I am taking a step back in thinking that I am trying to configure too many moving parts at once. So, all I am trying to do now is to get the switch (using the LZW30-SN driver), to be a scene controller for the 3 Illumin RGB bulbs connected to it using @EricM_Inovelli article here: [HOW-TO] Hubitat: Setting Up "Scenes" in Rule Machine
Steps taken:
- Confirmed with 100% certainty that the bulbs work (on/ off) with local control.
- Created a RuleMachine rule
- Disabled local control to the switch (understood that this is needed so the bulbs have power at all times).
- Nothing happens with the button presses. Well, almost nothing. Holding down button 1-press caused the lights to dim (not as a group, but one at a time and now they won’t turn back on).
So this is where I am. I am about to do a repair on the network again to see if that helps. Once I can get this figured out then I can consider incorporating the motion detector.
Any help is greatly appreciated!
Charlie-
