the logs in z2m don’t really point to anything helpful
2023-01-09 16:13:34 Checking if update available for 'Downstairs Bathroom Light Switch'
2023-01-09 16:13:36 No update available for 'Downstairs Bathroom Light Switch'
Any thoughts on how to work around this? Is there a method for manual update here?
I’ll be damned. that fixed it. that was nice and easy thankfully. Seems like when I did a pull on the code it updated 1 file…no clue how that got out of sync since i pulled the 1.29.1 tag previously but whatever…if it works it works!
Try this… Set logging to Info. Then go to the device and select the Dev Console tab. Select End Point 1, Cluster=genBasic, Attribute=swBuildId and then click Read. What version does it report?
