Blue Series Dimming Tech
Not true. Only the 15A On/Off switch is rated for 15A; 1500W incandescent or 3/4 HP motor loads. Model: D215S-2RW
However, look really close at the Safety notes found in all their manuals (15A or non-neutral switch). Here’s the a screenshot directly from the 15A model manual.
So yes, their 15A SKU can support up to 15A, but it is not meant to control a receptacle as noted. If a house burned down an due to someone used a large amperage load and caused the switch to catch fire; insurance would investigate and find the end user installed the product incorrectly. It does not follow NEC regulations and they would not have to pay out money for the repairs or replacement. He or she could attempt to sue the company, but he or she would not have a good case against the company. It is clearly identified in the manual and misuse of the product is not the companies fault.
I know I’m about to start a flurry of responses with this, but I wanted to at least keep everyone in the loop of what we’re testing against some of these concerns.
I’ll start with the first one because I’m not quite ready to discuss the second one as we’re still tweaking and testing.
One of the concerns is this switch needs to be capable of turning things completely on and off in order to be called an on/off switch.
We have been testing a parameter that allows for a full sine wave and I personally had a situation where I have a florescent ballast in my closet that hummed like crazy when I put the switch on it – even in on/off mode.
Testing the, “full sine wave” parameter eliminated all the humming and the light works as intended.
A few notes before watching the videos:
  • You’ll have to turn up the volume on the first one to hear the buzzing – I can try to get a better one tonight, I was just excited to test it yesterday
  • I still had the 500ms delay on so keep that in mind
  • I am talking weird bc I was trying to be quiet – I swear I’m not creepy
  • I found out about this parameter when I was in the basement and immediately went upstairs to test it out and when I say immediately, I mean I ran up both flights of stairs so I was out of breath (I tested it with full sine wave first, that’s why I’m panting like crazy in the second video, but normal in the first)
Before (No Full Sine Wave)
After (Full Sine Wave)
After some further testing, we plan to roll this out as a beta firmware. We still stand by the fact that it’s not UL rated for exhaust or ceiling fans and for safety concerns, these should not be used on outlets, but this should at least help with some buzzing and other lights that don’t fully turn off.
EDIT: Forgot to share the oscilloscope reading of this:
EDIT 2: Forgot to also mention that as of right now this is only available in a neutral, single-pole setting.
And if you think this is exciting, wait until I’m able to talk about the second feature that’s coming…
Just to confirm, that parameter will only be relevant in single-pole, non-dimming usecases?
Single Pole yes. No restriction on dimming.
This looks great! I can’t wait to try out the new FW (and hear about the 2nd feature haha)
Thanks for clarifying. Stating the obvious, would be great to see in a multi way setup (even if neutral required), but an improvement nonetheless.
Not sure what you mean. Full Wave is not available with dimming. Unless you’re thinking about the other feature which Eric hasn’t publicly announced yet
Oh right. On/off mode only. I’m confusing thing. :grimacing:
You could always use two blue switches and bind them together using Zigbee to make this work.
Awesome to hear about the full sine wave option!
Any news on this? For what it’s worth, I’d rank my wishlist:
  1. Dim lower: I have a 30W LED fixture in my bedroom (the kind with a bunch of LED chips on a circuit board); at the lowest dimming level, the switch reports 0.2W power consumption, but I’d guesstimate that it looks as bright as a 40W incandescent. I was hoping for somewhere around a 4W night light level. (And no, it’s not 100x as bright at full power :slight_smile: )
  2. Full sine wave output in on/off mode: sounds like this done!
  3. And barely making my list, trailing edge dimming: my lights all work fine with leading edge, so I’m completely fine with trailing edge not being possible. But it does seem to be the better method in general.
Is there an update on the issues discussed here? In really struggling to get these switches to dim anything smoothly - I’ve already tried 4 different styles of LED bulbs and all have exhibited undesirable characteristics that I’m hoping will at least be partially resolved by the various fixes that have already been discussed in this thread.
I’m coming from a bunch of TP-Link Kasa dimmers that I got fed up with and I was really looking forward to these new switches, but the dimming capabilities definitely have some room for improvement.
Looking forward to hearing what the new feature is as well!
I’m also bumping this topic. I have a pile of Blue switches ready to go into a new build, and there’s a part of me that’s worried I will one day be pulling out everything that needs to dim and getting Lutron Caseta instead. Every LED bulb and fixture I’ve used with a blue switch in dimming mode on my bench test unit has unacceptable flickering and buzzing. These switches contain the hardware to properly dim an LED light, but have been designed to sacrifice ideal dimming in order to maintain non-neutral installation capability instead. I hope there can be a future firmware update to make these actually workable as dimmers in the modern lighting world. The on/off function works well, but the other issues raised in this thread have me worried about longevity of the switches and fixtures even in that mode. I love all the smart features, and the look, but this is a huge achilles heel. My old Inovelli Red dimmers were never functional as dimmers for all the same problems, so I’ve been using them as generic smart switches instead. I was hoping the Blue would have solved that limitation.
Double bump. Is the feature Eric described ready yet? I don’t see it in my smartthings driver yet.
Long time lurker, first time poster.
  1. Did Eric ever say what the second feature is?
  2. I have one switch controlling 9 recessed incandescent lights – accidentally dimmed them to full brightness for more than a few minutes and something in the switch shorted – it was behaving very similar to another post above where the switch was stuck “on” and could not be turned off or dimmed, even after factory reset. Does anyone have a recommendation on LED replacements that will play nice with the leading edge dimming tech on these switches? These lights are 20 feet up and difficult to change, so I prefer to get it right the first time :slight_smile: Alternatively, I would entertain replacing all 9 lights with zigbee lights, but not sure how stable it would be for the switch to bind to 9 lights in a high ceiling.
  3. I recently moved to a new home and took all my switches with me! I have about 20 (err… 19 since I accidentally destroyed one of them) Inovelli Blue series switches (the only zigbee devices I have) and another 50-60 Z-Wave (some Inovelli, some Jasco, some other) switches. I’ll need to purchase another 30-40 switches to complete everything (I haven’t actually counted but there’s a LOT of switches) – should I wait on matter? The cost to replace everything later if matter ends up becoming dominant could very well cause marital problems :face_with_raised_eyebrow:
  4. I need some switches that are purely relay – use cases I have
    a) flourescent lighting (actually I’m not sure about this… can 2-1 work here?)
    b) exhaust fans – no need to dim, prefer simple on/off relay switch
    c) my master bath has a heater with fan in the ceiling controlled by a switch… I assume this would have to use a switched relay tech and is not suitable for either the Fan or Light swtiches?
    d) what about heat lamps? Any switches that can control these?
  5. Is it just me, or does zigbee seem to work better than zwave? I’ve found my zwave network to be very unreliable despite having many devices to make the mesh strong.
You know, you might be at or exceeding the 600W incandescent limit, and could have fried it. You should probably not hook up a new dimmer until you swap with LEDs.
I haven’t gotten my blues yet, so cannot recommend a specific bulb for dimming. But 20 feet in clear air is no big deal for zigbee. Number of walls is what matters.
Most smart switches aren’t rated for those loads, including Inovelli’s. I’d look at using a smart relay rated for your load in the heater box. You’ll have to look to see what the heater draws and then find dry contact relay that can handle it. Control the relay with Inovelli scene commands.
The upcoming Inovelli fan switch will handle bathroom fans. It’s also designed for ceiling fans, so it has speeds, but depending on the driver, you ought to be able to keep it on high.
Maybe sooner or later. Inovelli is working on a fix for the Blues so that it is a pure relay switch in the on-off mode. I’d wait to see how that shakes out.
Not officially in here, but you may be able to guess if you look from his newest (or latest ) post on the 800 series 2n1.
I seriously hope that comes to fruition. I’ve yet to find a LED fixture or bulb that dims nicely right now.
Is this not what the Jasco smart switch is (not dimmer)? From their spec sheet for Enbrighten 46201 -
Maximum Load: 960W Incandescent,
1/2 HP Motor 1800W (15A Resistive)
Is that same as what a dry contact relay would do? Looking at the Enbrighten one (and my apologies Inovelli – I realize this isn’t really the proper place to discuss competitor products… but as Inovelli doesn’t currently offer a product for this, I hope it’s ok). I have a couple of these and hear the relay click when turning on/off, so assumed it would work.
Thank you!
I’m not sure I totally understand your quesion, but I think you’re asking that since the ratings of the Jasco switch and relay are the same (I didn’t check but I believe that’s what you’re saying), why can’t you just use the switch to control a switched receptacle.
My comments were in regard to the requirements of the NEC, which specify requirements for switches controlling receptacles, not relays. I don’t know what, if any, requirements exist for those.
One of the things in play here (IMO) is that technology is rapidly evolving, but the NEC is only updated every three years. On the other hand, there are good reasons for the requirements and ratings. As an example, a user that had a high light load dimmed up to full brightness and smoked the switch, likely as a result of exceeding capacity. Smoking a switch, obviously, is a safety issue.
Hope that’s what you were asking.
