LED Effects with Inovelli Blue and Zigbee2MQTT/Home Assistant
I got my first Inovelli Blue setup in Zigbee2MQTT. Got the switch bound to some Hue Bulbs and created a scene controller in Home Assistant for multi-tap.
What is the procedure for setting LED effects? I found several sets of instructions for ZHA, but none for Zigbee2MQTT. The device page on the Inovelli Blue within Z2M says to post MQTT like:
{"led_effect": {"effect": "chase", "color": 11, "level": 90, "duration": 255}}
When I post, nothing happens.
If I try to set the led_effect effect, color, level, and duration in the Z2M ‘exposes’ tab in the UI, I get a ‘No Converter available for led_effect’ error message
Ideas?
I am getting the same error message and having the same problem.
It looks like the led effect is not exposed via mqtt. Tagging @nathanfiscus
I get the same on my end too even with the updated converter mentioned here.
Yea, I just finished looking at/loading that improved file too hoping that it also addressed LED issues. The energy/power counters are working now at least :frowning:
I too am having a problem trying to send effects via Zigbee2MQTT.
No converter available for ‘led_effect’ ({“effect”:“slow_blink”})
People are mentioning the PR to fix energy reporting, but there was another PR to address the LED effects: https://github.com/Koenkk/zigbee-herdsman-converters/pull/4802
It was merged into zigbee-herdsman-converters a few days ago, so you can either download the inovelli.js file directly from that the repo, or wait until the monthly release of Z2M comes out in a few days.
great! thanks for the information!
It seems like there’s a more “UI-based” way to set LED effects if using ZHA (see example here). Is this something that could be added to the Z2M integration at all? Where would that type of request go?
I made a script setting LED effects in Home Assistant for Z2M.
https://github.com/zanix/home-assistant-config/blob/master/scripts/inovelli_blue/inovelli_blue_led.yaml
It also has all of the new effects for firmware 2.05.
The new effects also require the newest zigbee-herdsman-converters too.
@zanix very cool! i think I saw you post someplace about potentially converting this to a blueprint, is that true?
Yep, I said that on the Home Assistant forums and once I have some extra time I will do so.
Here is the blueprint
@zanix Love the blueprint. Is it possible to modify it to work with the blue series fan switch? The fan switch entity does not show up as a selectable option. Probably because it is a fan and not a light. For example my fan entity is:
fan.0x048727fffe1b2ba0
and my 2-1 (which does show up is):
light.0x60a423fffe30a49c
I made the blueprint set to only show light entities. So that explains why it doesn’t show up.
It also filters based on the model name “Inovelli 2-in-1 switch + dimmer (VZM31-SN)” so it doesn’t try to send the commands to other devices if you pick an area for the target.
I can edit the blueprint to show fan entities and add the model name of the fan switch to the filter. If the Z2M commands are the same as the 2-in-1 it should work just fine.
Can you put this in Developer tools > Template and send back what the model string is?
{{ device_attr("fan.0x048727fffe1b2ba0", "model") }}
Inovelli Fan Controller (VZM35-SN)
I got the blueprint updated in another branch on my GitHub
It works for the light switch but since I don’t have the fan switch can you let me know if it works?
EDIT: I merged this into the main branch
Good to see you over here @zanix !
Works great, thanks! I am able to mix lights and fans to call the same notification at the same time.
Awesome! I’ll push the update to the main branch.
Now I just need to order a couple fan switches so I can use the update myself!
