I would like the ability to tell a Red Series Dimmer where the dimmer percentage on the LED bar should be set. For example, I am using Node Red in HA to program exact dim levels, and want to be able to send an MQTT command to the switch (via zwavejs2mqtt) so the dim level is reflected at the switch.
