White series on off switch issue
I’m using white series on/off switch for bathroom fans, but found an issue after installation.
Issue: the fan can be turned on but cannot be turn ed off, blue light is always on no matter I click any button . Can only be reset at the electrical panel
It would probably be helpful to post a picture of your wiring. Unless you changed something in the firmware config, that’s the thing I would suspect first.
This is a known issue. It appears to be specific to fan installations. There is a beta software version (1.0.1) that appears to fix the problem.
It has been discussed here:
https://community.inovelli.com/t/white-series-on-off-bug-enhancement-vtm30-sn/20213/51
I believe that there is now beta version 1.0.2, though I have not seen any release notes for it.
Thanks! Do you know how to update the firmware? I got the 1.0.3 json file
Inovelli will need to send you the recipe of how to do a beta update with HA.
It’s pretty easy but I think it really needs to come from them.
