Blue Series 2-1 Won't Enter Pairing Mode
Hello! I just got my Blue Series switches, and I was able to install 4 that weren’t in the recall. However, one of them refuses to enter pairing mode.
I hold the up paddle and then the config button, then wait for the LED to go green, then yellow, then red, then release the config and then paddle, the LED flashes red, but then goes solid blue. I’ve had no issue pairing the other 3 working switches with this method. Any suggestions?
If it matters, the neutral wire on this switch is jumped from another (working) Blue Series in the same 2-gang box. They’re both individually controlling their own single-pole lights.
Try config button then up paddle. Wait for red LED then release config button followed by the up paddle.
The switch should restart and begin pairing after a few seconds.
After it flashes red, you should get a solid blue as you mentioned, but only for a few seconds. It should then switch to pulsing blue.
Which hub are you pairing with?
I’m using Home Assistant, but it won’t even go into pairing mode and is not discoverable. My 3 other working switches paired with no issue. Here’s a video of what happens when I manually reset the switch, there’s no change to the LED afterwards.
I thought it was solid blue because I had the power off, but now I can see it’s a very dim blue: https://imgur.com/a/VlkQXO2
I see what you mean regarding the intensity. Can’t even see it pulsing on the video. It may be defective.
Try pulling out the air gap to see if that triggers pairing. That’s what I had to do to get one of mine to pair, after it didn’t automatically start pairing and after the paddle presses didn’t work either.
That solved it! After pulling/resetting the air gap it immediately went into pairing mode and was discovered by Home Assistant. Thank you!
I recently purchased a few more Blue 2-in-1s, and I’m running into this issue on one of them as well. I’ve tried all three options to put the device in pairing mode, but nothing seems to work.
  • Holding down Config + Up for 20 seconds until the light bar flashes red three times
  • Pressing Config three times quickly (I’ve tried various speeds to be safe)
  • Pulling the air gap out and pressing it back in
I’ve also tried various combinations, such as the button presses while the air gap is pulled. Nothing works. Every time I try one of the options, the light bar goes back to the on or off state and pairing mode never starts (flashing blue light bar).
Any tips for what to try next?
FWIW, I got it to enter pairing mode once right after I installed the switch. And I was even able to pair it with Home Assistant. But it kept dropping the connection in ZHA so I tried removing it from HA and re-pairing. Ever since then, it won’t go into pairing mode again.
I am having the same issue, did you ever find a fix?
I’m also having this issue. I got a batch of blue’s about 6 months ago, had two spares and neither will pair, even after factory resetting they don’t go into pairing mode without being forced and even then my Sonoff controller won’t find them even though I’m pairing from about 6’ away with direct line of sight.
