Donāt jump off a bridge. LOL, I probably worded that incompletely.
I understand their meaning individually. But it was comments in this other thread that muddied the water for me.
LZW31-SN Internal Relay Disable - What's the point?
Just so Iām understanding correctly, is it as simple as youād like a way to turn on/off a non-dimmable load without using scene control?.
Yeah, pretty much its that simple. Thatās how it works now with V1.47. The changes to v1.52 will break that.
My long diatribe was explaining that I realize the setting called āsmart bulb modeā probably makes more sense to work like v1.52 so Iām just looking for another way to get the v1.47 behaviour which should probably be called ānon-dimmable loadā or ādimming disabledā or something like that.
One way to do this, which I think would be very simple - without needing to create a new parameter - is to allow the existing parameter #5 āMinimum Levelā to be 99 (allow a range of 1-99 instead of the current restriction of 1-45). This would have a two-fold benefit:
- Some dimmable LEDās need minimum of 50 or more to turn on. (They can often be dimmed lower, but they donāt turn on unless the minimum is over 50)
- Allowing a value of 99 here would effectively disable all dimming but otherwise retain full control both local and remote.
