September 11, 2026 / v2.03 (Please reach out to support to test)
- Added P165 (Dumb Detection Value). Default: 0. Range: 0–4.
- Added P166 (Aux Detection Value). Default: 2. Range: 0–4.
- Added a quick way to cycle through detection test settings: hold Up and press Config 9 times.
** If Switch Type is Aux, this cycles through Aux Test settings. The indicator turns yellow.
** If Switch Type is Dumb, this cycles through Dumb Test settings. The indicator turns purple. - Improved the responsiveness of button presses.
July 8, 2026 / v2.02
- Fixed LED color distortion for some colors at low brightness
- Fixed the incorrect mapping of dimming duration(P1~P8)
- Fixed duration in Switch Multi Level command
February 9, 2026 / v2.01
Note: This firmware changes the default mode from On/Off to Dimmer. Make sure after updating that the mode is correct for your load.
- Modified the range of parameter P121 from 0 to 0-1
- Changed the default value of parameter P158 to 0
- Changed the default value of parameter P15 to 100
- Fixed an issue with LED notifications not working as expected
- Fixed an issue where the device could stop sending reports after an update or after factory reset/exclusion
December 15, 2025 / v2.00
2.00
- Updated Switch Type Parameter (P22)
- New options:
0– Load only1– Dumb Switch2– AUX
- Full-wave mode is now automatically configured when using On/Off mode or Smart Bulb mode.
- New Configuration Parameter Added
- P121 – Advanced Timer Mode
- When enabled double press up button to start 5 minute timer, triple press for 10 minute timer, quad press for 15 minute timer, 5x press for 30 minute timer.
- Z-Wave SDK Upgrade
- Updated to Z-Wave SDK 7.24.2.0
- Dimmer Performance Improvements
- Optimized dimming algorithm (now matches the Zigbee dimmer switch behavior)
March 29, 2024 / v1.04
1.04
- Upgrade the Z-WAVE SDK to 7.18.8 (Fix for “sleep” issue when device does not have activity for an extended amount of time).
March 18, 2024 / v1.03
1.03
- Added Parameters:
- P23: Quick Start Light Time
- P24: Quick Start Light Level
- P120: Single Tap Handle
- P130: Fan Control Module
- P131: Fan Low Level
- P132: Fan Medium Level
- P133: Fan High Level
- P134: Fan Color
- Added a timer countdown on the LED for the auto-off timer
- When in the local protection state, you can now restore factory settings by pressing factory reset button combo
- Combo Button to Single Tap Handle change:
- Old: Hold Up + Tap Config 12x = LED Blue
- New: Hold Down + Tap Config 12x
- Fixed an issue where a lifeline report was not made when a multicast message was received
- Added Group 7 for fan control
- Central Scene Supported Report changed to 6
- Resolved a bug in Association Group Behavior
- Added ability to disable the relay when in OnOff + Full Wave mode
August 11, 2023 / v1.02
1.02
- Add read only options to see internal temperature (P32) and Overheat condition (P33)
- Button combo to show firmware version. Hold Down Button and press config button 9 times Blink White to show major version. Long blink for 1’s and short blinks for 0.3’s. Blink Orange to show minor version. Long blink for 1’s and short blinks for 0.3’s. Version 1.02 would be = 2 short blinks of white + 2 short blinks of orange.
- Add overheat detection.
July 12, 2023 / v1.01
1.01
Warning: Trailing edge mode is only to be used to enhance compatibility with some LED bulbs. It should not be used with any other load. Please reach out to support to verify that your load is compatible with trailing edge.
- Return leading edge to the default dimming mode.
- Allow user to change dimming mode from leading edge to trailing edge. This can be done with a button combination:
** Leading Edge (Default) - Hold up button and press config button 13x
** Trailing Edge - Hold down button and press config button 13x
Firmware/Red-Series/Z-Wave/VZW31-SN-2-1-Switch/Beta/1.01 at main · InovelliUSA/Firmware · GitHub
