I purchased many Inovelli White Dimmer switches. They are all currently wired to dumb bulbs and working as expected except for one. This one turns the light on/off as expected. However, when I press the down paddle, it turns the light off and the LED bar then dims blue > flashes cyan > flashes yellow > returns to dim blue. None of my other switches do that. I pulled the air gap and reinstalled in case it was a problem with that. Although my long-term plan is to use these with Hue and Home Assistant, it’s currently simply setup as a switch to a dumb bulb - as simple as I could make it. What is this trying to tell me?
Inovelli White Dimmer - LED Bar flashes cyan > yellow > stays dim blue when pressing the down paddle
You may need a dimmer bypass, what kind of bulb is it and what is the wattage of the attached load?
What @sky320 said.
Is this a non-neutral? The flashing sequence you described is likely the switch rebooting. In a non-neutral configuration, if the bulb doesn’t leak enough power back to the switch, the switch doesn’t have sufficient power to remain running, so it reboots. If that is what is happening, a bypass should resolve the problem. In extreme cases, sometimes more than one bypass is required.
Alright, I figured this out - posting for anyone who finds this in the future. In the end, my electrician mistakenly swapped the Line and Load wires. Flipping them around solved the problem.
This was a new build so there was a neutral wire, single pole, dumb bulb (although long-term goal was to use a smart light). Turning the light on (pressing the up paddle) worked as expected. Pressing the down paddle turned the light off, and then did the flashing light sequence I previously mentioned. The interesting clue was that when I pulled the air gap, the LED light bar still stayed illuminated, whereas all my other switches, that light turned off.
Thanks for the replies!
