Did a quick search for humidity on the forum but nothing came up. Is there a fan switch with humidity sensing capabilities coming out in/around July?
I think in the short-term, it’s just going to be the on/off switches … the white that you linked, as well as the blue.
Is this for a bathroom? If that’s the case you want the on-off.
Right, but is it a purpose built switch that has a humidity sensor built in. Or the white/blue switch with an external sensor to programatically trigger the fan. Because neither is very clear or a forum post tracking progress like there normally is for releases.
The on/off switch design specifies a built-in temperature and humidity sensor. Both are exposed so that they can trigger automations.
