Using Inovelli switches in (southern) Japan
Hey guys,
Japan’s power grid does 100V / 60Hz which is a bit different from the 120V / 60Hz in NA.
Have the switches been tested on a 100V circuit? Would they still likely work fine or would there likely be issues?
The newly-announced mmWave Occupancy Smart Switches are of particular interest.
Cheers
Potentially could work. I don’t think anyone has tested on 100v/50hz power. Probably a better chance of it working on 100V than 230V.
I didn’t check for fitment while I was there but will a normal decora sized switch work in the switch boxes?
Fitment normally isn’t the same but it would be in a fully reno’d home with US outlets in this case.
The south is 60Hz not 50 so that’s likely helpful here.
The only difference would be the voltage.
Hmm this might work honestly. @Eric_Inovelli can you ask the manufacturer the voltage input range?
I’m not too concerned of the 50/60hz as I don’t think there’s any oscillator installed.
Yeah it would be great to know for sure.
We’d be doing all of the switches in one home and then possibly replacing the switches in another home. We’re currently all-in on the LIFX ecosystem but reliability has been an issue so we’re hoping ZigBee is the answer.
Having the occupancy sensor in every room would be perfect for a Japanese home though where it’s standard to have a seperate AC unit in every room.
Very interesting! Let me ask the manufacturer :slight_smile:
Ping me (or respond to this) if I don’t give an update by Tuesday.
Thanks Eric!
Just got the update from them and this is what they said (direct quote):
  • In 100V 60Hz, in the case of Neutral, the switch can be used. In the case of Non-Neutral, the compatibility of AUX will be worse a bit, and adjustment is needed according to the actual test.
  • In 100V 50Hz, at present, the dimming does not work normally, the AUX switch can’t be recognized. This requires additional development to target 50Hz.
  • It is necessary to re-do safety / RF certification for Japan market.
  • The installation method of the switch box also needs to be re-evaluated for Japan market.
We’re just about to close on the property that we’d be doing the installation in but it’ll be probably 12-18 months before the renovation actually starts (to hopefully line up with the new mmWave blue series).
I’ll follow up sometime around then and if there’s anything we can do to help then we’d be happy to.
Are the NA frequencies used for Zwave and ZigBee the same for Japan?
I thought they were different.
Japan: 922.5 MHz, 923.9 MHz, 926.3 MHz
USA: 908.4 MHz, 916 MHz
Assuming you’re not using a US spec’d hub.
Yeah honestly our plan is to just buy everything in North America and have it shipped so less likely for there to be any weirdness but it would be good to know about regional hardware incompatibilitoes ahead of time.
The point I was trying to make is that you can’t just buy these and use them in Japan as they use illegal frequencies not authorized nor licensed for transmitting in that country
It would be the same as buying a European hub and devices and trying to use them in NA.
They would work but would cause interference with whatever is actually authorized to use those European frequencies here in NA and the FCC or IC would eventually trace those unauthorized signals and come knocking on your door.
The 2.4ghz band for zigbee frequencies is global. So there would be no issues with using the blues assuming they can be made to work with the power delivery over there. Zwave is where things can get a bit sticky.
I am curious to know how this ended up. If you have more info could you please inform me here?
I won’t be doing my installation until 2025 so can’t report how it goes until then. I’ll also have neutrals in each so I’m not sure how much of an issue non-neutral is going to be for you.
@Eric_Inovelli There have been a couple new switches announced/released since last year - able to confirm if any of the Blue series (eg. fan, on/off w/ temp, smart button) would have issues at 100V/60?
We’re planning on picking up a combination of all 5 switches (mixing and matching in various rooms) and want to double check that they all behave the same.
Also just a heads up that we haven’t tested the original Blue series dimmer yet and are currently taking the manufacture’s word on that.
Is re-doing the safety / RF cert for Japan going to be a long road you think? We’re just in the design phase of the reno now but will probably want to pull the trigger on these in Q1 or Q2 next year.
I wanted to share some feedback and a suggestion. After trying various smart switches on the market, I’ve turned to using the Panasonic Advance (Link Plus). While it’s not perfect, it’s the best option available for now. Unfortunately, none of the electricians here are willing to install switches that aren’t certified for use in Japan.
I really love the design and features of Inovelli switches and would be thrilled to see them certified for use in Japan. As it stands, there are virtually no smart switches that work properly in the Japanese market. Getting RF certification would make a world of difference for many potential customers like myself.
