White series dimmer switch - FW 1.1.5 - Home Assistant - dimmer trim level adjustment?
I have 3 white series switches, two of them set up as dimmer switches. Last week, when I updated the FW of them from 1.0.5 to 1.1.5. The lowest dim light setting (1%) for our front vestibule is too bright, even at 1%. When I used to be on FW 1.0.5, I had to adjust the dimmer trim level only by using local configuration taps at the switch itself. I was wondering with the new FW, were additional entities or a way to adjust the dimmer trim levels via Home Assistant somehow instead (which would be easier for me)?
thanks in advance!
Jonathan
AFAIK Nothing has changed as far as that feature is concerned. That feature would be “top of my hit parade” to become a HA controllable feature at some point.
This topic was automatically closed 14 hours after the last reply. New replies are no longer allowed.
