Config button interfering with paddle operation
I’m going to vote against changing the profile of the button out of the box, and instead look at if firmware can address differently multiple button presses at the same time. That or start including a second “flush” button that can be swapped in if desired.
I use the config button as a “favorite” scene in almost all my installs. The most-useful scene for that location always is set to that button.
@flipontheradio This looks like a very good suggestion which would let anyone who doesn’t use the config button as a scene button to eliminate the possibility of finding the config button in the dark instead of the on paddle. I’d buy a low profile button for each of my switches if it’s as easy as popping off the switch to replace the existing one.
@Terk, I decided to to test creating my own flush mount buttons using a palm sander and several grits of sandpaper. I’m happy with the end result and will probably work on converting the entire house over.
That turned out looking really good. I’m interested in doing the same mod.
I looked more closely at the buttons, and I noticed the config button protrudes quite a bit more than the paddle. It looks like shortening the button might eliminate accidental presses while keeping the config button functional.
@flipontheradio That looks great, I was afraid the config button would be extruded plastic with a hollow center. I think I will try that this weekend. Thanks!
Here is an idea of how much I took off as compared to a normal config button. I started with 120 grit and then went on to 240, 400, 600, 800 and finally 1000, I’m sure that’s overkill though. Only thing to watch is rounding the top of the button as you sand, I had to use the edge of the sander to flatten it back out. Best of luck!
Nicely done. That looks really good.
That turned out very good! I will have to give this a try.
@Eric_Inovelli - Take note. This is probably well worth discussing for the next version.
Or maybe sell a “low profile button” it in the store? You already sell replacement paddles add this to the list.
I really like the low profile but I have 30+ switches and don’t want to have to do them all.
Sorry for the delay here – just starting to get caught up with tickets, forum questions, beta testing, and filling some of the internal gaps due to the transition of a few people.
So, I definitely understand the predicament here and it seems like yes, there’s something that at least needs to be addressed via firmware to make it so the lights turn on even if both the config and paddle are hit at the same time. Off the top of my head, maybe there’s a way to disable Button 7 (config button) so that if you press it as well as the paddle, the switch knows to just turn on.
@EricM_Inovelli – is there a way to do this via a handler or something? I’m guessing not, but figured I’d ask.
In terms of hardware – I do think @GavinCampbell has the solution we’ve been discussing internally. On one hand, if we change up the design for V2, everyone who likes the config button the way it is and/or has purchased V1 switches will be upset that their V2 paddles don’t match their V1’s.
I realize this is not the best news for people who prefer the low-profile look as the paddles are ~$3 and can add up fast but as you can see in this thread (although this is a low sample compared to switches sold) some people prefer it the way it is, while others do not.
We’re leaning towards the separate paddle because we’re also considering offering a different LED bar design for dimmers. Something closer to the HomeSeer HS200+ look where it shows individual LED’s. It would be a simple change in the paddle design.
Long story short, we do have notes out to the manufacturer to help with this enhancement via firmware. From a hardware standpoint (paddles), this is something we can certainly explore offering a low-profile version if there’s enough interest.
From a non-firmware software perspective, there really isn’t much to do other than having the scene for the config button turn the light on. It seems like the combination of pressing them both at the same time cancels out both button presses.
I like the idea of shortening it as a possible “permanent” fix. As you mentioned, we have alternative paddles on the docket to change the design (to look more like Homeseer or others). Something that the user could purchase and swap out.
A cheaper alternative would be to sell just the config button in a shorter version. Speaking of that, does anyone here have the time / ability to create a 3D printable version of the config button? It would be great to give that option to our users.
I wonder if just making it a bit shorter would help solve most cases: not so short that it’s only good as a config button but not sticking out as far as the main paddle.
One thing we (@EricM_Inovelli, @anon14959390 and I) talked about yesterday that we are going to run by the manufacturer is to have them create a slimmer design for just the config button and maybe just sell them in packs of 10 or something for a few bucks.
We could also see if they’d sell us alternate LED bars to mimic the HomeSeer / Lutron look.
In other words, instead of selling individual paddles for $3/piece, just sell the individual components for much less.
What do you guys think? @shaddy
More to come here.
Yes please. Even though I’ve already modded all 23 switches in my house by sanding the config button down (I’m beyond happy with them) I would happily buy a few packs of official config button replacements if they were reasonably priced and are flush. I tried slightly raised and decided I liked the flush look
I, nor any of my family have had this problem, yet. But I do like this idea. The pictures from customers that have already modified theirs, I like the look! Offering them separately may allow those who want a different color for this button, options. I personally wouldn’t do that. That would almost be as bad as horizontal faceplate screws. :astonished:
Are you trying to fight me? LOL
First off, thank you for looking into this issue. I greatly appreciate it.
I think a shorter config button is a great improvement. If someone is intending to press the config button, they already have to precisely target the smaller button. So, making it shorter and slightly harder to press sounds like a win.
I will be replacing my paddles with the ivory colored ones, so I would need to buy a pack of the shorter config buttons in ivory if the paddles come standard with the long buttons.
I love to customize, and I’m sure most people who buy Inovelli products are in the same boat. So the ability to customize the faceplate is really attractive.
LOL!
I modified all my config buttons tonight, but I’d definitely order a few packs of them when you had the shorter ones in stock, mainly for a consistent look all around as it was tough getting them all filed down the exact amount.
