Hi!
I just updated my LZW30 to 1.19, and now I’m trying to figure out how to setup parameter 51.
The problem is, I use alarm.com so I can’t do it from the panel. Is there any way to configure that from the config button or the Z-Wave PC Controller program?
Thank you
So, unfortunately you can’t set 51 from the switch as room was limited so we couldn’t put the code locally as well.
As for changing it via PC Controller, I’ll defer to @EricM_Inovelli as I’m not entirely sure how to change parameters on there. I’ve only ever used it to update firmware.
What device are you using Alarm.com on?
Oops, yeah it’s connected to Qolsys IQ2.
But I think I’ll switch everything to Home Assistant. The setting for param 51 is doable from there?
Thx
Ok no worries - I’ll see if @anon14959390 can reach out to his contact at Alarm.com and see if there’s a way to do it as he has Qolsys IQ 2 as well.
Yes, you can do it via Home Assistant for sure!
