Cannot get an detection of a button press for the Config button on the Blue Series Fan Switch in Home Assistant. It doesn’t show up in the log, events, or if I listen for it. There is an option for it (single, double, long) as a trigger, but pressing it doesn’t trigger. Any clues??
Did you set the button delay to 500 ms?
What hub are you using?
Home Assistant. It’s a slider that goes from 0 to 9 in whole integer increments which is currently set at 2.
Are you using ZHA or Z2M? I’ve not seen a slider with those increments with Z2M.
