Stripped terminal screws Blue 2-in-1 mmWave
I stripped the neutral terminal screw on the side of the VZM31SN. Afterwards, I read this discussion and looked at these instructions for opening up the Blue 2-1. Can I safely use those instructions to access the screws on the VZM31SN? I found some a similar screw to replace the damaged one and started down that path, but became hesitant when I met with some resistance at the point of separating the blue rear shell from the rest of the switch. Any advice? Thanks for your help!
I’ve not done it myself, but it should be the same process. We’ve seen a few reports on the forum from other users who have done it successfully:
Thanks @rohan for the encouragement! That did it for me. I got the blue shell off the back and replaced the stripped screw. It’s now installed and working great.
This topic was automatically closed 14 hours after the last reply. New replies are no longer allowed.
