LED on light strip is blinking
I have a few mmWave switches that will turn on to 100% as expected but then after about 1 second the top 4 LEDs will stop highlighting and the 3rd (or maybe 2nd) LED starts pulsing or flashing (see video).
Can I get some help troubleshooting this? Where can I go to see what command is being sent to the switch to make it do this.
I’m using Home Assistant and z2m. I’ve used integrations like Adaptive Lighting and Lampie but currently those are disables (as far as I can tell).
That looks to me like the switch firmware is updating…?
I thought so too but its been like this for days/weeks. Also, sometimes it pulses when the lights are off, but not all the time.
Very odd!
I found the source of this behavior. I had set the Auto Off Timer to 900 (15 mins). This blinking is indicating that the switch timer is counting down. When I disable this setting, the blinking stops.
