I’ve installed a LZW30-SN and paired it successfully. The notifications LEDs work great. I created a couple of rules in Hubitat to do things when I double-tap the Up button. When I test it from within the Hubitat web interface, it triggers fine. When I physically tap the Up button twice, it does nothing.
Is there something I need to do to get Hubitat to recognize the physical buttons? I’ve troubleshot this for a couple of days now without any luck. Any help would be greatly appreciated.
Just so I’m clear… pressing the “Press Up X2” button in the Web UI results in the lastEvent and pushed fields being changed successfully and the script executing. I just can’t get the actual physical buttons on the switch to do the same.
Mine works fine, pressing up twice on the switch activates a push of button 2 which tells my RM rule to turn on a lamp, pushing down twice activates a hold of button 2 which turns off the lamp.
Mine shows the last event as soon as I finish tapping as up up, down down, or up up up when I physically tap the switch 2 x up, 2 x down, or 3 x up in the devices page as you show. It also shows the button pushed or held. Maybe a setting that needs to be changed via the configuration button on the switch?
Also I have no idea what Child on or off do, if it’s talking about the child driver then maybe the child got turned off? Not sure why that would be an option though. Also the driver was updated a week or two ago maybe update yours, if you haven’t. I updated mine today and hadn’t tried the scene control features before the update, just the notification feature.
Here’s a sample rule. Activating the buttons within the Web UI works as expected. Still nothing in the logs that it’s picking up any kind of button presses from the switch though.
It leads me to believe it’s either a driver or a hardware issue. Do you guys have the “Child On” and “Child Off” buttons under your device info? They don’t seem to do anything. Perhaps I’ve stumbled across a bug and they shouldn’t even be there?
I have those buttons as well, never pressed them since I can’t think of what they are for. The way you have this pressing up twice quickly should set the level of you Room A and Room B to a random color and set level to 100 but that may not turn the light on just pre-assign the color and dimming level, if the light were already on you should see the changes otherwise you may want to add a light on as well. However if when you press up twice quickly and the Last Event info in the device page doesn’t update then your rules aren’t likely to work either.
Yeah, I make sure the LIFX lights are on during testing. This rule is configured just for troubleshooting the issue. It works fine when triggered from the Web UI. That means the rule is good. There’s just no changes to the Last Event log when I physically press the buttons. The switch just isn’t passing button tap traffic to Hubitat.
If you guys have gotten it to work, I’m leaning on it being a hardware issue at this point. I’ve got another switch that I’ll try out next week and see if it yields different results.
I saw this in my YouTube notifications today… I haven’t had a chance to watch it yet. Maybe it will help: Link.
Unfortunately, I was cheap and purchased the Black label so I can’t help much with the Inovelli scenes. But to be honest, where this switch will ultimately be installed, I won’t need scenes. I imagine I’ll be looking at this when the dimmers finally arrive
