Firmware v1.57 (Production) | LZW31-SN | Dimmer - Red Series (Gen 2)
This is something unique about LED bulbs that makes the minimum level a little tricky. Every bulb is a little different in this regard, but when the bulbs go from an OFF state to an ON state they have to be dimmed up to a certain (usually higher) level just to turn ON. Then, you can usually dim them down 10-15% and make them dimmer. I’ve had to set the minimum brightness to the higher level so that they don’t get in a state where the hub thinks they are on, but they actually are not.
