I have the switch properly set to dimmer mode and they do dim as expected, however setting the switch to 1% is still too bright. 1% is almost what 50% of th brightness of my old dumb dimmer switch. I want a greater range. How do I get the switch to dimmer lower than 1% or recalibrate what the lowest dim voltage is?
This has been brought up before for the other series in the thread below. Responses to the thread stopped so I don’t know if there was ever a resolution.
A couple things to try. Make sure your minimum level, P9, is set to 1.
Also, try switching to tralling edge.
