VZM32-SN set default dimming through automation or scene in HA
If anyone else happens across this thread, I believe the answer to the question is in this post:
My takeaway from this is: stuff got broken in the UI, but its a known issue, and will be fixed. You can fix it right now yourself if you want to follow those directions, or sounds like if I just wait a bit, it will fix itself.
