Zigbee failures after 2.14 firmware upgrade
Disconnected load removed device from Hub, still see same thing.
Here is the log from the device starting up. Seems a bunch of red that I don’t understand. Happy to learn though!
dev:3462023-06-15 12:01:07.514 PMwarnKitchen Lights Switch: Disabling Debug logging after timeout
dev:3462023-06-15 12:01:05.490 PMtraceKitchen Lights Switch: MULTISTATE_OUTPUT_CLUSTER (clusterId:0013 data:[8D, 73, 27, 5F, F4, 56, FE, FF, B1, 5C, 6C, 8E])
dev:3462023-06-15 12:01:05.488 PMinfoKitchen Lights Switch: Alexa Heartbeat
dev:3462023-06-15 12:01:05.484 PMdebugKitchen Lights Switch: [raw:catchall: 0000 0013 00 00 0040 00 2773 00 00 0000 00 00 8D73275FF456FEFFB15C6C8E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[8D, 73, 27, 5F, F4, 56, FE, FF, B1, 5C, 6C, 8E]]
dev:3462023-06-15 12:01:05.481 PMdebugKitchen Lights Switch: parse(catchall: 0000 0013 00 00 0040 00 2773 00 00 0000 00 00 8D73275FF456FEFFB15C6C8E)
dev:3462023-06-15 12:00:30.690 PMtraceKitchen Lights Switch: MULTISTATE_OUTPUT_CLUSTER (clusterId:0013 data:[8B, 73, 27, 5F, F4, 56, FE, FF, B1, 5C, 6C, 8E])
dev:3462023-06-15 12:00:30.688 PMinfoKitchen Lights Switch: Alexa Heartbeat
dev:3462023-06-15 12:00:30.685 PMdebugKitchen Lights Switch: [raw:catchall: 0000 0013 00 00 0040 00 2773 00 00 0000 00 00 8B73275FF456FEFFB15C6C8E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[8B, 73, 27, 5F, F4, 56, FE, FF, B1, 5C, 6C, 8E]]
dev:3462023-06-15 12:00:30.683 PMdebugKitchen Lights Switch: parse(catchall: 0000 0013 00 00 0040 00 2773 00 00 0000 00 00 8B73275FF456FEFFB15C6C8E)
dev:3462023-06-15 12:00:06.209 PMinfoKitchen Lights Switch: Report received Switch: 1 (on)
dev:3462023-06-15 12:00:06.207 PMtraceKitchen Lights Switch: ON_OFF_CLUSTER (clusterId:0006 attrId:0000 value:01 [name:switch, value:on])
dev:3462023-06-15 12:00:06.204 PMtraceKitchen Lights Switch: ON_OFF_CLUSTER (clusterId:0006 [name:switch, value:on])
dev:3462023-06-15 12:00:06.101 PMdebugKitchen Lights Switch: zigbee.getEvent [name:switch, value:on]
dev:3462023-06-15 12:00:06.087 PMdebugKitchen Lights Switch: [raw:27730100060800001001, dni:2773, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0]
dev:3462023-06-15 12:00:06.084 PMdebugKitchen Lights Switch: parse(read attr - raw: 27730100060800001001, dni: 2773, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01)
dev:3462023-06-15 12:00:06.084 PMdebugKitchen Lights Switch: zigbee.getEvent [name:switch, value:on]
dev:3462023-06-15 12:00:05.999 PMdebugKitchen Lights Switch: [raw:catchall: 0104 0006 01 01 0040 00 2773 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:3462023-06-15 12:00:05.997 PMdebugKitchen Lights Switch: parse(catchall: 0104 0006 01 01 0040 00 2773 00 00 0000 0B 01 0100)
dev:3462023-06-15 12:00:05.833 PMtraceKitchen Lights Switch: on [he cmd 0x2773 0x01 6 1 {}, delay 333]
dev:3462023-06-15 12:00:05.828 PMinfoKitchen Lights Switch: on()
dev:3462023-06-15 12:00:05.794 PMinfoKitchen Lights Switch: Report received Power: 0.0W
dev:3462023-06-15 12:00:05.792 PMtraceKitchen Lights Switch: ELECTRICAL_MEASUREMENT_CLUSTER (clusterId:0B04 attrId:050B value:0000)
dev:3462023-06-15 12:00:05.787 PMdebugKitchen Lights Switch: [raw:2773010B040A0B05290000, dni:2773, endpoint:01, cluster:0B04, size:0A, attrId:050B, encoding:29, command:0A, value:0000, clusterInt:2820, attrInt:1291]
dev:3462023-06-15 12:00:05.784 PMdebugKitchen Lights Switch: parse(read attr - raw: 2773010B040A0B05290000, dni: 2773, endpoint: 01, cluster: 0B04, size: 0A, attrId: 050B, encoding: 29, command: 0A, value: 0000)
dev:3462023-06-15 12:00:05.074 PMinfoKitchen Lights Switch: Report received Level: 254 (100%)
dev:3462023-06-15 12:00:05.045 PMtraceKitchen Lights Switch: LEVEL_CONTROL_CLUSTER (clusterId:0008 attrId:0000 value:FE [name:level, value:99])
dev:3462023-06-15 12:00:05.049 PMinfoKitchen Lights Switch: Report received Level: 254 (100%)
dev:3462023-06-15 12:00:05.032 PMtraceKitchen Lights Switch: LEVEL_CONTROL_CLUSTER (clusterId:0008 attrId:0000 value:FE [name:level, value:99])
dev:3462023-06-15 12:00:05.027 PMdebugKitchen Lights Switch: zigbee.getEvent [name:level, value:99]
dev:3462023-06-15 12:00:05.007 PMdebugKitchen Lights Switch: [raw:277301000808000020FE, dni:2773, endpoint:01, cluster:0008, size:08, attrId:0000, encoding:20, command:0A, value:FE, clusterInt:8, attrInt:0]
dev:3462023-06-15 12:00:05.014 PMdebugKitchen Lights Switch: zigbee.getEvent [name:level, value:99]
dev:3462023-06-15 12:00:05.011 PMdebugKitchen Lights Switch: [raw:277301000808000020FE, dni:2773, endpoint:01, cluster:0008, size:08, attrId:0000, encoding:20, command:0A, value:FE, clusterInt:8, attrInt:0]
dev:3462023-06-15 12:00:05.008 PMdebugKitchen Lights Switch: parse(read attr - raw: 277301000808000020FE, dni: 2773, endpoint: 01, cluster: 0008, size: 08, attrId: 0000, encoding: 20, command: 0A, value: FE)
dev:3462023-06-15 12:00:05.003 PMdebugKitchen Lights Switch: parse(read attr - raw: 277301000808000020FE, dni: 2773, endpoint: 01, cluster: 0008, size: 08, attrId: 0000, encoding: 20, command: 0A, value: FE)
dev:3462023-06-15 12:00:04.977 PMtraceKitchen Lights Switch: ON_OFF_CLUSTER (clusterId:0006 [name:switch, value:off])
dev:3462023-06-15 12:00:04.974 PMdebugKitchen Lights Switch: zigbee.getEvent [name:switch, value:off]
dev:3462023-06-15 12:00:04.962 PMdebugKitchen Lights Switch: [raw:catchall: 0104 0006 01 01 0040 00 2773 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:3462023-06-15 12:00:04.960 PMdebugKitchen Lights Switch: parse(catchall: 0104 0006 01 01 0040 00 2773 00 00 0000 0B 01 0000)
dev:3462023-06-15 12:00:04.853 PMtraceKitchen Lights Switch: off [he cmd 0x2773 0x01 6 0 {}, delay 333]
dev:3462023-06-15 12:00:04.850 PMinfoKitchen Lights Switch: off()
dev:3462023-06-15 12:00:00.722 PMinfoKitchen Lights Switch: Receive parameter 257 value 0 (Remote Control enabled)
dev:3462023-06-15 12:00:00.621 PMtraceKitchen Lights Switch: Private Cluster ( attrId:0101 value:00)
dev:3462023-06-15 12:00:00.618 PMdebugKitchen Lights Switch: [raw:277301FC310A01011000, dni:2773, endpoint:01, cluster:FC31, size:0A, attrId:0101, encoding:10, command:01, value:00, clusterInt:64561, attrInt:257]
dev:3462023-06-15 12:00:00.616 PMdebugKitchen Lights Switch: parse(read attr - raw: 277301FC310A01011000, dni: 2773, endpoint: 01, cluster: FC31, size: 0A, attrId: 0101, encoding: 10, command: 01, value: 00)
dev:3462023-06-15 12:00:00.287 PMinfoKitchen Lights Switch: Receive parameter 51 value 0 (Bindings)
dev:3462023-06-15 12:00:00.284 PMtraceKitchen Lights Switch: Private Cluster ( attrId:0033 value:00)
dev:3462023-06-15 12:00:00.281 PMdebugKitchen Lights Switch: [raw:277301FC310A33002000, dni:2773, endpoint:01, cluster:FC31, size:0A, attrId:0033, encoding:20, command:01, value:00, clusterInt:64561, attrInt:51]
dev:3462023-06-15 12:00:00.278 PMdebugKitchen Lights Switch: parse(read attr - raw: 277301FC310A33002000, dni: 2773, endpoint: 01, cluster: FC31, size: 0A, attrId: 0033, encoding: 20, command: 01, value: 00)
dev:3462023-06-15 11:59:59.977 AMtraceKitchen Lights Switch: Dimming Method = Trailing Edge
dev:3462023-06-15 11:59:59.960 AMinfoKitchen Lights Switch: Receive parameter 21 value 1 (Neutral)
dev:3462023-06-15 11:59:59.957 AMtraceKitchen Lights Switch: Private Cluster ( attrId:0015 value:01)
dev:3462023-06-15 11:59:59.954 AMdebugKitchen Lights Switch: [raw:277301FC310A15001001, dni:2773, endpoint:01, cluster:FC31, size:0A, attrId:0015, encoding:10, command:01, value:01, clusterInt:64561, attrInt:21]
dev:3462023-06-15 11:59:59.952 AMdebugKitchen Lights Switch: parse(read attr - raw: 277301FC310A15001001, dni: 2773, endpoint: 01, cluster: FC31, size: 0A, attrId: 0015, encoding: 10, command: 01, value: 01)
dev:3462023-06-15 11:59:59.619 AMinfoKitchen Lights Switch: Receive parameter 52 value 0 (SBM disabled)
dev:3462023-06-15 11:59:59.616 AMtraceKitchen Lights Switch: Private Cluster ( attrId:0034 value:00)
dev:3462023-06-15 11:59:59.612 AMdebugKitchen Lights Switch: [raw:277301FC310A34001000, dni:2773, endpoint:01, cluster:FC31, size:0A, attrId:0034, encoding:10, command:01, value:00, clusterInt:64561, attrInt:52]
dev:3462023-06-15 11:59:59.610 AMdebugKitchen Lights Switch: parse(read attr - raw: 277301FC310A34001000, dni: 2773, endpoint: 01, cluster: FC31, size: 0A, attrId: 0034, encoding: 10, command: 01, value: 00)
dev:3462023-06-15 11:59:59.291 AMtraceKitchen Lights Switch: Dimming Method = Trailing Edge
dev:3462023-06-15 11:59:59.285 AMinfoKitchen Lights Switch: Receive parameter 22 value 0 (No Aux)
dev:3462023-06-15 11:59:59.282 AMtraceKitchen Lights Switch: Private Cluster ( attrId:0016 value:00)
dev:3462023-06-15 11:59:59.279 AMdebugKitchen Lights Switch: [raw:277301FC310A16002000, dni:2773, endpoint:01, cluster:FC31, size:0A, attrId:0016, encoding:20, command:01, value:00, clusterInt:64561, attrInt:22]
dev:3462023-06-15 11:59:59.277 AMdebugKitchen Lights Switch: parse(read attr - raw: 277301FC310A16002000, dni: 2773, endpoint: 01, cluster: FC31, size: 0A, attrId: 0016, encoding: 20, command: 01, value: 00)
dev:3462023-06-15 11:59:58.957 AMtraceKitchen Lights Switch: Dimming Method = Trailing Edge
dev:3462023-06-15 11:59:58.951 AMinfoKitchen Lights Switch: Receive parameter 258 value 1 (On/Off mode)
dev:3462023-06-15 11:59:58.948 AMtraceKitchen Lights Switch: Private Cluster ( attrId:0102 value:01)
dev:3462023-06-15 11:59:58.945 AMdebugKitchen Lights Switch: [raw:277301FC310A02011001, dni:2773, endpoint:01, cluster:FC31, size:0A, attrId:0102, encoding:10, command:01, value:01, clusterInt:64561, attrInt:258]
dev:3462023-06-15 11:59:58.942 AMdebugKitchen Lights Switch: parse(read attr - raw: 277301FC310A02011001, dni: 2773, endpoint: 01, cluster: FC31, size: 0A, attrId: 0102, encoding: 10, command: 01, value: 01)
dev:3462023-06-15 11:59:58.615 AMinfoKitchen Lights Switch: Report received Power-On Level: 255 (Previous)
dev:3462023-06-15 11:59:58.614 AMtraceKitchen Lights Switch: LEVEL_CONTROL_CLUSTER (clusterId:0008 attrId:4000 value:FF [name:level, value:100])
dev:3462023-06-15 11:59:58.610 AMdebugKitchen Lights Switch: zigbee.getEvent [name:level, value:100]
dev:3462023-06-15 11:59:58.607 AMdebugKitchen Lights Switch: [raw:27730100080A004020FF, dni:2773, endpoint:01, cluster:0008, size:0A, attrId:4000, encoding:20, command:01, value:FF, clusterInt:8, attrInt:16384]
dev:3462023-06-15 11:59:58.605 AMdebugKitchen Lights Switch: parse(read attr - raw: 27730100080A004020FF, dni: 2773, endpoint: 01, cluster: 0008, size: 0A, attrId: 4000, encoding: 20, command: 01, value: FF)
dev:3462023-06-15 11:59:58.282 AMinfoKitchen Lights Switch: Report received Remote-On Level: 255 (Previous)
dev:3462023-06-15 11:59:58.280 AMtraceKitchen Lights Switch: LEVEL_CONTROL_CLUSTER (clusterId:0008 attrId:0011 value:FF [name:level, value:100])
dev:3462023-06-15 11:59:58.277 AMdebugKitchen Lights Switch: zigbee.getEvent [name:level, value:100]
dev:3462023-06-15 11:59:58.274 AMdebugKitchen Lights Switch: [raw:27730100080A110020FF, dni:2773, endpoint:01, cluster:0008, size:0A, attrId:0011, encoding:20, command:01, value:FF, clusterInt:8, attrInt:17]
dev:3462023-06-15 11:59:58.271 AMdebugKitchen Lights Switch: parse(read attr - raw: 27730100080A110020FF, dni: 2773, endpoint: 01, cluster: 0008, size: 0A, attrId: 0011, encoding: 20, command: 01, value: FF)
dev:3462023-06-15 11:59:57.947 AMinfoKitchen Lights Switch: Report received On/Off Transition: 3s
dev:3462023-06-15 11:59:57.946 AMtraceKitchen Lights Switch: LEVEL_CONTROL_CLUSTER (clusterId:0008 attrId:0010 value:001E [name:level, value:12])
dev:3462023-06-15 11:59:57.942 AMdebugKitchen Lights Switch: zigbee.getEvent [name:level, value:12]
dev:3462023-06-15 11:59:57.939 AMdebugKitchen Lights Switch: [raw:27730100080C1000211E00, dni:2773, endpoint:01, cluster:0008, size:0C, attrId:0010, encoding:21, command:01, value:001E, clusterInt:8, attrInt:16]
dev:3462023-06-15 11:59:57.937 AMdebugKitchen Lights Switch: parse(read attr - raw: 27730100080C1000211E00, dni: 2773, endpoint: 01, cluster: 0008, size: 0C, attrId: 0010, encoding: 21, command: 01, value: 1E00)
dev:3462023-06-15 11:59:57.621 AMinfoKitchen Lights Switch: Report received Level: 254 (100%)
dev:3462023-06-15 11:59:57.619 AMtraceKitchen Lights Switch: LEVEL_CONTROL_CLUSTER (clusterId:0008 attrId:0000 value:FE [name:level, value:99])
dev:3462023-06-15 11:59:57.615 AMdebugKitchen Lights Switch: zigbee.getEvent [name:level, value:99]
dev:3462023-06-15 11:59:57.612 AMdebugKitchen Lights Switch: [raw:27730100080A000020FE, dni:2773, endpoint:01, cluster:0008, size:0A, attrId:0000, encoding:20, command:01, value:FE, clusterInt:8, attrInt:0]
dev:3462023-06-15 11:59:57.610 AMdebugKitchen Lights Switch: parse(read attr - raw: 27730100080A000020FE, dni: 2773, endpoint: 01, cluster: 0008, size: 0A, attrId: 0000, encoding: 20, command: 01, value: FE)
dev:3462023-06-15 11:59:57.286 AMinfoKitchen Lights Switch: Report received Power-On State: 255 (Previous)
dev:3462023-06-15 11:59:57.285 AMtraceKitchen Lights Switch: ON_OFF_CLUSTER (clusterId:0006 attrId:4003 value:FF)
dev:3462023-06-15 11:59:57.282 AMdebugKitchen Lights Switch: [raw:27730100060A034030FF, dni:2773, endpoint:01, cluster:0006, size:0A, attrId:4003, encoding:30, command:01, value:FF, clusterInt:6, attrInt:16387]
dev:3462023-06-15 11:59:57.280 AMdebugKitchen Lights Switch: parse(read attr - raw: 27730100060A034030FF, dni: 2773, endpoint: 01, cluster: 0006, size: 0A, attrId: 4003, encoding: 30, command: 01, value: FF)
dev:3462023-06-15 11:59:56.976 AMinfoKitchen Lights Switch: Report received Switch: 1 (on)
dev:3462023-06-15 11:59:56.974 AMtraceKitchen Lights Switch: ON_OFF_CLUSTER (clusterId:0006 attrId:0000 value:01 [name:switch, value:on])
dev:3462023-06-15 11:59:56.969 AMdebugKitchen Lights Switch: zigbee.getEvent [name:switch, value:on]
dev:3462023-06-15 11:59:56.965 AMdebugKitchen Lights Switch: [raw:27730100060A00001001, dni:2773, endpoint:01, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:01, clusterInt:6, attrInt:0]
dev:3462023-06-15 11:59:56.961 AMdebugKitchen Lights Switch: parse(read attr - raw: 27730100060A00001001, dni: 2773, endpoint: 01, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 01)
dev:3462023-06-15 11:59:56.868 AMtraceKitchen Lights Switch: Binding Cluster (clusterId:8021 data:[C0, 00])
dev:3462023-06-15 11:59:56.865 AMinfoKitchen Lights Switch: Binding Cluster
dev:3462023-06-15 11:59:56.862 AMdebugKitchen Lights Switch: [raw:catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 C000, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[C0, 00]]
dev:3462023-06-15 11:59:56.860 AMdebugKitchen Lights Switch: parse(catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 C000)
dev:3462023-06-15 11:59:56.609 AMinfoKitchen Lights Switch: Report received FW Version: 2.08
dev:3462023-06-15 11:59:56.608 AMtraceKitchen Lights Switch: BASIC_CLUSTER (clusterId:0000 attrId:4000 value:2.08)
dev:3462023-06-15 11:59:56.605 AMdebugKitchen Lights Switch: [raw:27730100001200404204322E3038, dni:2773, endpoint:01, cluster:0000, size:12, attrId:4000, encoding:42, command:01, value:2.08, clusterInt:0, attrInt:16384]
dev:3462023-06-15 11:59:56.603 AMdebugKitchen Lights Switch: parse(read attr - raw: 27730100001200404204322E3038, dni: 2773, endpoint: 01, cluster: 0000, size: 12, attrId: 4000, encoding: 42, command: 01, value: 04322E3038)
dev:3462023-06-15 11:59:56.281 AMinfoKitchen Lights Switch: Report received Power Source: 1 (Neutral)
dev:3462023-06-15 11:59:56.279 AMtraceKitchen Lights Switch: BASIC_CLUSTER (clusterId:0000 attrId:0007 value:01)
dev:3462023-06-15 11:59:56.277 AMdebugKitchen Lights Switch: zigbee.getEvent [name:powerSource, value:mains]
dev:3462023-06-15 11:59:56.274 AMdebugKitchen Lights Switch: [raw:27730100000A07003001, dni:2773, endpoint:01, cluster:0000, size:0A, attrId:0007, encoding:30, command:01, value:01, clusterInt:0, attrInt:7]
dev:3462023-06-15 11:59:56.272 AMdebugKitchen Lights Switch: parse(read attr - raw: 27730100000A07003001, dni: 2773, endpoint: 01, cluster: 0000, size: 0A, attrId: 0007, encoding: 30, command: 01, value: 01)
dev:3462023-06-15 11:59:55.941 AMinfoKitchen Lights Switch: Report received FW Date: 20221110
dev:3462023-06-15 11:59:55.940 AMtraceKitchen Lights Switch: BASIC_CLUSTER (clusterId:0000 attrId:0006 value:20221110)
dev:3462023-06-15 11:59:55.937 AMdebugKitchen Lights Switch: [raw:27730100001A060042083230323231313130, dni:2773, endpoint:01, cluster:0000, size:1A, attrId:0006, encoding:42, command:01, value:20221110, clusterInt:0, attrInt:6]
dev:3462023-06-15 11:59:55.934 AMdebugKitchen Lights Switch: parse(read attr - raw: 27730100001A060042083230323231313130, dni: 2773, endpoint: 01, cluster: 0000, size: 1A, attrId: 0006, encoding: 42, command: 01, value: 083230323231313130)
dev:3462023-06-15 11:59:55.669 AMinfoKitchen Lights Switch: Report received Model: VZM31-SN
dev:3462023-06-15 11:59:55.667 AMtraceKitchen Lights Switch: BASIC_CLUSTER (clusterId:0000 attrId:0005 value:VZM31-SN)
dev:3462023-06-15 11:59:55.665 AMdebugKitchen Lights Switch: There was an error while calling zigbee.getEvent: read attr - raw: 27730100001A05004208565A4D33312D534E, dni: 2773, endpoint: 01, cluster: 0000, size: 1A, attrId: 0005, encoding: 42, command: 01, value: 08565A4D33312D534E
dev:3462023-06-15 11:59:55.662 AMdebugKitchen Lights Switch: [raw:27730100001A05004208565A4D33312D534E, dni:2773, endpoint:01, cluster:0000, size:1A, attrId:0005, encoding:42, command:01, value:VZM31-SN, clusterInt:0, attrInt:5]
dev:3462023-06-15 11:59:55.660 AMdebugKitchen Lights Switch: parse(read attr - raw: 27730100001A05004208565A4D33312D534E, dni: 2773, endpoint: 01, cluster: 0000, size: 1A, attrId: 0005, encoding: 42, command: 01, value: 08565A4D33312D534E)
dev:3462023-06-15 11:59:55.572 AMtraceKitchen Lights Switch: MULTISTATE_OUTPUT_CLUSTER (clusterId:0013 data:[89, 73, 27, 5F, F4, 56, FE, FF, B1, 5C, 6C, 8E])
dev:3462023-06-15 11:59:55.571 AMinfoKitchen Lights Switch: Alexa Heartbeat
dev:3462023-06-15 11:59:55.568 AMdebugKitchen Lights Switch: [raw:catchall: 0000 0013 00 00 0040 00 2773 00 00 0000 00 00 8973275FF456FEFFB15C6C8E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[89, 73, 27, 5F, F4, 56, FE, FF, B1, 5C, 6C, 8E]]
dev:3462023-06-15 11:59:55.566 AMdebugKitchen Lights Switch: parse(catchall: 0000 0013 00 00 0040 00 2773 00 00 0000 00 00 8973275FF456FEFFB15C6C8E)
dev:3462023-06-15 11:59:54.984 AMtraceKitchen Lights Switch: Binding Cluster (clusterId:8021 data:[BF, 00])
dev:3462023-06-15 11:59:54.982 AMinfoKitchen Lights Switch: Binding Cluster
dev:3462023-06-15 11:59:54.980 AMdebugKitchen Lights Switch: [raw:catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 BF00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[BF, 00]]
dev:3462023-06-15 11:59:54.978 AMdebugKitchen Lights Switch: parse(catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 BF00)
dev:3462023-06-15 11:59:54.655 AMtraceKitchen Lights Switch: Binding Cluster (clusterId:8021 data:[BE, 00])
dev:3462023-06-15 11:59:54.653 AMinfoKitchen Lights Switch: Binding Cluster
dev:3462023-06-15 11:59:54.649 AMdebugKitchen Lights Switch: [raw:catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 BE00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[BE, 00]]
dev:3462023-06-15 11:59:54.645 AMdebugKitchen Lights Switch: parse(catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 BE00)
dev:3462023-06-15 11:59:54.320 AMtraceKitchen Lights Switch: Binding Cluster (clusterId:8021 data:[BD, 00])
dev:3462023-06-15 11:59:54.318 AMinfoKitchen Lights Switch: Binding Cluster
dev:3462023-06-15 11:59:54.314 AMdebugKitchen Lights Switch: [raw:catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 BD00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[BD, 00]]
dev:3462023-06-15 11:59:54.310 AMdebugKitchen Lights Switch: parse(catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 BD00)
dev:3462023-06-15 11:59:53.979 AMtraceKitchen Lights Switch: Binding Cluster (clusterId:8021 data:[BC, 00])
dev:3462023-06-15 11:59:53.977 AMinfoKitchen Lights Switch: Binding Cluster
dev:3462023-06-15 11:59:53.973 AMdebugKitchen Lights Switch: [raw:catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 BC00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[BC, 00]]
dev:3462023-06-15 11:59:53.970 AMdebugKitchen Lights Switch: parse(catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 BC00)
dev:3462023-06-15 11:59:53.647 AMtraceKitchen Lights Switch: Binding Cluster (clusterId:8021 data:[BB, 00])
dev:3462023-06-15 11:59:53.645 AMinfoKitchen Lights Switch: Binding Cluster
dev:3462023-06-15 11:59:53.640 AMdebugKitchen Lights Switch: [raw:catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 BB00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[BB, 00]]
dev:3462023-06-15 11:59:53.637 AMdebugKitchen Lights Switch: parse(catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 BB00)
dev:3462023-06-15 11:59:53.317 AMtraceKitchen Lights Switch: Binding Cluster (clusterId:8021 data:[BA, 00])
dev:3462023-06-15 11:59:53.314 AMinfoKitchen Lights Switch: Binding Cluster
dev:3462023-06-15 11:59:53.310 AMdebugKitchen Lights Switch: [raw:catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 BA00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[BA, 00]]
dev:3462023-06-15 11:59:53.308 AMdebugKitchen Lights Switch: parse(catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 BA00)
dev:3462023-06-15 11:59:53.149 AMtraceKitchen Lights Switch: configure [zdo bind 2773 0x01 0x01 0x0006 {6C5CB1FFFE56F45F} {}, delay 333, zdo bind 2773 0x01 0x01 0x0008 {6C5CB1FFFE56F45F} {}, delay 333, zdo bind 2773 0x01 0x01 0x0019 {6C5CB1FFFE56F45F} {}, delay 333, zdo bind 2773 0x01 0x01 0x0702 {6C5CB1FFFE56F45F} {}, delay 333, zdo bind 2773 0x01 0x01 0x0B04 {6C5CB1FFFE56F45F} {}, delay 333, zdo bind 2773 0x01 0x01 0xFC31 {6C5CB1FFFE56F45F} {}, delay 333, zdo bind 2773 0x02 0x01 0xFC31 {6C5CB1FFFE56F45F} {}, delay 333, he rattr 2773 0x01 0x0000 0x0005 {}, delay 333, he rattr 2773 0x01 0x0000 0x0006 {}, delay 333, he rattr 2773 0x01 0x0000 0x0007 {}, delay 333, he rattr 2773 0x01 0x0000 0x4000 {}, delay 333, he rattr 2773 0x01 0x0006 0x0000 {}, delay 333, he rattr 2773 0x01 0x0006 0x4003 {}, delay 333, he rattr 2773 0x01 0x0008 0x0000 {}, delay 333, he rattr 2773 0x01 0x0008 0x0010 {}, delay 333, he rattr 2773 0x01 0x0008 0x0011 {}, delay 333, he rattr 2773 0x01 0x0008 0x4000 {}, delay 333, he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 02 01}, delay 333, he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 16 00}, delay 333, he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 34 00}, delay 333, he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 15 00}, delay 333, he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 33 00}, delay 333, he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 01 01}, delay 333]
dev:3462023-06-15 11:59:53.148 AMtraceKitchen Lights Switch: getParameter [he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 01 01}, delay 333]
dev:3462023-06-15 11:59:53.146 AMtraceKitchen Lights Switch: getAttribute [he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 01 01}, delay 333]
dev:3462023-06-15 11:59:53.143 AMdebugKitchen Lights Switch getAttribute(0xFC31, 0x0101, [mfgCode:0x122F], 333)
dev:3462023-06-15 11:59:53.142 AMtraceKitchen Lights Switch: Get parameter 257
dev:3462023-06-15 11:59:53.140 AMtraceKitchen Lights Switch: getParameter [he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 33 00}, delay 333]
dev:3462023-06-15 11:59:53.139 AMtraceKitchen Lights Switch: getAttribute [he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 33 00}, delay 333]
dev:3462023-06-15 11:59:53.136 AMdebugKitchen Lights Switch getAttribute(0xFC31, 0x0033, [mfgCode:0x122F], 333)
dev:3462023-06-15 11:59:53.135 AMtraceKitchen Lights Switch: Get parameter 51
dev:3462023-06-15 11:59:53.133 AMtraceKitchen Lights Switch: getParameter [he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 15 00}, delay 333]
dev:3462023-06-15 11:59:53.132 AMtraceKitchen Lights Switch: getAttribute [he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 15 00}, delay 333]
dev:3462023-06-15 11:59:53.129 AMdebugKitchen Lights Switch getAttribute(0xFC31, 0x0015, [mfgCode:0x122F], 333)
dev:3462023-06-15 11:59:53.128 AMtraceKitchen Lights Switch: Get parameter 21
dev:3462023-06-15 11:59:53.126 AMtraceKitchen Lights Switch: getParameter [he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 34 00}, delay 333]
dev:3462023-06-15 11:59:53.125 AMtraceKitchen Lights Switch: getAttribute [he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 34 00}, delay 333]
dev:3462023-06-15 11:59:53.122 AMdebugKitchen Lights Switch getAttribute(0xFC31, 0x0034, [mfgCode:0x122F], 333)
dev:3462023-06-15 11:59:53.121 AMtraceKitchen Lights Switch: Get parameter 52
dev:3462023-06-15 11:59:53.119 AMtraceKitchen Lights Switch: getParameter [he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 16 00}, delay 333]
dev:3462023-06-15 11:59:53.118 AMtraceKitchen Lights Switch: getAttribute [he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 16 00}, delay 333]
dev:3462023-06-15 11:59:53.115 AMdebugKitchen Lights Switch getAttribute(0xFC31, 0x0016, [mfgCode:0x122F], 333)
dev:3462023-06-15 11:59:53.114 AMtraceKitchen Lights Switch: Get parameter 22
dev:3462023-06-15 11:59:53.112 AMtraceKitchen Lights Switch: getParameter [he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 02 01}, delay 333]
dev:3462023-06-15 11:59:53.111 AMtraceKitchen Lights Switch: getAttribute [he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 02 01}, delay 333]
dev:3462023-06-15 11:59:53.108 AMdebugKitchen Lights Switch getAttribute(0xFC31, 0x0102, [mfgCode:0x122F], 333)
dev:3462023-06-15 11:59:53.106 AMtraceKitchen Lights Switch: Get parameter 258
dev:3462023-06-15 11:59:53.103 AMinfoKitchen Lights Switch: Driver Date 2023-04-11
dev:3462023-06-15 11:59:53.100 AMinfoKitchen Lights Switch: configure()
dev:3462023-06-15 11:58:44.148 AMtraceKitchen Lights Switch: MULTISTATE_OUTPUT_CLUSTER (clusterId:0013 data:[87, 73, 27, 5F, F4, 56, FE, FF, B1, 5C, 6C, 8E])
dev:3462023-06-15 11:58:44.145 AMinfoKitchen Lights Switch: Alexa Heartbeat
dev:3462023-06-15 11:58:44.141 AMdebugKitchen Lights Switch: [raw:catchall: 0000 0013 00 00 0040 00 2773 00 00 0000 00 00 8773275FF456FEFFB15C6C8E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[87, 73, 27, 5F, F4, 56, FE, FF, B1, 5C, 6C, 8E]]
dev:3462023-06-15 11:58:44.139 AMdebugKitchen Lights Switch: parse(catchall: 0000 0013 00 00 0040 00 2773 00 00 0000 00 00 8773275FF456FEFFB15C6C8E)
dev:3462023-06-15 11:58:34.887 AMtraceKitchen Lights Switch: off [he cmd 0x2773 0x01 6 0 {}, delay 333]
dev:3462023-06-15 11:58:34.884 AMinfoKitchen Lights Switch: off()
dev:3462023-06-15 11:58:33.534 AMtraceKitchen Lights Switch: on [he cmd 0x2773 0x01 6 1 {}, delay 333]
dev:3462023-06-15 11:58:33.531 AMinfoKitchen Lights Switch: on()
dev:3462023-06-15 11:58:32.690 AMtraceKitchen Lights Switch: off [he cmd 0x2773 0x01 6 0 {}, delay 333]
dev:3462023-06-15 11:58:32.687 AMinfoKitchen Lights Switch: off()
dev:3462023-06-15 11:58:08.064 AMtraceKitchen Lights Switch: MULTISTATE_OUTPUT_CLUSTER (clusterId:0013 data:[85, 73, 27, 5F, F4, 56, FE, FF, B1, 5C, 6C, 8E])
dev:3462023-06-15 11:58:08.063 AMinfoKitchen Lights Switch: Alexa Heartbeat
dev:3462023-06-15 11:58:08.060 AMdebugKitchen Lights Switch: [raw:catchall: 0000 0013 00 00 0040 00 2773 00 00 0000 00 00 8573275FF456FEFFB15C6C8E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[85, 73, 27, 5F, F4, 56, FE, FF, B1, 5C, 6C, 8E]]
dev:3462023-06-15 11:58:08.058 AMdebugKitchen Lights Switch: parse(catchall: 0000 0013 00 00 0040 00 2773 00 00 0000 00 00 8573275FF456FEFFB15C6C8E)
dev:3462023-06-15 11:57:52.718 AMtraceKitchen Lights Switch: off [he cmd 0x2773 0x01 6 0 {}, delay 333]
dev:3462023-06-15 11:57:52.714 AMinfoKitchen Lights Switch: off()
dev:3462023-06-15 11:57:43.717 AMdebugKitchen Lights Switch: Debug logging Enabled
dev:3462023-06-15 11:57:43.716 AMtraceKitchen Lights Switch: Trace logging Enabled
dev:3462023-06-15 11:57:43.715 AMinfoKitchen Lights Switch: Info logging Enabled
dev:3462023-06-15 11:57:43.714 AMinfoKitchen Lights Switch: No DEVICE settings were changed
dev:3462023-06-15 11:57:43.689 AMinfoKitchen Lights Switch: updated()
dev:3462023-06-15 11:57:39.592 AMinfoKitchen Lights Switch: Receive parameter 257 value 0 (Remote Control enabled)
dev:3462023-06-15 11:57:39.590 AMtraceKitchen Lights Switch: Private Cluster ( attrId:0101 value:00)
dev:3462023-06-15 11:57:39.587 AMdebugKitchen Lights Switch: [raw:277301FC310A01011000, dni:2773, endpoint:01, cluster:FC31, size:0A, attrId:0101, encoding:10, command:01, value:00, clusterInt:64561, attrInt:257]
dev:3462023-06-15 11:57:39.585 AMdebugKitchen Lights Switch: parse(read attr - raw: 277301FC310A01011000, dni: 2773, endpoint: 01, cluster: FC31, size: 0A, attrId: 0101, encoding: 10, command: 01, value: 00)
dev:3462023-06-15 11:57:39.260 AMinfoKitchen Lights Switch: Receive parameter 51 value 0 (Bindings)
dev:3462023-06-15 11:57:39.257 AMtraceKitchen Lights Switch: Private Cluster ( attrId:0033 value:00)
dev:3462023-06-15 11:57:39.254 AMdebugKitchen Lights Switch: [raw:277301FC310A33002000, dni:2773, endpoint:01, cluster:FC31, size:0A, attrId:0033, encoding:20, command:01, value:00, clusterInt:64561, attrInt:51]
dev:3462023-06-15 11:57:39.252 AMdebugKitchen Lights Switch: parse(read attr - raw: 277301FC310A33002000, dni: 2773, endpoint: 01, cluster: FC31, size: 0A, attrId: 0033, encoding: 20, command: 01, value: 00)
dev:3462023-06-15 11:57:38.929 AMtraceKitchen Lights Switch: Dimming Method = Trailing Edge
dev:3462023-06-15 11:57:38.923 AMinfoKitchen Lights Switch: Receive parameter 21 value 1 (Neutral)
dev:3462023-06-15 11:57:38.921 AMtraceKitchen Lights Switch: Private Cluster ( attrId:0015 value:01)
dev:3462023-06-15 11:57:38.918 AMdebugKitchen Lights Switch: [raw:277301FC310A15001001, dni:2773, endpoint:01, cluster:FC31, size:0A, attrId:0015, encoding:10, command:01, value:01, clusterInt:64561, attrInt:21]
dev:3462023-06-15 11:57:38.916 AMdebugKitchen Lights Switch: parse(read attr - raw: 277301FC310A15001001, dni: 2773, endpoint: 01, cluster: FC31, size: 0A, attrId: 0015, encoding: 10, command: 01, value: 01)
dev:3462023-06-15 11:57:38.589 AMinfoKitchen Lights Switch: Receive parameter 52 value 0 (SBM disabled)
dev:3462023-06-15 11:57:38.586 AMtraceKitchen Lights Switch: Private Cluster ( attrId:0034 value:00)
dev:3462023-06-15 11:57:38.583 AMdebugKitchen Lights Switch: [raw:277301FC310A34001000, dni:2773, endpoint:01, cluster:FC31, size:0A, attrId:0034, encoding:10, command:01, value:00, clusterInt:64561, attrInt:52]
dev:3462023-06-15 11:57:38.581 AMdebugKitchen Lights Switch: parse(read attr - raw: 277301FC310A34001000, dni: 2773, endpoint: 01, cluster: FC31, size: 0A, attrId: 0034, encoding: 10, command: 01, value: 00)
dev:3462023-06-15 11:57:38.260 AMtraceKitchen Lights Switch: Dimming Method = Trailing Edge
dev:3462023-06-15 11:57:38.254 AMinfoKitchen Lights Switch: Receive parameter 22 value 0 (No Aux)
dev:3462023-06-15 11:57:38.252 AMtraceKitchen Lights Switch: Private Cluster ( attrId:0016 value:00)
dev:3462023-06-15 11:57:38.248 AMdebugKitchen Lights Switch: [raw:277301FC310A16002000, dni:2773, endpoint:01, cluster:FC31, size:0A, attrId:0016, encoding:20, command:01, value:00, clusterInt:64561, attrInt:22]
dev:3462023-06-15 11:57:38.246 AMdebugKitchen Lights Switch: parse(read attr - raw: 277301FC310A16002000, dni: 2773, endpoint: 01, cluster: FC31, size: 0A, attrId: 0016, encoding: 20, command: 01, value: 00)
dev:3462023-06-15 11:57:37.927 AMtraceKitchen Lights Switch: Dimming Method = Trailing Edge
dev:3462023-06-15 11:57:37.921 AMinfoKitchen Lights Switch: Receive parameter 258 value 1 (On/Off mode)
dev:3462023-06-15 11:57:37.918 AMtraceKitchen Lights Switch: Private Cluster ( attrId:0102 value:01)
dev:3462023-06-15 11:57:37.914 AMdebugKitchen Lights Switch: [raw:277301FC310A02011001, dni:2773, endpoint:01, cluster:FC31, size:0A, attrId:0102, encoding:10, command:01, value:01, clusterInt:64561, attrInt:258]
dev:3462023-06-15 11:57:37.912 AMdebugKitchen Lights Switch: parse(read attr - raw: 277301FC310A02011001, dni: 2773, endpoint: 01, cluster: FC31, size: 0A, attrId: 0102, encoding: 10, command: 01, value: 01)
dev:3462023-06-15 11:57:37.586 AMinfoKitchen Lights Switch: Report received Power-On Level: 255 (Previous)
dev:3462023-06-15 11:57:37.585 AMtraceKitchen Lights Switch: LEVEL_CONTROL_CLUSTER (clusterId:0008 attrId:4000 value:FF [name:level, value:100])
dev:3462023-06-15 11:57:37.580 AMdebugKitchen Lights Switch: zigbee.getEvent [name:level, value:100]
dev:3462023-06-15 11:57:37.576 AMdebugKitchen Lights Switch: [raw:27730100080A004020FF, dni:2773, endpoint:01, cluster:0008, size:0A, attrId:4000, encoding:20, command:01, value:FF, clusterInt:8, attrInt:16384]
dev:3462023-06-15 11:57:37.574 AMdebugKitchen Lights Switch: parse(read attr - raw: 27730100080A004020FF, dni: 2773, endpoint: 01, cluster: 0008, size: 0A, attrId: 4000, encoding: 20, command: 01, value: FF)
dev:3462023-06-15 11:57:37.255 AMinfoKitchen Lights Switch: Report received Remote-On Level: 255 (Previous)
dev:3462023-06-15 11:57:37.253 AMtraceKitchen Lights Switch: LEVEL_CONTROL_CLUSTER (clusterId:0008 attrId:0011 value:FF [name:level, value:100])
dev:3462023-06-15 11:57:37.250 AMdebugKitchen Lights Switch: zigbee.getEvent [name:level, value:100]
dev:3462023-06-15 11:57:37.247 AMdebugKitchen Lights Switch: [raw:27730100080A110020FF, dni:2773, endpoint:01, cluster:0008, size:0A, attrId:0011, encoding:20, command:01, value:FF, clusterInt:8, attrInt:17]
dev:3462023-06-15 11:57:37.244 AMdebugKitchen Lights Switch: parse(read attr - raw: 27730100080A110020FF, dni: 2773, endpoint: 01, cluster: 0008, size: 0A, attrId: 0011, encoding: 20, command: 01, value: FF)
dev:3462023-06-15 11:57:36.925 AMinfoKitchen Lights Switch: Report received On/Off Transition: 3s
dev:3462023-06-15 11:57:36.924 AMtraceKitchen Lights Switch: LEVEL_CONTROL_CLUSTER (clusterId:0008 attrId:0010 value:001E [name:level, value:12])
dev:3462023-06-15 11:57:36.920 AMdebugKitchen Lights Switch: zigbee.getEvent [name:level, value:12]
dev:3462023-06-15 11:57:36.917 AMdebugKitchen Lights Switch: [raw:27730100080C1000211E00, dni:2773, endpoint:01, cluster:0008, size:0C, attrId:0010, encoding:21, command:01, value:001E, clusterInt:8, attrInt:16]
dev:3462023-06-15 11:57:36.914 AMdebugKitchen Lights Switch: parse(read attr - raw: 27730100080C1000211E00, dni: 2773, endpoint: 01, cluster: 0008, size: 0C, attrId: 0010, encoding: 21, command: 01, value: 1E00)
dev:3462023-06-15 11:57:36.608 AMinfoKitchen Lights Switch: Report received Level: 254 (100%)
dev:3462023-06-15 11:57:36.604 AMtraceKitchen Lights Switch: LEVEL_CONTROL_CLUSTER (clusterId:0008 attrId:0000 value:FE [name:level, value:99])
dev:3462023-06-15 11:57:36.593 AMdebugKitchen Lights Switch: zigbee.getEvent [name:level, value:99]
dev:3462023-06-15 11:57:36.587 AMdebugKitchen Lights Switch: [raw:27730100080A000020FE, dni:2773, endpoint:01, cluster:0008, size:0A, attrId:0000, encoding:20, command:01, value:FE, clusterInt:8, attrInt:0]
dev:3462023-06-15 11:57:36.584 AMdebugKitchen Lights Switch: parse(read attr - raw: 27730100080A000020FE, dni: 2773, endpoint: 01, cluster: 0008, size: 0A, attrId: 0000, encoding: 20, command: 01, value: FE)
dev:3462023-06-15 11:57:36.308 AMinfoKitchen Lights Switch: Report received Power-On State: 255 (Previous)
dev:3462023-06-15 11:57:36.306 AMtraceKitchen Lights Switch: ON_OFF_CLUSTER (clusterId:0006 attrId:4003 value:FF)
dev:3462023-06-15 11:57:36.300 AMdebugKitchen Lights Switch: [raw:27730100060A034030FF, dni:2773, endpoint:01, cluster:0006, size:0A, attrId:4003, encoding:30, command:01, value:FF, clusterInt:6, attrInt:16387]
dev:3462023-06-15 11:57:36.242 AMdebugKitchen Lights Switch: parse(read attr - raw: 27730100060A034030FF, dni: 2773, endpoint: 01, cluster: 0006, size: 0A, attrId: 4003, encoding: 30, command: 01, value: FF)
dev:3462023-06-15 11:57:35.917 AMinfoKitchen Lights Switch: Report received Switch: 1 (on)
dev:3462023-06-15 11:57:35.915 AMtraceKitchen Lights Switch: ON_OFF_CLUSTER (clusterId:0006 attrId:0000 value:01 [name:switch, value:on])
dev:3462023-06-15 11:57:35.912 AMdebugKitchen Lights Switch: zigbee.getEvent [name:switch, value:on]
dev:3462023-06-15 11:57:35.909 AMdebugKitchen Lights Switch: [raw:27730100060A00001001, dni:2773, endpoint:01, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:01, clusterInt:6, attrInt:0]
dev:3462023-06-15 11:57:35.907 AMdebugKitchen Lights Switch: parse(read attr - raw: 27730100060A00001001, dni: 2773, endpoint: 01, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 01)
dev:3462023-06-15 11:57:35.577 AMinfoKitchen Lights Switch: Report received FW Version: 2.08
dev:3462023-06-15 11:57:35.576 AMtraceKitchen Lights Switch: BASIC_CLUSTER (clusterId:0000 attrId:4000 value:2.08)
dev:3462023-06-15 11:57:35.574 AMdebugKitchen Lights Switch: [raw:27730100001200404204322E3038, dni:2773, endpoint:01, cluster:0000, size:12, attrId:4000, encoding:42, command:01, value:2.08, clusterInt:0, attrInt:16384]
dev:3462023-06-15 11:57:35.571 AMdebugKitchen Lights Switch: parse(read attr - raw: 27730100001200404204322E3038, dni: 2773, endpoint: 01, cluster: 0000, size: 12, attrId: 4000, encoding: 42, command: 01, value: 04322E3038)
dev:3462023-06-15 11:57:35.248 AMinfoKitchen Lights Switch: Report received Power Source: 1 (Neutral)
dev:3462023-06-15 11:57:35.247 AMtraceKitchen Lights Switch: BASIC_CLUSTER (clusterId:0000 attrId:0007 value:01)
dev:3462023-06-15 11:57:35.245 AMdebugKitchen Lights Switch: zigbee.getEvent [name:powerSource, value:mains]
dev:3462023-06-15 11:57:35.239 AMdebugKitchen Lights Switch: [raw:27730100000A07003001, dni:2773, endpoint:01, cluster:0000, size:0A, attrId:0007, encoding:30, command:01, value:01, clusterInt:0, attrInt:7]
dev:3462023-06-15 11:57:35.236 AMdebugKitchen Lights Switch: parse(read attr - raw: 27730100000A07003001, dni: 2773, endpoint: 01, cluster: 0000, size: 0A, attrId: 0007, encoding: 30, command: 01, value: 01)
dev:3462023-06-15 11:57:34.913 AMinfoKitchen Lights Switch: Report received FW Date: 20221110
dev:3462023-06-15 11:57:34.912 AMtraceKitchen Lights Switch: BASIC_CLUSTER (clusterId:0000 attrId:0006 value:20221110)
dev:3462023-06-15 11:57:34.909 AMdebugKitchen Lights Switch: [raw:27730100001A060042083230323231313130, dni:2773, endpoint:01, cluster:0000, size:1A, attrId:0006, encoding:42, command:01, value:20221110, clusterInt:0, attrInt:6]
dev:3462023-06-15 11:57:34.907 AMdebugKitchen Lights Switch: parse(read attr - raw: 27730100001A060042083230323231313130, dni: 2773, endpoint: 01, cluster: 0000, size: 1A, attrId: 0006, encoding: 42, command: 01, value: 083230323231313130)
dev:3462023-06-15 11:57:34.739 AMtraceKitchen Lights Switch: MULTISTATE_OUTPUT_CLUSTER (clusterId:0013 data:[83, 73, 27, 5F, F4, 56, FE, FF, B1, 5C, 6C, 8E])
dev:3462023-06-15 11:57:34.736 AMinfoKitchen Lights Switch: Alexa Heartbeat
dev:3462023-06-15 11:57:34.733 AMdebugKitchen Lights Switch: [raw:catchall: 0000 0013 00 00 0040 00 2773 00 00 0000 00 00 8373275FF456FEFFB15C6C8E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[83, 73, 27, 5F, F4, 56, FE, FF, B1, 5C, 6C, 8E]]
dev:3462023-06-15 11:57:34.731 AMdebugKitchen Lights Switch: parse(catchall: 0000 0013 00 00 0040 00 2773 00 00 0000 00 00 8373275FF456FEFFB15C6C8E)
dev:3462023-06-15 11:57:34.589 AMinfoKitchen Lights Switch: Report received Model: VZM31-SN
dev:3462023-06-15 11:57:34.587 AMtraceKitchen Lights Switch: BASIC_CLUSTER (clusterId:0000 attrId:0005 value:VZM31-SN)
dev:3462023-06-15 11:57:34.584 AMdebugKitchen Lights Switch: There was an error while calling zigbee.getEvent: read attr - raw: 27730100001A05004208565A4D33312D534E, dni: 2773, endpoint: 01, cluster: 0000, size: 1A, attrId: 0005, encoding: 42, command: 01, value: 08565A4D33312D534E
dev:3462023-06-15 11:57:34.572 AMdebugKitchen Lights Switch: [raw:27730100001A05004208565A4D33312D534E, dni:2773, endpoint:01, cluster:0000, size:1A, attrId:0005, encoding:42, command:01, value:VZM31-SN, clusterInt:0, attrInt:5]
dev:3462023-06-15 11:57:34.570 AMdebugKitchen Lights Switch: parse(read attr - raw: 27730100001A05004208565A4D33312D534E, dni: 2773, endpoint: 01, cluster: 0000, size: 1A, attrId: 0005, encoding: 42, command: 01, value: 08565A4D33312D534E)
dev:3462023-06-15 11:57:34.335 AMtraceKitchen Lights Switch: Binding Cluster (clusterId:8021 data:[A3, 00])
dev:3462023-06-15 11:57:34.334 AMinfoKitchen Lights Switch: Binding Cluster
dev:3462023-06-15 11:57:34.331 AMdebugKitchen Lights Switch: [raw:catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 A300, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[A3, 00]]
dev:3462023-06-15 11:57:34.330 AMdebugKitchen Lights Switch: parse(catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 A300)
dev:3462023-06-15 11:57:33.906 AMtraceKitchen Lights Switch: Binding Cluster (clusterId:8021 data:[A2, 00])
dev:3462023-06-15 11:57:33.904 AMinfoKitchen Lights Switch: Binding Cluster
dev:3462023-06-15 11:57:33.902 AMdebugKitchen Lights Switch: [raw:catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 A200, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[A2, 00]]
dev:3462023-06-15 11:57:33.899 AMdebugKitchen Lights Switch: parse(catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 A200)
dev:3462023-06-15 11:57:33.560 AMtraceKitchen Lights Switch: Binding Cluster (clusterId:8021 data:[A1, 00])
dev:3462023-06-15 11:57:33.559 AMinfoKitchen Lights Switch: Binding Cluster
dev:3462023-06-15 11:57:33.556 AMdebugKitchen Lights Switch: [raw:catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 A100, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[A1, 00]]
dev:3462023-06-15 11:57:33.551 AMdebugKitchen Lights Switch: parse(catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 A100)
dev:3462023-06-15 11:57:33.218 AMtraceKitchen Lights Switch: Binding Cluster (clusterId:8021 data:[A0, 00])
dev:3462023-06-15 11:57:33.216 AMinfoKitchen Lights Switch: Binding Cluster
dev:3462023-06-15 11:57:33.214 AMdebugKitchen Lights Switch: [raw:catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 A000, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[A0, 00]]
dev:3462023-06-15 11:57:33.212 AMdebugKitchen Lights Switch: parse(catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 A000)
dev:3462023-06-15 11:57:32.880 AMtraceKitchen Lights Switch: Binding Cluster (clusterId:8021 data:[9F, 00])
dev:3462023-06-15 11:57:32.879 AMinfoKitchen Lights Switch: Binding Cluster
dev:3462023-06-15 11:57:32.876 AMdebugKitchen Lights Switch: [raw:catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 9F00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[9F, 00]]
dev:3462023-06-15 11:57:32.875 AMdebugKitchen Lights Switch: parse(catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 9F00)
dev:3462023-06-15 11:57:32.550 AMtraceKitchen Lights Switch: Binding Cluster (clusterId:8021 data:[9E, 00])
dev:3462023-06-15 11:57:32.549 AMinfoKitchen Lights Switch: Binding Cluster
dev:3462023-06-15 11:57:32.546 AMdebugKitchen Lights Switch: [raw:catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 9E00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[9E, 00]]
dev:3462023-06-15 11:57:32.544 AMdebugKitchen Lights Switch: parse(catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 9E00)
dev:3462023-06-15 11:57:32.215 AMtraceKitchen Lights Switch: Binding Cluster (clusterId:8021 data:[9D, 00])
dev:3462023-06-15 11:57:32.213 AMinfoKitchen Lights Switch: Binding Cluster
dev:3462023-06-15 11:57:32.210 AMdebugKitchen Lights Switch: [raw:catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 9D00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[9D, 00]]
dev:3462023-06-15 11:57:32.208 AMdebugKitchen Lights Switch: parse(catchall: 0000 8021 00 00 0040 00 2773 00 00 0000 00 00 9D00)
dev:3462023-06-15 11:57:32.102 AMtraceKitchen Lights Switch: configure [zdo bind 2773 0x01 0x01 0x0006 {6C5CB1FFFE56F45F} {}, delay 333, zdo bind 2773 0x01 0x01 0x0008 {6C5CB1FFFE56F45F} {}, delay 333, zdo bind 2773 0x01 0x01 0x0019 {6C5CB1FFFE56F45F} {}, delay 333, zdo bind 2773 0x01 0x01 0x0702 {6C5CB1FFFE56F45F} {}, delay 333, zdo bind 2773 0x01 0x01 0x0B04 {6C5CB1FFFE56F45F} {}, delay 333, zdo bind 2773 0x01 0x01 0xFC31 {6C5CB1FFFE56F45F} {}, delay 333, zdo bind 2773 0x02 0x01 0xFC31 {6C5CB1FFFE56F45F} {}, delay 333, he rattr 2773 0x01 0x0000 0x0005 {}, delay 333, he rattr 2773 0x01 0x0000 0x0006 {}, delay 333, he rattr 2773 0x01 0x0000 0x0007 {}, delay 333, he rattr 2773 0x01 0x0000 0x4000 {}, delay 333, he rattr 2773 0x01 0x0006 0x0000 {}, delay 333, he rattr 2773 0x01 0x0006 0x4003 {}, delay 333, he rattr 2773 0x01 0x0008 0x0000 {}, delay 333, he rattr 2773 0x01 0x0008 0x0010 {}, delay 333, he rattr 2773 0x01 0x0008 0x0011 {}, delay 333, he rattr 2773 0x01 0x0008 0x4000 {}, delay 333, he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 02 01}, delay 333, he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 16 00}, delay 333, he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 34 00}, delay 333, he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 15 00}, delay 333, he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 33 00}, delay 333, he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 01 01}, delay 333]
dev:3462023-06-15 11:57:32.101 AMtraceKitchen Lights Switch: getParameter [he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 01 01}, delay 333]
dev:3462023-06-15 11:57:32.099 AMtraceKitchen Lights Switch: getAttribute [he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 01 01}, delay 333]
dev:3462023-06-15 11:57:32.096 AMdebugKitchen Lights Switch getAttribute(0xFC31, 0x0101, [mfgCode:0x122F], 333)
dev:3462023-06-15 11:57:32.095 AMtraceKitchen Lights Switch: Get parameter 257
dev:3462023-06-15 11:57:32.093 AMtraceKitchen Lights Switch: getParameter [he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 33 00}, delay 333]
dev:3462023-06-15 11:57:32.092 AMtraceKitchen Lights Switch: getAttribute [he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 33 00}, delay 333]
dev:3462023-06-15 11:57:32.089 AMdebugKitchen Lights Switch getAttribute(0xFC31, 0x0033, [mfgCode:0x122F], 333)
dev:3462023-06-15 11:57:32.088 AMtraceKitchen Lights Switch: Get parameter 51
dev:3462023-06-15 11:57:32.086 AMtraceKitchen Lights Switch: getParameter [he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 15 00}, delay 333]
dev:3462023-06-15 11:57:32.085 AMtraceKitchen Lights Switch: getAttribute [he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 15 00}, delay 333]
dev:3462023-06-15 11:57:32.082 AMdebugKitchen Lights Switch getAttribute(0xFC31, 0x0015, [mfgCode:0x122F], 333)
dev:3462023-06-15 11:57:32.081 AMtraceKitchen Lights Switch: Get parameter 21
dev:3462023-06-15 11:57:32.079 AMtraceKitchen Lights Switch: getParameter [he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 34 00}, delay 333]
dev:3462023-06-15 11:57:32.078 AMtraceKitchen Lights Switch: getAttribute [he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 34 00}, delay 333]
dev:3462023-06-15 11:57:32.075 AMdebugKitchen Lights Switch getAttribute(0xFC31, 0x0034, [mfgCode:0x122F], 333)
dev:3462023-06-15 11:57:32.074 AMtraceKitchen Lights Switch: Get parameter 52
dev:3462023-06-15 11:57:32.072 AMtraceKitchen Lights Switch: getParameter [he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 16 00}, delay 333]
dev:3462023-06-15 11:57:32.071 AMtraceKitchen Lights Switch: getAttribute [he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 16 00}, delay 333]
dev:3462023-06-15 11:57:32.067 AMdebugKitchen Lights Switch getAttribute(0xFC31, 0x0016, [mfgCode:0x122F], 333)
dev:3462023-06-15 11:57:32.065 AMtraceKitchen Lights Switch: Get parameter 22
dev:3462023-06-15 11:57:32.064 AMtraceKitchen Lights Switch: getParameter [he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 02 01}, delay 333]
dev:3462023-06-15 11:57:32.062 AMtraceKitchen Lights Switch: getAttribute [he raw 0x2773 1 0x01 0xFC31 {04 2F 12 00 00 02 01}, delay 333]
dev:3462023-06-15 11:57:32.059 AMdebugKitchen Lights Switch getAttribute(0xFC31, 0x0102, [mfgCode:0x122F], 333)
dev:3462023-06-15 11:57:32.056 AMtraceKitchen Lights Switch: Get parameter 258
dev:3462023-06-15 11:57:32.052 AMinfoKitchen Lights Switch: Driver Date 2023-04-11
dev:3462023-06-15 11:57:32.049 AMinfoKitchen Lights Switch: configure()
dev:3462023-06-15 11:57:04.628 AMdebugKitchen Lights Switch: Debug logging Enabled
dev:3462023-06-15 11:57:04.627 AMtraceKitchen Lights Switch: Trace logging Enabled
dev:3462023-06-15 11:57:04.625 AMinfoKitchen Lights Switch: Info logging Enabled
dev:3462023-06-15 11:57:04.624 AMinfoKitchen Lights Switch: No DEVICE settings were changed
dev:3462023-06-15 11:57:04.596 AMinfoKitchen Lights Switch: updated()
dev:3462023-06-15 11:56:13.448 AMtraceKitchen Lights Switch: on [he cmd 0x2773 0x01 6 1 {}, delay 333]
dev:3462023-06-15 11:56:13.444 AMinfoKitchen Lights Switch: on()
dev:3462023-06-15 11:56:07.488 AMdebugKitchen Lights Switch: Debug Logging will be disabled in 5 minutes
dev:3462023-06-15 11:56:07.466 AMtraceKitchen Lights Switch: Trace Logging will be disabled in 10 minutes
dev:3462023-06-15 11:56:07.407 AMinfoKitchen Lights Switch: Info Logging will be disabled in 20 minutes
dev:3462023-06-15 11:56:07.405 AMdebugKitchen Lights Switch: Debug logging Enabled
dev:3462023-06-15 11:56:07.404 AMtraceKitchen Lights Switch: Trace logging Enabled
dev:3462023-06-15 11:56:07.400 AMinfoKitchen Lights Switch: Info logging Enabled
dev:3462023-06-15 11:56:07.399 AMinfoKitchen Lights Switch: No DEVICE settings were changed
dev:3462023-06-15 11:56:07.352 AMinfoKitchen Lights Switch: updated()
dev:3462023-06-15 11:55:22.074 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Receive parameter 257 value 0 (Remote Control enabled)
dev:3462023-06-15 11:55:21.739 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Receive parameter 51 value 0 (Bindings)
dev:3462023-06-15 11:55:21.400 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Receive parameter 21 value 1 (Neutral)
dev:3462023-06-15 11:55:21.074 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Receive parameter 52 value 0 (SBM disabled)
dev:3462023-06-15 11:55:20.679 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Receive parameter 22 value 0 (No Aux)
dev:3462023-06-15 11:55:20.349 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Receive parameter 258 value 1 (On/Off mode)
dev:3462023-06-15 11:55:20.012 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Receive parameter 8 value 127 (Local Ramp Rate Off: sync with 4)
dev:3462023-06-15 11:55:19.677 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Receive parameter 7 value 127 (Remote Ramp Rate Off: sync with 3)
dev:3462023-06-15 11:55:19.344 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Receive parameter 6 value 127 (Local Dim Rate Down: sync with 2)
dev:3462023-06-15 11:55:19.009 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Receive parameter 5 value 127 (Remote Dim Rate Down: sync with 1)
dev:3462023-06-15 11:55:18.671 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Receive parameter 4 value 127 (Local Ramp Rate On: sync with 3)
dev:3462023-06-15 11:55:18.342 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Receive parameter 3 value 127 (Remote Ramp Rate On: sync with 1)
dev:3462023-06-15 11:55:18.012 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Receive parameter 2 value 127 (Local Dim Rate Up: sync with 1)
dev:3462023-06-15 11:55:17.680 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Receive parameter 1 value 25 (Remote Dim Rate Up: 2.5s)
dev:3462023-06-15 11:55:17.335 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Report received Power-On Level: 255 (Previous)
dev:3462023-06-15 11:55:17.000 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Report received Remote-On Level: 255 (Previous)
dev:3462023-06-15 11:55:16.663 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Report received On/Off Transition: 3s
dev:3462023-06-15 11:55:16.334 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Report received Level: 254 (100%)
dev:3462023-06-15 11:55:16.000 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Report received Power-On State: 255 (Previous)
dev:3462023-06-15 11:55:15.993 AMwarnInovelli Dimmer 2-in-1 Blue Series VZM31-SN: UNKNOWN CLUSTER(0x8004) [raw:catchall: 0000 8004 00 00 0040 00 2773 00 00 0000 00 00 6B0073270AF2E0A161000000012100, profileId:0000, clusterId:8004, clusterInt:32772, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[6B, 00, 73, 27, 0A, F2, E0, A1, 61, 00, 00, 00, 01, 21, 00]] [:]
dev:3462023-06-15 11:55:15.672 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Report received Switch: 1 (on)
dev:3462023-06-15 11:55:15.320 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Report received FW Version: 2.08
dev:3462023-06-15 11:55:14.990 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Report received Power Source: 1 (Neutral)
dev:3462023-06-15 11:55:14.658 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Report received FW Date: 20221110
dev:3462023-06-15 11:55:14.496 AMwarnInovelli Dimmer 2-in-1 Blue Series VZM31-SN: UNKNOWN CLUSTER(0x8004) [raw:catchall: 0000 8004 00 00 0040 00 2773 00 00 0000 00 00 6C0073270AF2E0A161000000012100, profileId:0000, clusterId:8004, clusterInt:32772, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[6C, 00, 73, 27, 0A, F2, E0, A1, 61, 00, 00, 00, 01, 21, 00]] [:]
dev:3462023-06-15 11:55:14.489 AMwarnInovelli Dimmer 2-in-1 Blue Series VZM31-SN: UNKNOWN CLUSTER(0x8004) [raw:catchall: 0000 8004 00 00 0040 00 2773 00 00 0000 00 00 6B0073270AF2E0A161000000012100, profileId:0000, clusterId:8004, clusterInt:32772, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[6B, 00, 73, 27, 0A, F2, E0, A1, 61, 00, 00, 00, 01, 21, 00]] [:]
dev:3462023-06-15 11:55:14.457 AMwarnInovelli Dimmer 2-in-1 Blue Series VZM31-SN: UNKNOWN CLUSTER(0x8004) [raw:catchall: 0000 8004 00 00 0040 00 2773 00 00 0000 00 00 6A0073270AF2E0A161000000012100, profileId:0000, clusterId:8004, clusterInt:32772, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[6A, 00, 73, 27, 0A, F2, E0, A1, 61, 00, 00, 00, 01, 21, 00]] [:]
dev:3462023-06-15 11:55:14.427 AMwarnInovelli Dimmer 2-in-1 Blue Series VZM31-SN: UNKNOWN CLUSTER(0x8004) [raw:catchall: 0000 8004 00 00 0040 00 2773 00 00 0000 00 00 690073270AF2E0A161000000012100, profileId:0000, clusterId:8004, clusterInt:32772, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[69, 00, 73, 27, 0A, F2, E0, A1, 61, 00, 00, 00, 01, 21, 00]] [:]
dev:3462023-06-15 11:55:14.410 AMwarnInovelli Dimmer 2-in-1 Blue Series VZM31-SN: UNKNOWN CLUSTER(0x8004) [raw:catchall: 0000 8004 00 00 0040 00 2773 00 00 0000 00 00 690073270AF2E0A161000000012100, profileId:0000, clusterId:8004, clusterInt:32772, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[69, 00, 73, 27, 0A, F2, E0, A1, 61, 00, 00, 00, 01, 21, 00]] [:]
dev:3462023-06-15 11:55:14.367 AMwarnInovelli Dimmer 2-in-1 Blue Series VZM31-SN: UNKNOWN CLUSTER(0x8004) [raw:catchall: 0000 8004 00 00 0040 00 2773 00 00 0000 00 00 670073270AF2E0A161000000012100, profileId:0000, clusterId:8004, clusterInt:32772, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[67, 00, 73, 27, 0A, F2, E0, A1, 61, 00, 00, 00, 01, 21, 00]] [:]
dev:3462023-06-15 11:55:14.365 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Report received Model: VZM31-SN
dev:3462023-06-15 11:55:13.976 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Binding Cluster
dev:3462023-06-15 11:55:13.643 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Binding Cluster
dev:3462023-06-15 11:55:13.307 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Binding Cluster
dev:3462023-06-15 11:55:12.983 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Binding Cluster
dev:3462023-06-15 11:55:12.898 AMwarnInovelli Dimmer 2-in-1 Blue Series VZM31-SN: UNKNOWN CLUSTER(0x8004) [raw:catchall: 0000 8004 00 00 0040 00 2773 00 00 0000 00 00 6C0073270AF2E0A161000000012100, profileId:0000, clusterId:8004, clusterInt:32772, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[6C, 00, 73, 27, 0A, F2, E0, A1, 61, 00, 00, 00, 01, 21, 00]] [:]
dev:3462023-06-15 11:55:12.888 AMwarnInovelli Dimmer 2-in-1 Blue Series VZM31-SN: UNKNOWN CLUSTER(0x8004) [raw:catchall: 0000 8004 00 00 0040 00 2773 00 00 0000 00 00 6A0073270AF2E0A161000000012100, profileId:0000, clusterId:8004, clusterInt:32772, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[6A, 00, 73, 27, 0A, F2, E0, A1, 61, 00, 00, 00, 01, 21, 00]] [:]
dev:3462023-06-15 11:55:12.881 AMwarnInovelli Dimmer 2-in-1 Blue Series VZM31-SN: UNKNOWN CLUSTER(0x8004) [raw:catchall: 0000 8004 00 00 0040 00 2773 00 00 0000 00 00 6B0073270AF2E0A161000000012100, profileId:0000, clusterId:8004, clusterInt:32772, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[6B, 00, 73, 27, 0A, F2, E0, A1, 61, 00, 00, 00, 01, 21, 00]] [:]
dev:3462023-06-15 11:55:12.821 AMwarnInovelli Dimmer 2-in-1 Blue Series VZM31-SN: UNKNOWN CLUSTER(0x8004) [raw:catchall: 0000 8004 00 00 0040 00 2773 00 00 0000 00 00 670073270AF2E0A161000000012100, profileId:0000, clusterId:8004, clusterInt:32772, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[67, 00, 73, 27, 0A, F2, E0, A1, 61, 00, 00, 00, 01, 21, 00]] [:]
dev:3462023-06-15 11:55:12.796 AMwarnInovelli Dimmer 2-in-1 Blue Series VZM31-SN: UNKNOWN CLUSTER(0x8004) [raw:catchall: 0000 8004 00 00 0040 00 2773 00 00 0000 00 00 680073270AF2E0A161000000012100, profileId:0000, clusterId:8004, clusterInt:32772, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[68, 00, 73, 27, 0A, F2, E0, A1, 61, 00, 00, 00, 01, 21, 00]] [:]
dev:3462023-06-15 11:55:12.788 AMwarnInovelli Dimmer 2-in-1 Blue Series VZM31-SN: UNKNOWN CLUSTER(0x8004) [raw:catchall: 0000 8004 00 00 0040 00 2773 00 00 0000 00 00 680073270AF2E0A161000000012100, profileId:0000, clusterId:8004, clusterInt:32772, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[68, 00, 73, 27, 0A, F2, E0, A1, 61, 00, 00, 00, 01, 21, 00]] [:]
dev:3462023-06-15 11:55:12.705 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Binding Cluster
dev:3462023-06-15 11:55:12.692 AMwarnInovelli Dimmer 2-in-1 Blue Series VZM31-SN: UNKNOWN CLUSTER(0x8004) [raw:catchall: 0000 8004 00 00 0040 00 2773 00 00 0000 00 00 65007327180204010401010400000300040005000403000600080031FC, profileId:0000, clusterId:8004, clusterInt:32772, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[65, 00, 73, 27, 18, 02, 04, 01, 04, 01, 01, 04, 00, 00, 03, 00, 04, 00, 05, 00, 04, 03, 00, 06, 00, 08, 00, 31, FC]] [:]
dev:3462023-06-15 11:55:12.681 AMwarnInovelli Dimmer 2-in-1 Blue Series VZM31-SN: UNKNOWN CLUSTER(0x8004) [raw:catchall: 0000 8004 00 00 0040 00 2773 00 00 0000 00 00 65007327180204010401010400000300040005000403000600080031FC, profileId:0000, clusterId:8004, clusterInt:32772, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[65, 00, 73, 27, 18, 02, 04, 01, 04, 01, 01, 04, 00, 00, 03, 00, 04, 00, 05, 00, 04, 03, 00, 06, 00, 08, 00, 31, FC]] [:]
dev:3462023-06-15 11:55:12.629 AMwarnInovelli Dimmer 2-in-1 Blue Series VZM31-SN: UNKNOWN CLUSTER(0x8004) [raw:catchall: 0000 8004 00 00 0040 00 2773 00 00 0000 00 00 63007327180204010401010400000300040005000403000600080031FC, profileId:0000, clusterId:8004, clusterInt:32772, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[63, 00, 73, 27, 18, 02, 04, 01, 04, 01, 01, 04, 00, 00, 03, 00, 04, 00, 05, 00, 04, 03, 00, 06, 00, 08, 00, 31, FC]] [:]
dev:3462023-06-15 11:55:12.615 AMwarnInovelli Dimmer 2-in-1 Blue Series VZM31-SN: UNKNOWN CLUSTER(0x8004) [raw:catchall: 0000 8004 00 00 0040 00 2773 00 00 0000 00 00 63007327180204010401010400000300040005000403000600080031FC, profileId:0000, clusterId:8004, clusterInt:32772, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[63, 00, 73, 27, 18, 02, 04, 01, 04, 01, 01, 04, 00, 00, 03, 00, 04, 00, 05, 00, 04, 03, 00, 06, 00, 08, 00, 31, FC]] [:]
dev:3462023-06-15 11:55:12.584 AMwarnInovelli Dimmer 2-in-1 Blue Series VZM31-SN: UNKNOWN CLUSTER(0x8004) [raw:catchall: 0000 8004 00 00 0040 00 2773 00 00 0000 00 00 61007327180204010401010400000300040005000403000600080031FC, profileId:0000, clusterId:8004, clusterInt:32772, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2773, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[61, 00, 73, 27, 18, 02, 04, 01, 04, 01, 01, 04, 00, 00, 03, 00, 04, 00, 05, 00, 04, 03, 00, 06, 00, 08, 00, 31, FC]] [:]
dev:3462023-06-15 11:55:12.209 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Binding Cluster
dev:3462023-06-15 11:55:11.877 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Binding Cluster
dev:3462023-06-15 11:55:11.698 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: Driver Date 2023-04-11
dev:3462023-06-15 11:55:11.695 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: configure()
dev:3462023-06-15 11:55:11.685 AMinfoInovelli Dimmer 2-in-1 Blue Series VZM31-SN: installed()
I noticed a bunch about unknown cluster and also there is an Alexa Heartbeat which I am not sure of why that is as I removed the Alexa Skills App from Hubitat and also unplugged my two alexa devices.
I just found this post. Seems similar issue.
https://community.inovelli.com/t/blue-2-1-only-pairs-for-2-seconds/13980
Yea I was going to ask if you could move the switch or hub closer to pair. You could use an old CPU cord and cut off the plug and wire it to the switch. Plug into an outlet near the hub and pair. I didn’t see any pairing info in the log (I may have skimmed over it tbh).
Same issue :frowning:
What is an Alexa Heartbeat and does that have anything to do with the issue?
What does pairing entry look like, I see Binding Cluster info messages everywhere and I also see this:
" 2023-06-15 12:42:01.345 PMdebugKitchen Lights Switch: There was an error while calling zigbee.getEvent: read attr - raw: 95F20100001A05004208565A4D33312D534E, dni: 95F2, endpoint: 01, cluster: 0000, size: 1A, attrId: 0005, encoding: 42, command: 01, value: 08565A4D33312D534E
dev:348"
Well I went scorched earth on zigbee in hubitat. Reset everything, changed channels etc. Then I fist paired the switch and all was well. Now Im in the process of adding back the Sengled bulbs. Hopefully they play well and if not then we’ll go from there
How many of these do you have? They are the zigbee equivalent of the Zooz ZSE40 z-wave 4-in-1 sensors. Looks great on paper and the price is right, but add two or three to your network and the whole thing comes to a screeching halt. In isolation the Sengled bulbs are reported to be …ok, but if you have other brands/devices, incompatibilities are widely reported.
Well that sucks. I have 18. The rest of my lights are Wiz. It wasn’t until after I bought the switches I realized the lights are not listed as compatible…err not listed as certified.
And this is why I sort of wish I waited for the Reds… Zigbee’s lack of standards enforcement means there are tons of these kinds of incompatibilities across brands.
