Thank you for your script Ted. I went ahead and ported it to pyscript, fixed support for matter.js and extended it to work with other devices. I’ve validated it works with eve power devices in addition to my inovelli switches.
# ruff: noqa: TRY002
def duraitonToTenthsOfSeconds(duration=None) -> int:
if duration is None:
return 0
TenthsOfSeconds = 0
TenthsOfSeconds += int(duration.get('hours', 0))
TenthsOfSeconds *= 60
TenthsOfSeconds += int(duration.get('minutes', 0))
TenthsOfSeconds += int(duration.get('seconds', 0))
TenthsOfSeconds *= 10
return TenthsOfSeconds
@service("pyscript.matter_OnWithTimedOff", supports_response="optional") # noqa: F821
async def OnWithTimedOff(entity_id, OnTime=None, OffWaitTime=None, AcceptOnlyWhenOn=False) -> dict:
"""yaml
name: Matter On With Timed Off
description: |
Turns the device on, then turns it off after On time. If you send the
command again while it is still on, the on timer is extended to whichever
is longer: the time already left, or the new On time.
Off wait is a lockout after it turns off. During that lockout, another
On with timed off command will not turn it back on. A normal turn-on
still works. Sending this command during the lockout only shortens the
remaining wait if the new Off wait is shorter.
fields:
entity_id:
description: Matter light or switch to send the command to.
required: true
selector:
entity:
filter:
integration: matter
domain:
- switch
- light
OnTime:
description: |
How long the device stays on before it turns itself off.
Maximum is 1 hour, 49 minutes, and 13 seconds.
If it is already on, the longer of the remaining time and this value is used.
required: true
selector:
duration:
OffWaitTime:
description: |
After the device turns off, how long to ignore further On with timed off
commands so it cannot be turned back on that way. Maximum is 1 hour,
49 minutes, and 13 seconds. Leave empty for no lockout.
required: false
selector:
duration:
AcceptOnlyWhenOn:
name: Only if already on
description: |
If enabled, the command is ignored when the device is already off.
Use this to extend a timer on a device that is on, without turning
off devices back on. If disabled, the command always turns the device on.
required: true
selector:
boolean:
global hass # noqa: PLW0602
try:
_ = hass
except NameError:
raise Exception("Enable 'Hass is global' in the Pyscript integration options")
try:
import asyncio
import json
import uuid
import aiohttp
from homeassistant.components.matter.helpers import get_node_from_device_entry
from homeassistant.helpers import device_registry, entity_registry
except ImportError:
raise Exception("Enable 'Allow all imports' in the Pyscript integration options")
# Matter Spec mandates time in tenths of a second (e.g., 60s = 600)
OnTime = duraitonToTenthsOfSeconds(OnTime)
if OnTime > 0xFFFE:
raise Exception("OnTime is longer than 1 hour, 49 minutes, and 13 seconds")
OffWaitTime = duraitonToTenthsOfSeconds(OffWaitTime)
if OffWaitTime > 0xFFFE:
raise Exception("OffWaitTime is longer than 1 hour, 49 minutes, and 13 seconds")
OnOffControlBitmap = 0
if isinstance(AcceptOnlyWhenOn, str):
AcceptOnlyWhenOn = AcceptOnlyWhenOn.strip().lower() in {"1", "true", "yes", "on"}
if AcceptOnlyWhenOn:
OnOffControlBitmap |= 1
entity = entity_registry.async_get(hass).async_get(entity_id)
if entity is None:
raise Exception(f"Failed to look up entity for {entity_id}")
device = device_registry.async_get(hass).async_get(entity.device_id)
if device is None:
raise Exception(f"Failed to look up device for {entity.device_id}")
node = get_node_from_device_entry(hass, device)
if node is None:
raise Exception(f"Failed to look up node for {device}")
try:
endpoint_id = int(entity.unique_id.rsplit("-", 4)[1])
except (AttributeError, IndexError, ValueError, TypeError):
raise Exception(f"Failed to parse Matter endpoint from unique_id for {entity_id}")
endpoint = node.endpoints.get(endpoint_id)
if endpoint is None:
raise Exception("Unable to find the Matter endpoint for this entity.")
cluster = endpoint.get_cluster(6)
if cluster is None:
raise Exception("Unable to find the OnOff cluster for this entity. Your device may not support OnWithTimedOff.")
accepted = getattr(cluster, "acceptedCommandList", None)
if accepted and 0x42 not in accepted:
raise Exception("This entity's OnOff cluster does not support OnWithTimedOff.")
payload = {
"message_id": uuid.uuid4().hex,
"command": "device_command",
"args": {
"node_id": node.node_id,
"endpoint_id": endpoint_id,
"cluster_id": 6,
"command_name": "OnWithTimedOff",
"payload": {
"onTime": OnTime,
"offWaitTime": OffWaitTime,
"onOffControl": OnOffControlBitmap,
async with aiohttp.ClientSession() as session: # noqa: SIM117
async with session.ws_connect("ws://core-matter-server:5580/ws") as ws:
try:
async with asyncio.timeout(15):
log.info(f"Sending Payload: {payload}") # noqa: F821
await ws.send_str(json.dumps(payload))
while True:
response = await ws.receive_json()
if response.get("message_id") == payload["message_id"]:
break
except TimeoutError:
raise Exception("Timed out waiting for a Matter server response") from None
if "error_code" in response or "error" in response:
error_text = response.get("details") or response.get("error") or response
log.error(f"Error from Matter Server: {error_text}") # noqa: F821
raise Exception(error_text)
log.info(f"Success! Hardware timer sent. Response: {response}") # noqa: F821
return response
return {}
