Issue with VZM32-SN
I have the VZM32-SN setup with 2 Inovelli AUX switches. It is set up with the white option (hold paddle up and press 5 times). It was working correctly, but lately it is not. Sometimes when the light is on and I want to turn it off with the either AUX switch nothing happens when I press the switch. I re-program the the VZM32-SN with the up pressed and 5 presses and the AUX switches work again. I’m not sure what is happening causing this switch to stop working? This has happened several times after I have reconfigured the switch. Reconfiguring the VZM32 always brings the AUX switch back to being able to control the lights.
Could a restart of Home Assistant cause the Quirk file to reload and change the settings on the switch?
This topic was automatically closed after 75 days. New replies are no longer allowed.
