How To Set Up Config Button on Z2MqTT
I have a Blue Series dimmer. I had just figured out how to set up the Config button in ZHA where you make your automation By Type, and then use Device\Device\(device name) and it’s one of the options on that list.
but then I had to switch to Zigbee2MQTT because some of my other devices were not compatible. And that’s apparently not how you do it here. You get no such options doing it the same way. What do I need to do now? I’m hoping I don’t need to mess with MQTT messages or something. I know pretty much nothing about that, and just got Z2MQTT installed by fudging it.
My blueprint (linked here: [zigbee2mqtt] Blue Series 2-1 missing action sensor in Home-Assistant - #15 by rohan ) is the easiest way to get all of the scene controls working with Zigbee2mqtt.
That’s awesome, thanks!
