I am using hubitat c7 with the Blue Series Dimmer. I notice my device switch attribute doesn’t get updated pretty much ever for all 5 dimmers I’ve tried. I turned on the debugging and it looks like the switch is getting a response but the driver doesn’t update.
Hubitat logs:
dev:20192022-10-26 01:01:52.702 am trace Upstairs Hallway Dimmer: ON_OFF_CLUSTER (clusterId:0006 [name:switch, value:off])
dev:20192022-10-26 01:01:52.700 am debug Upstairs Hallway Dimmer: zigbee.getEvent [name:switch, value:off]
dev:20192022-10-26 01:01:52.697 am debug Upstairs Hallway Dimmer: [raw:catchall: 0104 0006 01 01 0040 00 5F37 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5F37, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:20192022-10-26 01:01:52.694 am debug Upstairs Hallway Dimmer: parse(catchall: 0104 0006 01 01 0040 00 5F37 00 00 0000 0B 01 0000)
dev:20192022-10-26 01:01:52.586 am trace off [he cmd 0x5F37 0x01 6 0 {}, delay 500]
dev:20192022-10-26 01:01:52.582 am info Upstairs Hallway Dimmer: off()
dev:20192022-10-26 01:01:50.884 am trace Upstairs Hallway Dimmer: ON_OFF_CLUSTER (clusterId:0006 [name:switch, value:on])
dev:20192022-10-26 01:01:50.875 am debug Upstairs Hallway Dimmer: zigbee.getEvent [name:switch, value:on]
dev:20192022-10-26 01:01:50.872 am debug Upstairs Hallway Dimmer: [raw:catchall: 0104 0006 01 01 0040 00 5F37 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5F37, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:20192022-10-26 01:01:50.868 am debug Upstairs Hallway Dimmer: parse(catchall: 0104 0006 01 01 0040 00 5F37 00 00 0000 0B 01 0100)
dev:20192022-10-26 01:01:50.753 am trace on [he cmd 0x5F37 0x01 6 1 {}, delay 500]
dev:20192022-10-26 01:01:50.747 am info Upstairs Hallway Dimmer: on()
I did an on() call then an off() call. The light correctly turned on/off, but the switch attribute didn’t change.
Looks like the code is reaching Line 1186 at Hubitat/Drivers/inovelli-dimmer-blue-series-vzm31-sn.src/inovelli-dimmer-blue-series-vzm31-sn.groovy at master · InovelliUSA/Hubitat · GitHub then does nothing since parameter 51 is 0.
The dimmer is configured as a dimmer with 3-way dumb switch. These are the state variables:
driverDate : 2022-08-14
fwDate : 2020805
fwVersion : 2.00
lastCommand : Refresh All
lastCommandTime : 2022-Oct-26 1:11:58 AM
lastEventAttribute : 257
lastEventCluster : PRIVATE_CLUSTER (0xFC31)
lastEventTime : 2022-Oct-26 1:12:21 AM
lastEventValue : 00
lastRan : 1666752573175
manufacturer : Inovelli
model : VZM31-SN
parameter1value : 5
parameter2value : 127
parameter3value : 0
parameter4value : 127
parameter5value : 127
parameter6value : 127
parameter7value : 127
parameter8value : 127
parameter9value : 3
parameter10value : 100
parameter11value : 0
parameter12value : 0
parameter13value : 101
parameter14value : 101
parameter15value : 101
parameter17value : 11
parameter18value : 10
parameter19value : 3600
parameter20value : 10
parameter21value : 1
parameter22value : 1
parameter23level : 100
parameter23value : 0
parameter256value : 0
parameter257value : 0
parameter258value : 0
parameter260value : 1
parameter50value : 0
parameter51value : 0
parameter52value : 0
parameter53value : 0
parameter95custom : 237
parameter95value : 168
parameter96value : 170
parameter97value : 100
parameter98value : 1
powerOnState : Previous
powerSource : Neutral
