White series fan firmware and beta lighting firmware
My white series fans have a tendency to go offline after a matter-server reboot and occasionally after power blips. Occasionally fan switches will stop responding on the matter network and go offline and never come back. The light switches don’t do this and I know the light switches are on a more recent firmware. Additionally there are network changes (i hear) in the new beta white series firmware. When will there be new firmware available for light switches and fans to see if it resolves this issue. Pulling the gap on the switch restores the switch so it is simply giving up trying to join the matter network.
I’m having another issue with the fans in that in home assistant when the inovelli matter fan switch is shared via the alexa integration to expose entities, the inovelli fans fail to expose. I can create a template fan and link to the fan and that entity exposes fine, I’m wondering if there is anyone else that has experienced that problem and if there is any chance the way the fan is exposing itself to the matter server is causing the problem.
I don’t see any issues with exposing an Inovelli fan in HA to Homekit with the HomeKit Bridge. My guess (note guess) is that the problem is in the Alexa Integration. I did see a problem with the speed presets (preset_modes) however you can disable them in HA which fixed the issue.
I also do not hav any problem with the homekit bridge. I also had issue in homekit with it creating a bunch of switches but modified it in the homekit yaml to show 3 speeds. I have been discussing it in the alexa integration section of HA. what is strange is when you expose it through the voice assistants it simply doesn’t send the device and there is no logging. all other fans (non matter, non inovelli) expose fine and when i created a template fan (my workaround) i could expose it so there is something odd in the fan definition I would guess but that could also be the HA matter integration. Thanks for you comments! Still hoping a firmware fixes the fan dropouts from the matter fabric that require a reset.
@Kaleb_Inovelli can i get an answer to the questions regarding firmware in this post. There were obvious improvement from 1.0.0 to 1.0.5 for lighting as it related to pairing and network. There is a beta firmware for the white dimmer switch which fixes some traffic noise. My only switches that fall off the matter network and get stuck are fan switches (mostly happens after a border router is rebooted or some potential network reset at router). I know someone asked about the roadmap, where can we see firmware updates that are active in dev or in beta?
Hi there,
There are community threads for firmware when they are released, for example, this is for the white series dimmer switch firmware: White Series Dimmer Switch Firmware Changelog | VTM31-SN - Switches / Firmware Discussion - Inovelli Community
I’d say to keep an eye on the community especially any firmware changelog threads that are out there. Unfortunately, we do not have an ETA on where our firmware updates stand currently.
Please let me know if you have any additional questions.
Thank you.
@Kaleb_Inovelli So since there is still no firmware thread for the fan switch, I have to keep coming back here. Same problem as I. june. Is there and updated firmware for the vtm-35 in the works. They go offline after matter server reboots and don’t come back and have to be air gapped.
The dimmer, fan with humidity don’t do this. They probably needed to be moved to 1.4 as well.
