Pulling out hair over 3 way no neutral install
If the diagram you posted is accurate, then the diagram posted by @jtronicus was reported to have worked. Post 13.
@Rob79
it worked perfectly once I finished wiring i changed option x12 and x13 on config switch so it was set to no neutral and aux switch and everything works perfectly.
