[HOW-TO] Hubitat: Setting Up "Scenes" in Rule Machine
@arcxk - just for confirmation, you’re using Inovelli’s driver correct?
Yep
Do you have logging on for the switch? We can look at real time logs to see if it’s receiving all 6 buttons pressed, just to see if it’s not missing something.
Yes, I am getting both “Button 6 pushed” and “Button 6 held” events in the logs
Weird…especially if it’s working on the other switches. So 6 button is actually a hold button for 3 secs correct? The fact that the logs are seeing it, points me more into the Rule Machine issue than a switch issue if it’s seeing the logs…
That seems to be the case. I created a new automation for that switch and button 6 pushed event functions normally, guess I’m recreating all the others. Thanks for the help!
edit: update, copying my current rule also presents the same issue in the copied rule. Definitely a rule machine issue.
@arcxk - Somewhat easy fix… At least you ruled it down to a RM issue.
Timeline
Pre-Initial Timeline Milestones
  • Present PRD: Completed.
  • R&D Analysis: Completed.
  • Initial Timeline Released: In Progress.
Timeline (Estimated)
  1. Structure & Hardware Design
    Details: ID/Structure Design, PCB Layout & PCBA Making, Hardware Sample, Structure Tooling.
    Est Completion Date: April 25, 2024
    Status: NOT STARTED.
  2. Software Development
    Est Completion Date: February 15, 2024
    Status: IN PROGRESS.
Pinned Ideas & Shout-Outs
Here are the ideas from the community. We sincerely appreciate them, we love them, and we couldn’t create the products we do without them.
Hardware
Software
Monthly Recap
Every month I’ll provide a recap as well as edit the sections above so we can all keep track.
  • February 2nd, 2024: I’ve presented the PRD (Project Request Document) to the manufacturer and they have finished analyzing it.
  • February 21, 2024: We’ve sent a PO off to the manufacturer and have officially kicked off this project!
  • April 18, 2024: Update posted here:
  • December 10, 2024: Beta testing is underway.
  • January 06, 2025: Project update here: https://community.inovelli.com/t/18249/85214
You should check out Button Controller and/or Button Devices for scene control.
Got it, worked great. Now I just need my 10 pack of dimmers to show up!
I believe button 6 and button 8 are reversed in this description (at least, for LZW30-SN)… Button 6 is released while button 8 is held, cmd.keyattributes is 1 for released and 2 for held. Maybe the issue is with the latest driver though.
@EricM_Inovelli just wanted to confirm that buttons 6 and 8 are switched in your HE driver. Held up should be button 6 pushed for the on/off but it’s currently button 8 pushed (for physical control).
A digital held up is actually button 6 pushed so digital is correct while physical is wrong.
I haven’t checked the dimmer so not sure if it has the same issue.
Cheers
Yes, you are correct. They were listed incorrectly in the post. I have just updated it.
Only issue is in the driver, a digital “up” held is actually button 6… So the physical “up” held and digital “up” held would result in different button events
def holdUp() {
sendEvent(buttonEvent(6, “pushed”))
def holdDown() {
sendEvent(buttonEvent(6, “held”))
@EricM_Inovelli please see the post above
I haven’t been keeping up on those custom methods since they are commented out and not very many use them. Any way you can submit a PR for them?
@shewhorn
Late to the party here, but did you ever figure out what was causing your delay when doing a scene? Im in the same boat you are/were except I am using Home Assistant. See thread: Frustration level 100! Scene commanding 5 red dimmers can take over 20+ seconds to complete - #13 by nappyjim
I’ve tried to rule out everything. The only things I havent ruled out yet are the dimmers themselves, as they are currently the only Z wave light switches I have. But as of Saturday, I will have a couple {gasp} non-inovelli switches that I will be testing the scene on (sorry Inovelli, but I have to rule out the switches) ((I really really REALLY hope its not the switches themselves as I have spent over 1k on 30 switches in the past 2 months))
Hi, is the advice here still current with RM 5.1? I have Red Dimmers, and am using the Inovelli Driver in Hubitat (and have hit Save Preferences a ton of times). In RM, I don’t see the “prefill all” option, and I don’t see “Button Device” in the trigger dropdown. Choosing “Button” in the trigger dropdown seems to work, but I have to specify the button number and the action (Pressed or Held, I ignore doubleTap and Released). Again, I can get scenes to work, but not the way it’s specified in the first post here. What am I doing wrong?
EDIT: updated some of the “Device Button” terminology above, for accuracy
No, Rule 5.0 removed “Button Device” and the functionality has been substantially replaced with a revamped Button Controller app. That’s where I’d recommend starting nowadays, but the flow is still pretty similar.
@budmannxx you could try Button Controller from the app page.
