Hey everyone, I’ve got a bunch of blue dimmers installed, first time installing an on/off. Turned it on and it seemed to work great! Then I came back upstairs later and it’s flashing red every few seconds. The switch is wired to a 70CFM ceiling fan with a 1.2A rating. Not sure on the motor HP, but it’s a Nutone 695-R03 if that helps.
I checked Home Assistant and for some reason when I turn the switch on, the current and power reported don’t update. Then a minute later when they do the switch reports exactly 21.81A and goes into this loop of flashing red, back to normal, flashing red.
To be clear, I don’t think this is actually a real ~22A load, because I’m on a 15A circuit and haven’t tripped it yet with this fan on a dumb switch.
Is there a way to reflash the latest OTA on my switch? The switch turns on, runs for a bit and then shuts down blinking red (or LED off entirely). Until this point, active and periodic power reporting do not happen, but at the time of failure I get a bunch of (mostly bogus) info.
At failure time I get 600-ish% RH, -30°F, and 21.81A (always that number). The power number looks accurate at about ~120W (the fan is rated for 1.2A).
Reconfiguring, factory reset and attempting to manually change the divisor of the metering cluster (which reads 15880) all fail to resolve the issue
I think there’s either a component that’s marginal on the switch or FW is really freaking out over these bogus readings but I would reach out to support and get a replacement. Wish I had a better solution that didn’t involve waiting a few weeks but at least they seem to want to make it right!
I’ve talked to support a lot of this and done so much troubleshooting on them and once they start throwing this error there just doesn’t seem to be a way around it. Support has replaced my switch multiple times now. I’m on switch number 3, and every single one of them has started doing this eventually.
At this point, I honestly feel like the model either has serious firmware bugs that need worked out, or they’ve just got defective hardware. I’ve never had issues like this with any of the other inovelli switches or dimmers.
It may well be. I don’t have their firmware or internal specs but my outside opinion is that there’s a current divisor that is wrong somewhere given power looks good but current is off by a factor of 22
