin file. They are like peanut butter and jelly at this time.
-Travis
I wanted to chime in here and add that I’m still experiencing this issue as well. I updated otz and bin via a zstick on PC as secondary and still have issues with the dimmer controlling two hue bulbs. The most common issue is the power cuts and I need to airgap to get it back. It seems to happen only when the lights are dimmed.
I had other issues prior to this update but have yet to see them on 1.45 but it’s only been a day. The more common one was that the lights would be dimmed then flash and come back on brighter. I believe the power was momentarily dropping to the bulb and it was reverting to full brightness. I would also very occasionally get what I lovingly refer to as “Party Bathroom” with both bulbs flickering quickly and out of sync.
Side, probably unrelated, question: what do the “Activate” button and “Activation” toggle in the Silicon Labs controller software do in the firmware update section?
Thanks for the clarification @Daweeze. I purchased for overnight delivery from Amazon the ZooZ S2 stick and was able to run the Z-Wave Controller software on my MacBook Air via Parallels.
Even though I originally updated the otz file through Hubitat, I decided to run that updater and the .bin file through the stick per the instructions on this page:
It all went cleanly, and both Target 0 and 1 were updated.
The issue seems to be that nothing I do now changes the LED bar color as it is stuck on blue. I air-gapped the switch and tried a few different Inovelli drivers. I am using the one that was updated 6 days ago.
The page I got the bin and otz files from are here:
So I don’t know what more to try in order to get the strip to work as expected.
I also notice when I enable or disable local control from Hubitat, that it doesn’t seem to do so. I end up doing the 8x tap of the config button in order to get it to go.
Is there a specific order to update the two targets or something I may have done incorrectly?
Thanks,
Charlie-
Is there any single place I can go to find a list of changes, from version to version, for each piece of hardware? I apologize if there is and I’ve just missed it, but maybe that means it’s just not easy enough to find.
Why does one or two firmware for LZW31-SN have “Holtek” in the name? Who is Holtek and why would I care? :slight_smile: (But more importantly, a changelog that’s easy to find would be super useful and I could read backwards through that and find it.)
To make it more friendly to newer users, can the directory structure say “Red Series Dimmer” or whatever?
Otherwise, I really like the files being available like this!
I agree, appended change logs and release notes are my preference as well. Especially useful when changing to something several releases later. I also prefer a the breakdown for Categories: Fixes, New Features, and Known Issues.
Just wanted to update progress here. After not having success with the one switch, I thought I would try fresh on a new one.
Followed all the instructions on the update page (tried target 0 first, then target 1), removed, reset and have been incapable of re-adding the switch back into Hubitat. It adds super easy in the controller software though.
I tried every combination of reset, restart, exclude (no effect), include (no effect), and even restarted the Hubitat. No joy.
Thinking that this was a problematic switch I picked a third switch (by switch I mean LZW31-sn), and same result.
I also read that there are instances where the switch requires a second flashing because the first does not always overwrite as expected. I did three and still cannot re-add into Hubitat. And yes, the signal strength is green.
@EricM_Inovelli any ideas?
@wsdavis, @Jbaskerville — I am having similar problems achieving stability when controlling smart bulbs. Are you experiencing trouble with a neutral or non-neutral configuration? What I have discovered is that with a smart bulb load and the dimmer set to 99 per Inovelli instructions it sends the dimmer into a reset loop. Depending on how the “State After Power Restored” parameter is set, the dimmer either would simply dive back into the reset loop, remain off, or some middle state. No matter what I have tried I still cannot achieve success with smart bulbs on a non-neutral circuit.
See this thread for more:
Note: I will be able to test with a neutral-equipped circuit in a few days and will be able to flash both target0 and target1 as soon as my DigiKey delivery arrives and I can perform the complete firmware update (at the moment all I can do firmware update wise is target0 using the Hubitat Firmware Updater App). I’ll keep posting as I test more.
I’m currently running v1.35 firmware from the factory. Any reason I should upgrade if I’m not having flickering light issues?
@turbotiger - If you’re using it for notifications, then I would because the notifications go away after your turn on/off the light. If not, maybe just hold out until you deem necessary. Most of my lights haven’t experienced flicker, so it’s a use case basis I think (to upgrade or not).
@EricM_Inovelli so I experienced the flickering issue (more like strobing) on v1.45 with the style of fixture/light I sent you and Eric. I have an MP4 video of it, but it doesn’t look like I can upload those types of files. The only way I could resolve it was to pull the air gap. This happened from a manual push of the button directly after I loaded the firmware and re-included it into ST.
@rpulivella…thanks for the callout. I am not using smart bulbs with any of my Inovelli switches, however, my fixtures are dimmable white LEDS…so may it has more to do with the LED control than the fact they are smart bulbs. FWIW…my switches have the neutral wired in.
That is strange. Does it appear on the Hubitat Discovery screen after you press the config button 3x? What is the distance of the device from the hub?
@EricM_Inovelli - nothing, nada. Green signal strength and it previously joined (and unjoined when I did the update), with no issues. The third one I tried is even closer to the Hubitat (one less wall to go through). To test, I located a switch even further away and through yet another wall and was able to un/ rejoin it (not firmware updates - still 1.35).
I have not yet re-downloaded the 1.45 firmware to the first switch (a couple posts up from this one), as it re-joined, but the disable local control and non of the LED stuff works on it (color change, etc,).
Open for any suggestions.
