I want to wire two fans to the white series fan switch. I see in the FAQ that in this configuration the low and medium are half their normal speeds. Is there a way to adjust the speed levels up to have the normal low and medium? I see a parameter to set the minimum level. If I set the minimum level to a medium speed, I assume I only have 2 speeds then.
I am pretty sure that the low and medium speeds are dictated by the size of the capacitors in the switch.
See this thread for a discussion of fan speeds:
Does it make a difference if the multiple fans are in series or parallel?
They can only be installed in series parallel.
