I have tried the method of waiting 10 seconds between setting each parameter the “FAR” parameter is well within the bounds of the room but it still sees far through it (even if I adjust the sensitivity). Previously I even tried setting all the values to 0. Here are the logs I got from the CLI (I did test again with a reboot in between, still no success)
2026-02-10T22:42:37.784515580Z TRACE Inovelli mmWave Red Series Received event with handler device_lifecycle
2026-02-10T22:42:37.858437580Z TRACE Inovelli mmWave Red Series Z-Wave command(86322d01) queued for radio transmission: CC:Configuration, CID:0x04
2026-02-10T22:42:37.859876038Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received lifecycle event: infoChanged
2026-02-10T22:42:37.861127205Z TRACE Inovelli mmWave Red Series Found DeviceLifecycleDispatcher handler in zwave_switch
2026-02-10T22:42:37.861844247Z INFO Inovelli mmWave Red Series info_changed function entered
2026-02-10T22:42:37.862495413Z INFO Inovelli mmWave Red Series parameter101
2026-02-10T22:42:37.863102872Z INFO Inovelli mmWave Red Series 0
2026-02-10T22:42:37.863705455Z INFO Inovelli mmWave Red Series 2
2026-02-10T22:42:37.864362497Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={configuration_value=0, default=false, format=0, parameter_number=101, size=2}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x65\x02\x00\x00", src_channel=0, version=3}
2026-02-10T22:42:37.955045288Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={parameter_number=101}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="e", src_channel=0, version=1}
2026-02-10T22:42:37.963592497Z TRACE Inovelli mmWave Red Series Z-Wave command(794de675) queued for radio transmission: CC:Configuration, CID:0x05
2026-02-10T22:42:38.047130372Z TRACE Inovelli mmWave Red Series Z-Wave command(235a9139) queued for radio transmission: CC:Association, CID:0x01
2026-02-10T22:42:38.048186122Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={grouping_identifier=1, node_ids={1}}, cmd_class="ASSOCIATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x01\x01", src_channel=0, version=1}
2026-02-10T22:42:38.058247163Z TRACE Inovelli mmWave Red Series Z-Wave command(86322d01) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:42:38.143853872Z DEBUG Inovelli mmWave Red Series Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:42:38.228551247Z TRACE Inovelli mmWave Red Series Z-Wave command(794de675) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:42:38.401881038Z TRACE Inovelli mmWave Red Series Z-Wave command(235a9139) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:42:38.479198872Z TRACE Inovelli mmWave Red Series Received event with handler unnamed
2026-02-10T22:42:38.480280413Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={configuration_value=0, parameter_number=101, size=2}, cmd_class="CONFIGURATION", cmd_id="REPORT", dst_channels={}, encap="S2_AUTH", payload="\x65\x02\x00\x00\x00\x00", src_channel=0, version=1}
2026-02-10T22:42:38.481548622Z TRACE Inovelli mmWave Red Series Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:42:38.482280372Z DEBUG Inovelli mmWave Red Series Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:42:53.317067457Z TRACE Inovelli mmWave Red Series Received event with handler device_lifecycle
2026-02-10T22:42:53.318349332Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received lifecycle event: infoChanged
2026-02-10T22:42:53.398317040Z TRACE Inovelli mmWave Red Series Z-Wave command(e3b378fe) queued for radio transmission: CC:Configuration, CID:0x04
2026-02-10T22:42:53.399340623Z TRACE Inovelli mmWave Red Series Found DeviceLifecycleDispatcher handler in zwave_switch
2026-02-10T22:42:53.400040665Z INFO Inovelli mmWave Red Series info_changed function entered
2026-02-10T22:42:53.400682957Z INFO Inovelli mmWave Red Series parameter102
2026-02-10T22:42:53.401306832Z INFO Inovelli mmWave Red Series 300
2026-02-10T22:42:53.401926373Z INFO Inovelli mmWave Red Series 2
2026-02-10T22:42:53.402572790Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={configuration_value=300, default=false, format=0, parameter_number=102, size=2}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x66\x02\x01\x2C", src_channel=0, version=3}
2026-02-10T22:42:53.506010998Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={parameter_number=102}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="f", src_channel=0, version=1}
2026-02-10T22:42:53.513351790Z TRACE Inovelli mmWave Red Series Z-Wave command(17ab1893) queued for radio transmission: CC:Configuration, CID:0x05
2026-02-10T22:42:53.596528040Z TRACE Inovelli mmWave Red Series Z-Wave command(47342aff) queued for radio transmission: CC:Association, CID:0x01
2026-02-10T22:42:53.597691207Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={grouping_identifier=1, node_ids={1}}, cmd_class="ASSOCIATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x01\x01", src_channel=0, version=1}
2026-02-10T22:42:53.608818373Z TRACE Inovelli mmWave Red Series Z-Wave command(e3b378fe) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:42:53.705960248Z DEBUG Inovelli mmWave Red Series Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:42:53.861923040Z TRACE Inovelli mmWave Red Series Z-Wave command(17ab1893) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:42:54.035905623Z TRACE Inovelli mmWave Red Series Z-Wave command(47342aff) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:42:54.126013498Z TRACE Inovelli mmWave Red Series Received event with handler unnamed
2026-02-10T22:42:54.127293415Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={configuration_value=300, parameter_number=102, size=2}, cmd_class="CONFIGURATION", cmd_id="REPORT", dst_channels={}, encap="S2_AUTH", payload="\x66\x02\x01\x2C\x00\x00", src_channel=0, version=1}
2026-02-10T22:42:54.128618707Z TRACE Inovelli mmWave Red Series Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:42:54.129384790Z DEBUG Inovelli mmWave Red Series Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:43:04.925713125Z TRACE Inovelli mmWave Red Series Received event with handler unnamed
2026-02-10T22:43:04.928145208Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={configuration_value=0, parameter_number=116, size=4}, cmd_class="CONFIGURATION", cmd_id="REPORT", dst_channels={0}, encap="S2_AUTH", payload="\x74\x04\x00\x00\x00\x00", src_channel=10, version=1}
2026-02-10T22:43:04.930706791Z TRACE Inovelli mmWave Red Series Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:43:04.933000208Z DEBUG Inovelli mmWave Red Series Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:43:11.490001584Z TRACE Inovelli mmWave Red Series Received event with handler device_lifecycle
2026-02-10T22:43:11.631966376Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received lifecycle event: infoChanged
2026-02-10T22:43:11.651453917Z TRACE Inovelli mmWave Red Series Z-Wave command(e86d9fd5) queued for radio transmission: CC:Configuration, CID:0x04
2026-02-10T22:43:11.652481834Z TRACE Inovelli mmWave Red Series Found DeviceLifecycleDispatcher handler in zwave_switch
2026-02-10T22:43:11.655078459Z INFO Inovelli mmWave Red Series info_changed function entered
2026-02-10T22:43:11.655817792Z INFO Inovelli mmWave Red Series parameter103
2026-02-10T22:43:11.656483292Z INFO Inovelli mmWave Red Series 300
2026-02-10T22:43:11.657100459Z INFO Inovelli mmWave Red Series 2
2026-02-10T22:43:11.657746209Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={configuration_value=300, default=false, format=0, parameter_number=103, size=2}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x67\x02\x01\x2C", src_channel=0, version=3}
2026-02-10T22:43:11.788998709Z TRACE Inovelli mmWave Red Series Z-Wave command(a22297d9) queued for radio transmission: CC:Configuration, CID:0x05
2026-02-10T22:43:11.791901792Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={parameter_number=103}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="g", src_channel=0, version=1}
2026-02-10T22:43:11.925003042Z TRACE Inovelli mmWave Red Series Z-Wave command(31844218) queued for radio transmission: CC:Association, CID:0x01
2026-02-10T22:43:11.926233001Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={grouping_identifier=1, node_ids={1}}, cmd_class="ASSOCIATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x01\x01", src_channel=0, version=1}
2026-02-10T22:43:11.936522834Z TRACE Inovelli mmWave Red Series Z-Wave command(e86d9fd5) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:43:12.013772501Z DEBUG Inovelli mmWave Red Series Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:43:12.102940167Z TRACE Inovelli mmWave Red Series Z-Wave command(a22297d9) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:43:12.296762042Z TRACE Inovelli mmWave Red Series Z-Wave command(31844218) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:43:12.375208417Z TRACE Inovelli mmWave Red Series Received event with handler unnamed
2026-02-10T22:43:12.454869334Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={configuration_value=300, parameter_number=103, size=2}, cmd_class="CONFIGURATION", cmd_id="REPORT", dst_channels={}, encap="S2_AUTH", payload="\x67\x02\x01\x2C\x00\x00", src_channel=0, version=1}
2026-02-10T22:43:12.456443126Z TRACE Inovelli mmWave Red Series Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:43:12.457250959Z DEBUG Inovelli mmWave Red Series Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:43:30.097875253Z TRACE Inovelli mmWave Red Series Received event with handler device_lifecycle
2026-02-10T22:43:30.199241503Z TRACE Inovelli mmWave Red Series Z-Wave command(bb54aebc) queued for radio transmission: CC:Configuration, CID:0x04
2026-02-10T22:43:30.200439128Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received lifecycle event: infoChanged
2026-02-10T22:43:30.201657628Z TRACE Inovelli mmWave Red Series Found DeviceLifecycleDispatcher handler in zwave_switch
2026-02-10T22:43:30.202387961Z INFO Inovelli mmWave Red Series info_changed function entered
2026-02-10T22:43:30.203019503Z INFO Inovelli mmWave Red Series parameter104
2026-02-10T22:43:30.203632628Z INFO Inovelli mmWave Red Series 0
2026-02-10T22:43:30.204220669Z INFO Inovelli mmWave Red Series 2
2026-02-10T22:43:30.205122503Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={configuration_value=0, default=false, format=0, parameter_number=104, size=2}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x68\x02\x00\x00", src_channel=0, version=3}
2026-02-10T22:43:30.336407753Z TRACE Inovelli mmWave Red Series Z-Wave command(5a3be9ab) queued for radio transmission: CC:Configuration, CID:0x05
2026-02-10T22:43:30.337646336Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={parameter_number=104}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="h", src_channel=0, version=1}
2026-02-10T22:43:30.441248628Z TRACE Inovelli mmWave Red Series Z-Wave command(296ec451) queued for radio transmission: CC:Association, CID:0x01
2026-02-10T22:43:30.442497669Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={grouping_identifier=1, node_ids={1}}, cmd_class="ASSOCIATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x01\x01", src_channel=0, version=1}
2026-02-10T22:43:30.515534211Z DEBUG Inovelli mmWave Red Series Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:43:30.523285461Z TRACE Inovelli mmWave Red Series Z-Wave command(bb54aebc) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:43:31.133548170Z TRACE Inovelli mmWave Red Series Z-Wave command(5a3be9ab) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:43:31.781874378Z TRACE Inovelli mmWave Red Series Z-Wave command(296ec451) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:43:31.878591170Z TRACE Inovelli mmWave Red Series Received event with handler unnamed
2026-02-10T22:43:31.885598211Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={configuration_value=0, parameter_number=104, size=2}, cmd_class="CONFIGURATION", cmd_id="REPORT", dst_channels={}, encap="S2_AUTH", payload="\x68\x02\x00\x00\x00\x00", src_channel=0, version=1}
2026-02-10T22:43:31.886960628Z TRACE Inovelli mmWave Red Series Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:43:31.887689336Z DEBUG Inovelli mmWave Red Series Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:43:49.635630380Z TRACE Inovelli mmWave Red Series Received event with handler device_lifecycle
2026-02-10T22:43:49.645144505Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received lifecycle event: infoChanged
2026-02-10T22:43:49.728596963Z TRACE Inovelli mmWave Red Series Z-Wave command(f5415320) queued for radio transmission: CC:Configuration, CID:0x04
2026-02-10T22:43:49.731434838Z TRACE Inovelli mmWave Red Series Found DeviceLifecycleDispatcher handler in zwave_switch
2026-02-10T22:43:49.732191297Z INFO Inovelli mmWave Red Series info_changed function entered
2026-02-10T22:43:49.732837130Z INFO Inovelli mmWave Red Series parameter105
2026-02-10T22:43:49.733471630Z INFO Inovelli mmWave Red Series 5
2026-02-10T22:43:49.734079838Z INFO Inovelli mmWave Red Series 2
2026-02-10T22:43:49.734729505Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={configuration_value=5, default=false, format=0, parameter_number=105, size=2}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x69\x02\x00\x05", src_channel=0, version=3}
2026-02-10T22:43:49.827025880Z TRACE Inovelli mmWave Red Series Z-Wave command(aedeb800) queued for radio transmission: CC:Configuration, CID:0x05
2026-02-10T22:43:49.828265172Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={parameter_number=105}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="i", src_channel=0, version=1}
2026-02-10T22:43:49.921094672Z TRACE Inovelli mmWave Red Series Z-Wave command(20a0541a) queued for radio transmission: CC:Association, CID:0x01
2026-02-10T22:43:49.922185213Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={grouping_identifier=1, node_ids={1}}, cmd_class="ASSOCIATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x01\x01", src_channel=0, version=1}
2026-02-10T22:43:49.991248547Z DEBUG Inovelli mmWave Red Series Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:43:49.999327213Z TRACE Inovelli mmWave Red Series Z-Wave command(f5415320) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:43:50.243938838Z TRACE Inovelli mmWave Red Series Z-Wave command(aedeb800) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:43:50.417016088Z TRACE Inovelli mmWave Red Series Z-Wave command(20a0541a) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:43:50.481601464Z TRACE Inovelli mmWave Red Series Received event with handler unnamed
2026-02-10T22:43:50.482895005Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={configuration_value=5, parameter_number=105, size=2}, cmd_class="CONFIGURATION", cmd_id="REPORT", dst_channels={}, encap="S2_AUTH", payload="\x69\x02\x00\x05\x00\x00", src_channel=0, version=1}
2026-02-10T22:43:50.484199089Z TRACE Inovelli mmWave Red Series Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:43:50.485230714Z DEBUG Inovelli mmWave Red Series Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:44:04.105861548Z TRACE Inovelli mmWave Red Series Received event with handler unnamed
2026-02-10T22:44:04.109684257Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={}, cmd_class="TIME", cmd_id="DATE_GET", dst_channels={}, encap="S2_AUTH", payload="", src_channel=0, version=1}
2026-02-10T22:44:04.112428548Z DEBUG Inovelli mmWave Red Series Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:44:04.322681132Z TRACE Inovelli mmWave Red Series Received event with handler unnamed
2026-02-10T22:44:04.323683548Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={}, cmd_class="TIME", cmd_id="GET", dst_channels={}, encap="S2_AUTH", payload="", src_channel=0, version=1}
2026-02-10T22:44:04.325001298Z DEBUG Inovelli mmWave Red Series Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:44:09.716404966Z TRACE Inovelli mmWave Red Series Received event with handler device_lifecycle
2026-02-10T22:44:09.796008216Z TRACE Inovelli mmWave Red Series Z-Wave command(de0e1932) queued for radio transmission: CC:Configuration, CID:0x04
2026-02-10T22:44:09.797262257Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received lifecycle event: infoChanged
2026-02-10T22:44:09.798496341Z TRACE Inovelli mmWave Red Series Found DeviceLifecycleDispatcher handler in zwave_switch
2026-02-10T22:44:09.799211257Z INFO Inovelli mmWave Red Series info_changed function entered
2026-02-10T22:44:09.799853966Z INFO Inovelli mmWave Red Series parameter106
2026-02-10T22:44:09.800461341Z INFO Inovelli mmWave Red Series 100
2026-02-10T22:44:09.801075966Z INFO Inovelli mmWave Red Series 2
2026-02-10T22:44:09.801707882Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={configuration_value=100, default=false, format=0, parameter_number=106, size=2}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x6A\x02\x00\x64", src_channel=0, version=3}
2026-02-10T22:44:09.892106591Z TRACE Inovelli mmWave Red Series Z-Wave command(4819d90e) queued for radio transmission: CC:Configuration, CID:0x05
2026-02-10T22:44:09.893485549Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={parameter_number=106}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="j", src_channel=0, version=1}
2026-02-10T22:44:09.986296716Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={grouping_identifier=1, node_ids={1}}, cmd_class="ASSOCIATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x01\x01", src_channel=0, version=1}
2026-02-10T22:44:09.993472508Z TRACE Inovelli mmWave Red Series Z-Wave command(1c4624f8) queued for radio transmission: CC:Association, CID:0x01
2026-02-10T22:44:10.067761383Z DEBUG Inovelli mmWave Red Series Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:44:10.075839924Z TRACE Inovelli mmWave Red Series Z-Wave command(de0e1932) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:44:10.238529799Z TRACE Inovelli mmWave Red Series Z-Wave command(4819d90e) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:44:10.410479341Z TRACE Inovelli mmWave Red Series Z-Wave command(1c4624f8) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:44:10.480438424Z TRACE Inovelli mmWave Red Series Received event with handler unnamed
2026-02-10T22:44:10.481701716Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={configuration_value=100, parameter_number=106, size=2}, cmd_class="CONFIGURATION", cmd_id="REPORT", dst_channels={}, encap="S2_AUTH", payload="\x6A\x02\x00\x64\x00\x00", src_channel=0, version=1}
2026-02-10T22:44:10.482988133Z TRACE Inovelli mmWave Red Series Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:44:10.483740299Z DEBUG Inovelli mmWave Red Series Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:44:32.262647510Z TRACE Inovelli mmWave Red Series Received event with handler unnamed
2026-02-10T22:44:32.267213843Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={alarm_level=0, alarm_type=0, event="MOTION_DETECTION", event_parameter="", notification_status="ON", notification_type="HOME_SECURITY", v1_alarm_level=0, v1_alarm_type=0, z_wave_alarm_event=8, z_wave_alarm_status="ON", z_wave_alarm_type="BURGLAR", zensor_net_source_node_id=0}, cmd_class="NOTIFICATION", cmd_id="REPORT", dst_channels={}, encap="S2_AUTH", payload="\x00\x00\x00\xFF\x07\x08\x00", src_channel=0, version=3}
2026-02-10T22:44:32.296682177Z TRACE Inovelli mmWave Red Series Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:44:32.311519635Z TRACE Inovelli mmWave Red Series Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:44:32.317457302Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> emitting event: {"attribute_id":"motion","capability_id":"motionSensor","component_id":"main","state":{"value":"active"}}
2026-02-10T22:44:32.376206302Z DEBUG Inovelli mmWave Red Series Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:44:32.965828302Z TRACE Inovelli mmWave Red Series Received event with handler unnamed
2026-02-10T22:44:32.967651969Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={configuration_value=16777216, parameter_number=116, size=4}, cmd_class="CONFIGURATION", cmd_id="REPORT", dst_channels={0}, encap="S2_AUTH", payload="\x74\x04\x01\x00\x00\x00", src_channel=10, version=1}
2026-02-10T22:44:32.970215094Z TRACE Inovelli mmWave Red Series Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:44:32.972487302Z DEBUG Inovelli mmWave Red Series Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:44:33.494752344Z TRACE Inovelli mmWave Red Series Received event with handler unnamed
2026-02-10T22:44:33.498742885Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={current_value=99, duration=0, target_value=99, value=99}, cmd_class="SWITCH_MULTILEVEL", cmd_id="REPORT", dst_channels={}, encap="S2_AUTH", payload="\x63\x63\x00", src_channel=0, version=4}
2026-02-10T22:44:33.501981969Z TRACE Inovelli mmWave Red Series Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:44:33.504143510Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2026-02-10T22:44:33.515956177Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> emitting event: {"attribute_id":"level","capability_id":"switchLevel","component_id":"main","state":{"value":100}}
2026-02-10T22:44:33.528397552Z DEBUG Inovelli mmWave Red Series Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:44:34.411258635Z TRACE Inovelli mmWave Red Series Received event with handler unnamed
2026-02-10T22:44:34.416742510Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={precision=0, scale="LUX", sensor_type="LUMINANCE", sensor_value=61, size=4}, cmd_class="SENSOR_MULTILEVEL", cmd_id="REPORT", dst_channels={}, encap="S2_AUTH", payload="\x03\x0C\x00\x00\x00\x3D", src_channel=0, version=1}
2026-02-10T22:44:34.421432302Z TRACE Inovelli mmWave Red Series Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:44:34.429518844Z TRACE Inovelli mmWave Red Series Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:44:34.431677927Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> emitting event: {"attribute_id":"illuminance","capability_id":"illuminanceMeasurement","component_id":"main","state":{"unit":"lux","value":61}}
2026-02-10T22:44:34.443028927Z DEBUG Inovelli mmWave Red Series Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:44:35.005518927Z TRACE Inovelli mmWave Red Series Received event with handler unnamed
2026-02-10T22:44:35.009521969Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={delta_time=1642, meter_type="ELECTRIC_METER", meter_value=15.56, precision=2, previous_meter_value=0.0, rate_type="IMPORT", scale="WATTS", size=4}, cmd_class="METER", cmd_id="REPORT", dst_channels={}, encap="S2_AUTH", payload="\x21\x54\x00\x00\x06\x14\x06\x6A\x00\x00\x00\x00", src_channel=0, version=3}
2026-02-10T22:44:35.013482302Z TRACE Inovelli mmWave Red Series Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:44:35.017946677Z TRACE Inovelli mmWave Red Series Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:44:35.020203094Z INFO Inovelli mmWave Red Series <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> emitting event: {"attribute_id":"power","capability_id":"powerMeter","component_id":"main","state":{"unit":"W","value":15.56}}
2026-02-10T22:44:35.032056552Z DEBUG Inovelli mmWave Red Series Inovelli mmWave Dimmer Red Series 1 device thread event handled
