Yes, it is possible, there is a real relay in the dimmer (used for 3-way) that can be disabled (A 3-Way situation may complicate this).
Then there are scenes for up, hold up, release up, down, hold down and release down that can be used to control the smart bulb. You will need to handle that on your hub however…
Yes, and we were just testing this out yesterday actually! We tested it with our Z-Wave bulb (ilumin) and our dimmer switch and it worked great.
We’re testing it out on Hubitat with Hue bulbs – just no one in the office uses Hubitat, so we’re trying to learn lol @anon14959390
In theory it should work with non-Z-Wave bulbs, but results will vary depending on the Hub you have (ie: if the Hub executes in the cloud like SmartThings or local like Hubitat).
The quickest and best way (in our opinion) is to have two of the same protocols talking to each other (ie: Z-Wave to Z-Wave or ZigBee to ZigBee).
That’s great. So just to confirm, the dimming capability only works using the Red Series Dimmer and not with the On/Offs? How was it configured in SmartThings to work?
Also, are the AUX switches also dimmers? My guess is the AUX switches are default and work with either dimmers or on/off since they simply “replicate” the main so that doesn’t matter. In your video, the 2nd aux switch did take a while to dim the bulb though :).
It’s my understanding that the Dimmer is the only one that can make smart bulbs dim in real time (however, I’m intrigued by this post: Let's see how far we can push the red series...shall we? – the hold/release was not supposed to be in the firmware haha. It’s nice that it is, but we never asked for it) – I’ll clarify with @MxMLssR in a second bc we may be talking about two different things.
When we’re talking about dimming capability, we’re talking about dimming the smart bulb in real time (well, as close as you can get w/out a wired connection).
Here’s the main distinction between the On/Off’s and Dimmers (both Red Series):
On/Off’s
You can control a smart bulb with an On/Off switch, but it will simply be On/Off (no dim)
You can, however, use scenes to change the dim level (but this is more static vs dynamic/real-time dimming).
What I mean here is that you can multi-tap your switch to setup different scenes to control your bulbs (ie: Double-tap = 25%, Triple-tap = 50%, 4x tap = 75%, etc)
But you cannot hold the button down to tell the bulb to dim up and down in real time (again, there was some bonus scenes in our firmware, so who knows per the URL above)
Dimmers
Dimmers can do the same thing as On/Off’s in regards to scenes, but they can also send a dim command to the HUB (or another Z-Wave bulb) to dim up/down
This is what was shown in the video above, which I’ll explain below.
Setup
We used the following for this setup:
Inovelli Dimmer (Red Series)
Ilumin RGBW Smart Bulb
Samsung SmartThings v3 HUB (it will work with V2 as well)
Dimmer & Bulb Device Handlers
Z-Wave Association Tools
NOTE: I’ll provide links once these are up and in stock and we’ve published the handlers/drivers. If someone runs across this and the links are still not up, tag me and I’ll add them.
Notes
The setup was a 4-Way non-neutral setting, but it will work in any setting as the wiring is not the important part here.
First, you pair the products to ST, then you use a SmartApp Eric M created to associate the dimmer and bulb together (use Group 2 & Group 4).
Now that they’re associated, they bypass the Hub and talk to one another directly
I’ll definitely provide better notes once everything is released and likely post it in the Tips & Tricks section.
Your guess is correct – it does work with either On/Off and Dimmers and I believe you’re also correct in that it replicates a push or a hold for On/Off or Dimming.
Yeah, honestly, we didn’t even know the aux switch would work with the dimmer switch to change the bulb dimness. That was an added bonus as well!
@Eric_Inovelli The beauty of association groups! I used to use association group 3 with my GE switches for the double tap functionality. Was always funny when the switches associated would turn on before the actual switch. It was because the actual switch couldn’t be part of association group and so had to go through ST and cloud processing before turning on whereas the associated switches were local.
I’m guessing for the dimmer, group 2 is single tap while group 4 is hold. Is group 3 double tap?
Unfortunately, my smart bulbs are Philip Hues i.e. zigbee so ultimately, there’d still be a lag as I won’t be able to associate them and would need to go through ST. Good to know it works great with zwave bulbs though!
So I’m curious, for those of us who intend to use these switches with Hue bulbs in a relay-disabled setting… Given that the red series on/off sends hold/release events, is there any advantage toward getting the red series dimmer switch? I’m thinking it might just be aesthetic - a larger LED indicator. Is that right?
That assumes the hold/release events stick around in future firmware releases…
I’m trying to setup 3-way with LZW31 on both ends. Slave switch is not connected to the load.
Using your smartapp I got association setup and working however there is 5-6 seconds delay before clicking the slave switch and action happening. From what I read about zwave associations - it should be quite opposite.
I see “Execution Location: Cloud” in ST - is that causing it? How could I change it to “Local”?
@Eric_Inovelli I recently purchased the Red Series Dimmer/RGBW combo pack and I’m interested in replicating this setup in my non-neutral environment with an ST Hub. Do you have any additional documentation available on how this was accomplished? You mentioned in your note that you might have some more info on this.
Also, with the Association Tools can I associate a single Red Series Dimmer with multiple RGBW bulbs for direct control? I’d like to control two bulbs in a ceiling fixture connected to a single dimmer.
Hey @mcerwin, other Eric here. First off, you can associate multiple bulbs with a single dimmer. So that is definitely a possibility. @Eric_Inovelli (Hines) might have some additional documentation, but the process is pretty straight forward. The source device would be the switch and the destination device would be the bulbs. You would create two associations (one for group 2 & one for group 4).
Don’t create associations back from the bulbs to the switch. I think I saw somebody do that and it can create a loop of commands.
@EricM_Inovelli Thanks for the pointers! I finally found the time to set this up and get it tested and it’s working just as I had envisioned with both bulbs associated with the switch.
I did notice that with the two bulbs in the fixture, they seem to have different response times. One bulb will turn on/off before the other and the dimming seems to vary between them as well. I’m new to z-wave devices having used ZigBee bulbs in the past.
Is there a way to keep the bulbs in sync or is that the just the nature of this setup?
I’m using a SmartThings hub. Could the delay be a result of the cloud processing?
There as been mention that the switches and bulbs are being reviewed for the "Works with SmartThings designation. If they are certified will this allow for local control via the hub or will the cloud processing always be a factor for these devices with SmartThings?
Yeah, keeping the bulbs perfectly in sync can be a little difficult. A lot of environments are usually ok, but in some situations there is a slight delay. Sometimes including the device as secure adds just enough overhead for things to be out of sync, but it should be pretty close. The cloud shouldn’t be at play here as the associations are device to device. I think setting the config button scene as a “favorites” scene could help with the problem. If things ever get out of sync, you hit that button and dim up or down from there.
When our devices are “Works with SmartThings” approved, they will definitely have a performance boost on the SmartThings platform, but it probably wouldn’t make a difference in this situation.
Greetings. I could use some help (i.e. point me to the directions) on how to use the config button to change bulb colors. I use the Hubitat hub. So, I can dim using a Group. But, what tips can you offer on how to change the colors easily? TIA
@EricM_Inovelli, is there a guide on the setup for this yet? I just bought my ilumin bulbs and I am having a really hard time using the association tool and switch controls.
No, there isn’t an advantage. I use my On/Offs in locations with hue bulbs and use my Dimmers at other location. As @wsdavis said, only issue could come if there’s a firmware update you want and they reminder the held/released events as I don’t believe they planned for them to be included. If using zwave bulbs, them association works better so there’s a clear advantage for the dimmers there
This question is kindergarten compared to what you guys are trying.
I have 8 gu10 bulbs set up with an Inovelli Black dimmer. I want to exchange 2 gu10s with 2 zigbee gu10s.
At this stage in my learning curve Im fine using Google assistant or SmartThings to control the 2 smart bulbs… and keep the other 6 gu10s on the Black dimmer.
Can that work? I may connect the switch when I’m farther along the learning curve. I don’t even mind of the dumb switch has to stay in the on position to make the smart bulbs work.
It’s a neutral wire a 3 way switch with a 2nd gen black dimmer and dumb switch at the end.
Thanks.
I also have some red dimmers that I could exchange with the black if needed.
