Hello,
I just got my first (used) Inovell product, a LZW31 dimmer, wired up along with an Inovelli aux switch. I have a neutral bundle and wired it accordingly. Once included via HA / Z-Wave JS UI, I made the basic tweaks to the parameters to fit my situation, and everything seemed to be working including on / off at the aux switch.
Immediately thereafter, I noticed that there were firmware updates available and I updated to 1.57.
Unfortunately, I can no longer turn on the lights at the aux switch (but I can turn them off). In fiddling around, I discovered that if I change parameter 21 to “no neutral”, the aux will allow me to turn on and off again. But I am a bit confused - I am 99% sure that I had it set to “neutral” and it was working correctly, prior to that firmware update.
I did try to exclude, re-include, factory reset, etc. to no avail.
Appreciate any help!
Edit: Seems like the working on / off with “no neutral” setting is not consistent either - I am able to reproduce it occasionally when toggling some settings back and forth, but seems to mostly not be working that way, either.
