mmWave zone occupancy not matching coordinates of reported target
I installed a new mmwave switch and trying to set up the zones.
I set stay and hold times to their minimum values so that the light will turn off immediately when I leave the area.
However, I’ll go and sit in the area that I’m expecting to be detected, and it will work… but the reported target will not be in the zone:
(despite it saying stop editing, this is the saved zone configuration, I just wanted to highlight it for the screenhot). ID “1” target is me. The switch is reporting that area 1 is detected, but the target is not in the coordinates of the zone. If I walk away, the light will immediately turn off.
Is there maybe something I’m not understanding?
I am noticing the same issue with my new Blue switch. I replaced a Red mmWave switch with this Blue one because Z-Wave does not support multi-zones, and then I switched ~40 devices from ZHA to Zigbee2Mqtt.
I have not had time to test things well, but it seemed targets matched coordinates better when I was using only two zones and got worse when I added a third zone.
Not sure if it’s the same thing, but I’m finding on one switch that the main occupancy now seems stuck clear while area 1 continues detecting presence.
I had AI collect this evidence:
Evidence:
  • Over 72 hours, the affected switch had 303 occupied Area 1 history
    records, but zero occupied main-occupancy records.
  • Raw Zigbee messages show Area 1 reporting occupied.
  • While someone remained in the detection area, repeated direct reads
    of endpoint 1 / cluster 0x0406 / attribute 0x0000 returned
    occupancy: 0, while Area 1 showed occupied.
I uses Medium sensitivity, Fast trigger, hold 10, stay-life 300, and matching occupancy bindings/reporting configuration. No active interference or stay zones. Target reporting and wired-load control are disabled.
This sounds similar to: VZM32-SN mmWave occupancy gets stuck on (won't clear) despite that zone occupancy continues updating
With the solution being to power-cycle the device using the air-gap switch. Not discussed in that thread is an attempt at factory resetting the mmWave module, which if it works would provide a programatic way to automate the problem away.
Because the 3rd party mmWave module is a self-contained device with its own processor it may be that this issue, as well as one I’ve had with detection areas close to the sensors, are firmware/hardware quirks of the mmWave module. Unfortunately, none of these quirks are described in the manufacturer’s documentation so we are left to puzzle these out on our own.
