VTM31-SN multiway: physical binding works, but syncing the other companion’s level causes jitter
Hi, I have several multiway circuits with Inovelli White VTM31-SN dimmers. One switch controls the load; the other White switches act as companions. All the affected switches I checked are on firmware 1.1.6r3.
Matter bindings work well for physical control. When I dim from one companion, the main switch and the actual light follow it smoothly in real time. The problem is that the other companion doesn’t follow the new level.
I’d like all the companions’ displayed/reported levels to follow the main switch, including when brightness is changed from Home Assistant or Alexa. But when I mirror the main switch’s brightness to the other companion from Home Assistant, the circuit jitters. I tried per-circuit automations, debouncing, suppressing writes during a hold, and reconciling after release; none fixed it. Mirroring only on/off is stable, but companion levels can be stale.
My suspicion is that a companion’s Light Load Control endpoint isn’t a passive status mirror, and writing brightness to it affects the control path. Is that expected on 1.1.6r3?
Is there a supported configuration or binding setup where all the companions’ level indicators follow the main switch without issuing their own level-control commands? In particular, does Endpoint 22’s “Remote Only with Bindings” mode help with this?
If this isn’t supported today, could the firmware provide a separate way for companions to mirror the main switch’s level without controlling the load? That would let the paddles keep working through bindings while keeping all the displayed levels in sync.
Have you tried putting the 3 switches in a light group and controlling that from HA? I just tried that and everything stayed in sync.
I use typically binding for paddle control and groups for HA control in that configuration .
Just need a bit of clarification. Is the idea behind the light group that the commands from HA/Alexa-bound HA “devices” will reach that group endpoint so their load control status indicators all change at the same time? That’s a really interesting idea and might be cleaner than what I’ve been doing with my fan switches and canopy modules as well. That behind said, I’m not totally sure what you meant by this:
You’re saying you use Matter bindings from each switch to the main switch? Or something else? I think I’m about 9/10 of the way there, but if you could help me out with this bit I think I’ll have a potentially workable solution to test. Perhaps this should make its way into official documentation?
Following up: this is now working in my testing. Thanks @andrewk—the combination of bindings for physical control and HA groups for HA/Alexa control did the trick.
For the multi-way dimmers, I bound each switch to every other switch , rather than just binding the companions to the main. Each binding uses source endpoint 2 → target load-control endpoint 1, with On/Off (6) and Level Control (8). For a three-switch circuit, that’s six directed relationships, with both clusters on each. Target ACL permissions also need to allow those commands.
I then created a native HA Light Group containing all the switches’ load-control entities , including the companions. HA controls and Alexa target that group, and I disabled the old on/off and brightness-mirroring automations. Only the group is exposed to Alexa.
This gives each control path a way to reach everyone:
  • Physical paddle use updates that switch locally and commands the other switches through Matter bindings.
  • HA/Alexa commands go to every switch through the HA group.
The important detail was including every controller in the group , not just the actual light outputs. I ran into the same issue with my sunroom canopy modules: a canopy-only group controlled the lights but left the wall dimmer’s level stale. Adding the wall dimmer’s load-control entity fixed that. The same approach worked for the fans: wall fan controller plus both canopy fan outputs in an HA Fan Group. Those retained their existing wall-to-canopy bindings; no reverse bindings were needed.
Physical dimming, switch indicators, and HA/Alexa control now stay in sync in my testing, including switching between controllers, with no observed jitter or snap-back.
One caveat: this distributes commands; it doesn’t continuously mirror state. Controlling an individual member directly can still leave things out of sync, so normal HA/Alexa controls need to target the group.
For reference, this is HA Core 2026.11.0 / Matter Server 9.3.0, with the VTM31-SN dimmers on 1.1.6r3. I didn’t change wiring, firmware, or switch modes. Operation with HA offline remains untested, but I’m confident it’s working just fine now.
