Saving stay areas on Blue mmWave causes X min and X max to flip values and inverts signs
Trying to update Stay Area on a Blue mmWave switch in Zigbee2MQTT on Home Assistant. Every time I click the “Save” button for the Stay Areas, the X min and X max values flip flop and invert sign (positive/negative), even if I don’t make any changes.
If I have the Visualizer app open on my phone while clicking the “Save” button on my PC, I see the orange stay box jump to a different location. Don’t make any changes, just click the save box again and it goes back to where it should be.
Doesn’t matter what device I edit the zone from, it happens on every device. This issue happens inside the visualizer app as well, but I believe this to be a firmware issue that can be replicated from any method that allows you to edit the zones.
I have approximately 20 mmWave switches, and I can reproduce this issue on any that use the stay areas 1 or 2, haven’t tested with stay areas 3 or 4. I don’t have any interference areas set, and the detection areas don’t seem to be affected by this.
I’m on the latest version of Zigbee2MQTT, and the latest firmware version on the switches.
Unfortunately, this is a known bug:
And probably some other links. So, you’re not alone on this.
It’s supposed to be tracked internally, and being worked on:
So with any luck, there will be a fix at some point.
