LZW36 driver missing child option in LZW30-SN & LZW31-SN
Will the child device option for “LED color” be added to the LZW36, as it is for the LZW30 & LZW31? I know it has the 5 notification options for both the light and the fan, but having the child device option allows for other easier ways to use the LEDs for status indicators.
In another thread there was indication that @EricM_Inovelli planned to add this capability, but I haven’t seen that happen yet - I’m suspect they will get to it once the chance arrives.
Looking at the the change that added it for the LZW31, it appears it wouldn’t be too hard to add, though there is the added complexity of having two LED notification devices to control. If someone is up for giving it a try.
I have been tempted to try, but haven’t had the time.
Yes, for sure. Working on getting several changed done for the driver & device handler this week.
Any updated for the LED Child Devices. Was hoping to change the Fan LED on the basis of High/Medium/Low but need the command / Child to be added.
Additionally really miss the ability to set the timeout for the info logging in this drivers
Have you tried using the Hampton Bay Fan Component as the child driver? I have been using that and can set it based on the regular fan template.
I have the for the Fan I have the Hampton Bay Fan component, but what I am talking about has to do with the ability to create a child device for the LED control… In the Dimmer/Switches the driver has the ability to create additional child devices for LED control… This was not added to the Fan/Light driver…
@EricM_Inovelli, we could really use this feature soon in order to sync the LED to the level of the smart bulbs that are controlled by the switch. There’s a nice little app that keeps them in sync but it needs the children.
Alright, you convinced me. :wink: I’ve added the child devices for the led color and intensity to the lzw36 driver.
See this is why I tell everyone you’re my favorite.
Eric is my favorite too (depends on which Eric is reading this).
My mission was accomplished with a Hubitat Rule. The color transition are not perfect as the Zwave message from local Hub is clearly not as quick as device firmware that controls the LED Bar
FAN LED
@EricM_Inovelli Thanks for the update…
