Z-Wave Motion Switch • Project Linus • Bug & Enhancement Thread
PS: To clarify; my version is the Zigbee/Blue lineup.
I’m noticing a discrepancy between the parameter descriptions in the Hubitat drivers for the red and blue mmWave switches. Could use some clarification and may be appropriate to update the descriptions for consistency (unless intentional for some reason). I don’t see that these parameters are described yet on the red series parameters page.
Blue series:
Parameter 108. mmWave Stay Life
*The delay time of the stay area is set to 50ms when it is set to 1, to 1 second when it is set to 20, and the default value is 300, that is, 15 seconds
Range=0..4294967295 Default=300
Red Series:
Parameter* 108. mmWave Stay Life
Time in seconds before reporting no motion after target leaves detection area
Range=0..3600 Default=300
–> So the Blue series seems to set the parameter in 50ms ticks (time (seconds) = value × 0.05), whereas the red series indicates the parameter is set in 1s ticks (time (seconds) = value). But the 300 default value seems quite long, so it makes me wonder if this was intended to be the same scale as the blue series?
Could you clarify whether the scale for the red series is in fact seconds or if it is in 50ms increments like the blue series?
Same question for Parameter 114:
Blue Series:
114. mmWave Detection Timeout
*Amount of time after presence detection that a no-presence report is sent
Range=0..4294967296 Default=20
Red series:*
Amount of time in seconds *after presence detection that a no-presence report is sent.
Range=0..4294967296 Default=30
No real rush on this, but just something that might be good/easy to fix as you’re pushing out other updates. Though some clarification in the meantime would be helpful!*
I am continuing to have issues setting up each of the 10 switches and have confirmed for me, Settings just dont take unless everything is done one by one and/or sent multiple times with long wait times and refresh each time.
I am wondering if there is also a driver issue. (With hubitat at least). I am on the latest driver published. When I try to use a rule to change a parameter, it errors out.
org.codehaus.groovy.runtime.metaclass.MethodSelectionException: Could not find which method setParameter() to invoke from this list:
I was trying to set the switch to not turn on unless it’s dark (using lux). This should ideally part of the base functionality. Would highly appreciate this to be an enhancement for the future (after the settings/driver issues are resolved)
Wow that’s interesting that the Hubitat drivers say second. Home Assistant says 50ms in the UI, but I’ve done testing that shows that it is being set in seconds. A driver or documentation update would be appreciated.
Also interesting that the description in Hubitat for params 108 and 114 are so similar. It makes me think that they are both doing the same thing, which I’m starting to suspect but haven’t nailed down a way to test
Param 108: Time in seconds before reporting no motion after target leaves detection area
Param 114: Amount of time in seconds after presence detection that a no-presence report is sent.
Just a follow-up, it looks like I got a driver update on Jan 28th and now the settings show with the innovelli driver. However I do still get the toast that says “the device hasn’t updated all of it’s status information”. Even with the official driver, setting the distance parameters seem to have no affect and it is still detecting through walls far beyond the limits I’ve set.
Today my z-wave motion dimmer stopped being able to turn on my lights through both the physical switch and through home assistant. It was still reporting, settings were correct, etc and I was not able to find any issue. After pulling the physical power tab and restarting the switch, it was working again. Looks like there is something causing instability. Any recommendations on what to collect if this happens again?
In the hubitat driver
111. mmWave Module Commands
Stays to what you last set for options other than reset, and the options are not really clear on what they do. Could we get better descriptions, and if they are one time commands instead of settings move them to the commands tab instead of preferences.
Are there any updates here yet? Really disappointing that we don’t have even feature parity with the blue version, yet alone the bugs with room size and such. I haven’t been able to use my switches as anything but regular switches because of this. Kinda wish I had switched to blues when I had the chance, would have if I known this was going to be the result.
Yes, see:
FYI - I’ve installed this updated firmware (2.01) and found it to resolve that issue.
Shoot, my bad, I somehow missed that. Gonna install these this week, should solve 80% of my issues. Now I just need multi-zone and I should be able to hopefully fix the issue in my office with the last switch.
They have only provided a bug fix so far.
No additional features are planned from the feedback, and have been unresponsive as to what their plan is on addressing the challenges that they are encountering exposing the same settings as the blue version. Not sure why this was not known before making the choice to continue with production.
I use 90% z-wave and 10% Zigbee, but would have considered switching to blue if I would have known that red would be left behind.
To be honest, I am in the same boat. My current system is 50/50 between Zwave and Zigbee. I would have gone to Zigbee route if I would have known that they are pushing Zigbee more than Zwave in terms of software. Eric also told within same post that they are not pushing for development for zwave which also means that we will not see improvement on zwave next 2-3 months except bug fixes.
It does not align with the roadmap that was announced for 2026. One of the key points was to “Further developing our Z-Wave product line to be consistent with the other lines”.
I installed a couple more to try and tune a large room and it’s just too much of a guessing game as I am getting inconsistent results.
FWIW - As far as I know multiple area support was never promised as a feature on this product when it was in the pre-order or development stage. I see it as a “happy benefit” that they were able to expose this functionality on the blue series in the first place.
They didn’t say that they weren’t going to try to get it on the Red series. They said that they aren’t making a commitment to it right now because they don’t have a path forward to exposing it within the Z-Wave specifications (which are a lot more rigid than Zigbee are).
These things take time to do correctly and the approach has to be approved by the Z-Wave certification group.
See this post and previous posts. I am not happy about it either. For a second, I thought about RMA to replace Zwave mmWave with Zigbee. Just to try to replace them. I am not sure that it is feasible or not.
I would not expect new features on either Blue or Red for a while. They have a small team and this is a new release. They will have to focus mainly on any issues found to polish the firmware and drivers before they can focus on new or expanded features. Any new or expanded features added in that process should be seen as a nice little bonus they managed to add in.
Once they have fixed any bugs people have found and can start working on adding features, i would still expect it to take longer on z-wave due to certification needs.
If you really want to pressure anyone, get on the z-wave alliance to build out handling of the feature set and what is needed for certification to make it easier for Inovelli.
@EricM_Inovelli
I have tried the method of waiting 10 seconds between setting each parameter the “FAR” parameter is well within the bounds of the room but it still sees far through it (even if I adjust the sensitivity). Previously I even tried setting all the values to 0. Here are the logs I got from the CLI (I did test again with a reboot in between, still no success)
2026-02-10T22:42:37.784515580Z TRACE Inovelli mmWave Red Series  Received event with handler device_lifecycle
2026-02-10T22:42:37.858437580Z TRACE Inovelli mmWave Red Series  Z-Wave command(86322d01) queued for radio transmission: CC:Configuration, CID:0x04
2026-02-10T22:42:37.859876038Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received lifecycle event: infoChanged
2026-02-10T22:42:37.861127205Z TRACE Inovelli mmWave Red Series  Found DeviceLifecycleDispatcher handler in zwave_switch
2026-02-10T22:42:37.861844247Z INFO Inovelli mmWave Red Series  info_changed function entered
2026-02-10T22:42:37.862495413Z INFO Inovelli mmWave Red Series  parameter101
2026-02-10T22:42:37.863102872Z INFO Inovelli mmWave Red Series  0
2026-02-10T22:42:37.863705455Z INFO Inovelli mmWave Red Series  2
2026-02-10T22:42:37.864362497Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={configuration_value=0, default=false, format=0, parameter_number=101, size=2}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x65\x02\x00\x00", src_channel=0, version=3}
2026-02-10T22:42:37.955045288Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={parameter_number=101}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="e", src_channel=0, version=1}
2026-02-10T22:42:37.963592497Z TRACE Inovelli mmWave Red Series  Z-Wave command(794de675) queued for radio transmission: CC:Configuration, CID:0x05
2026-02-10T22:42:38.047130372Z TRACE Inovelli mmWave Red Series  Z-Wave command(235a9139) queued for radio transmission: CC:Association, CID:0x01
2026-02-10T22:42:38.048186122Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={grouping_identifier=1, node_ids={1}}, cmd_class="ASSOCIATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x01\x01", src_channel=0, version=1}
2026-02-10T22:42:38.058247163Z TRACE Inovelli mmWave Red Series  Z-Wave command(86322d01) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:42:38.143853872Z DEBUG Inovelli mmWave Red Series  Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:42:38.228551247Z TRACE Inovelli mmWave Red Series  Z-Wave command(794de675) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:42:38.401881038Z TRACE Inovelli mmWave Red Series  Z-Wave command(235a9139) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:42:38.479198872Z TRACE Inovelli mmWave Red Series  Received event with handler unnamed
2026-02-10T22:42:38.480280413Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={configuration_value=0, parameter_number=101, size=2}, cmd_class="CONFIGURATION", cmd_id="REPORT", dst_channels={}, encap="S2_AUTH", payload="\x65\x02\x00\x00\x00\x00", src_channel=0, version=1}
2026-02-10T22:42:38.481548622Z TRACE Inovelli mmWave Red Series  Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:42:38.482280372Z DEBUG Inovelli mmWave Red Series  Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:42:53.317067457Z TRACE Inovelli mmWave Red Series  Received event with handler device_lifecycle
2026-02-10T22:42:53.318349332Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received lifecycle event: infoChanged
2026-02-10T22:42:53.398317040Z TRACE Inovelli mmWave Red Series  Z-Wave command(e3b378fe) queued for radio transmission: CC:Configuration, CID:0x04
2026-02-10T22:42:53.399340623Z TRACE Inovelli mmWave Red Series  Found DeviceLifecycleDispatcher handler in zwave_switch
2026-02-10T22:42:53.400040665Z INFO Inovelli mmWave Red Series  info_changed function entered
2026-02-10T22:42:53.400682957Z INFO Inovelli mmWave Red Series  parameter102
2026-02-10T22:42:53.401306832Z INFO Inovelli mmWave Red Series  300
2026-02-10T22:42:53.401926373Z INFO Inovelli mmWave Red Series  2
2026-02-10T22:42:53.402572790Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={configuration_value=300, default=false, format=0, parameter_number=102, size=2}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x66\x02\x01\x2C", src_channel=0, version=3}
2026-02-10T22:42:53.506010998Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={parameter_number=102}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="f", src_channel=0, version=1}
2026-02-10T22:42:53.513351790Z TRACE Inovelli mmWave Red Series  Z-Wave command(17ab1893) queued for radio transmission: CC:Configuration, CID:0x05
2026-02-10T22:42:53.596528040Z TRACE Inovelli mmWave Red Series  Z-Wave command(47342aff) queued for radio transmission: CC:Association, CID:0x01
2026-02-10T22:42:53.597691207Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={grouping_identifier=1, node_ids={1}}, cmd_class="ASSOCIATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x01\x01", src_channel=0, version=1}
2026-02-10T22:42:53.608818373Z TRACE Inovelli mmWave Red Series  Z-Wave command(e3b378fe) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:42:53.705960248Z DEBUG Inovelli mmWave Red Series  Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:42:53.861923040Z TRACE Inovelli mmWave Red Series  Z-Wave command(17ab1893) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:42:54.035905623Z TRACE Inovelli mmWave Red Series  Z-Wave command(47342aff) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:42:54.126013498Z TRACE Inovelli mmWave Red Series  Received event with handler unnamed
2026-02-10T22:42:54.127293415Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={configuration_value=300, parameter_number=102, size=2}, cmd_class="CONFIGURATION", cmd_id="REPORT", dst_channels={}, encap="S2_AUTH", payload="\x66\x02\x01\x2C\x00\x00", src_channel=0, version=1}
2026-02-10T22:42:54.128618707Z TRACE Inovelli mmWave Red Series  Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:42:54.129384790Z DEBUG Inovelli mmWave Red Series  Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:43:04.925713125Z TRACE Inovelli mmWave Red Series  Received event with handler unnamed
2026-02-10T22:43:04.928145208Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={configuration_value=0, parameter_number=116, size=4}, cmd_class="CONFIGURATION", cmd_id="REPORT", dst_channels={0}, encap="S2_AUTH", payload="\x74\x04\x00\x00\x00\x00", src_channel=10, version=1}
2026-02-10T22:43:04.930706791Z TRACE Inovelli mmWave Red Series  Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:43:04.933000208Z DEBUG Inovelli mmWave Red Series  Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:43:11.490001584Z TRACE Inovelli mmWave Red Series  Received event with handler device_lifecycle
2026-02-10T22:43:11.631966376Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received lifecycle event: infoChanged
2026-02-10T22:43:11.651453917Z TRACE Inovelli mmWave Red Series  Z-Wave command(e86d9fd5) queued for radio transmission: CC:Configuration, CID:0x04
2026-02-10T22:43:11.652481834Z TRACE Inovelli mmWave Red Series  Found DeviceLifecycleDispatcher handler in zwave_switch
2026-02-10T22:43:11.655078459Z INFO Inovelli mmWave Red Series  info_changed function entered
2026-02-10T22:43:11.655817792Z INFO Inovelli mmWave Red Series  parameter103
2026-02-10T22:43:11.656483292Z INFO Inovelli mmWave Red Series  300
2026-02-10T22:43:11.657100459Z INFO Inovelli mmWave Red Series  2
2026-02-10T22:43:11.657746209Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={configuration_value=300, default=false, format=0, parameter_number=103, size=2}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x67\x02\x01\x2C", src_channel=0, version=3}
2026-02-10T22:43:11.788998709Z TRACE Inovelli mmWave Red Series  Z-Wave command(a22297d9) queued for radio transmission: CC:Configuration, CID:0x05
2026-02-10T22:43:11.791901792Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={parameter_number=103}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="g", src_channel=0, version=1}
2026-02-10T22:43:11.925003042Z TRACE Inovelli mmWave Red Series  Z-Wave command(31844218) queued for radio transmission: CC:Association, CID:0x01
2026-02-10T22:43:11.926233001Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={grouping_identifier=1, node_ids={1}}, cmd_class="ASSOCIATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x01\x01", src_channel=0, version=1}
2026-02-10T22:43:11.936522834Z TRACE Inovelli mmWave Red Series  Z-Wave command(e86d9fd5) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:43:12.013772501Z DEBUG Inovelli mmWave Red Series  Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:43:12.102940167Z TRACE Inovelli mmWave Red Series  Z-Wave command(a22297d9) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:43:12.296762042Z TRACE Inovelli mmWave Red Series  Z-Wave command(31844218) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:43:12.375208417Z TRACE Inovelli mmWave Red Series  Received event with handler unnamed
2026-02-10T22:43:12.454869334Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={configuration_value=300, parameter_number=103, size=2}, cmd_class="CONFIGURATION", cmd_id="REPORT", dst_channels={}, encap="S2_AUTH", payload="\x67\x02\x01\x2C\x00\x00", src_channel=0, version=1}
2026-02-10T22:43:12.456443126Z TRACE Inovelli mmWave Red Series  Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:43:12.457250959Z DEBUG Inovelli mmWave Red Series  Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:43:30.097875253Z TRACE Inovelli mmWave Red Series  Received event with handler device_lifecycle
2026-02-10T22:43:30.199241503Z TRACE Inovelli mmWave Red Series  Z-Wave command(bb54aebc) queued for radio transmission: CC:Configuration, CID:0x04
2026-02-10T22:43:30.200439128Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received lifecycle event: infoChanged
2026-02-10T22:43:30.201657628Z TRACE Inovelli mmWave Red Series  Found DeviceLifecycleDispatcher handler in zwave_switch
2026-02-10T22:43:30.202387961Z INFO Inovelli mmWave Red Series  info_changed function entered
2026-02-10T22:43:30.203019503Z INFO Inovelli mmWave Red Series  parameter104
2026-02-10T22:43:30.203632628Z INFO Inovelli mmWave Red Series  0
2026-02-10T22:43:30.204220669Z INFO Inovelli mmWave Red Series  2
2026-02-10T22:43:30.205122503Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={configuration_value=0, default=false, format=0, parameter_number=104, size=2}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x68\x02\x00\x00", src_channel=0, version=3}
2026-02-10T22:43:30.336407753Z TRACE Inovelli mmWave Red Series  Z-Wave command(5a3be9ab) queued for radio transmission: CC:Configuration, CID:0x05
2026-02-10T22:43:30.337646336Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={parameter_number=104}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="h", src_channel=0, version=1}
2026-02-10T22:43:30.441248628Z TRACE Inovelli mmWave Red Series  Z-Wave command(296ec451) queued for radio transmission: CC:Association, CID:0x01
2026-02-10T22:43:30.442497669Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={grouping_identifier=1, node_ids={1}}, cmd_class="ASSOCIATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x01\x01", src_channel=0, version=1}
2026-02-10T22:43:30.515534211Z DEBUG Inovelli mmWave Red Series  Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:43:30.523285461Z TRACE Inovelli mmWave Red Series  Z-Wave command(bb54aebc) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:43:31.133548170Z TRACE Inovelli mmWave Red Series  Z-Wave command(5a3be9ab) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:43:31.781874378Z TRACE Inovelli mmWave Red Series  Z-Wave command(296ec451) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:43:31.878591170Z TRACE Inovelli mmWave Red Series  Received event with handler unnamed
2026-02-10T22:43:31.885598211Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={configuration_value=0, parameter_number=104, size=2}, cmd_class="CONFIGURATION", cmd_id="REPORT", dst_channels={}, encap="S2_AUTH", payload="\x68\x02\x00\x00\x00\x00", src_channel=0, version=1}
2026-02-10T22:43:31.886960628Z TRACE Inovelli mmWave Red Series  Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:43:31.887689336Z DEBUG Inovelli mmWave Red Series  Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:43:49.635630380Z TRACE Inovelli mmWave Red Series  Received event with handler device_lifecycle
2026-02-10T22:43:49.645144505Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received lifecycle event: infoChanged
2026-02-10T22:43:49.728596963Z TRACE Inovelli mmWave Red Series  Z-Wave command(f5415320) queued for radio transmission: CC:Configuration, CID:0x04
2026-02-10T22:43:49.731434838Z TRACE Inovelli mmWave Red Series  Found DeviceLifecycleDispatcher handler in zwave_switch
2026-02-10T22:43:49.732191297Z INFO Inovelli mmWave Red Series  info_changed function entered
2026-02-10T22:43:49.732837130Z INFO Inovelli mmWave Red Series  parameter105
2026-02-10T22:43:49.733471630Z INFO Inovelli mmWave Red Series  5
2026-02-10T22:43:49.734079838Z INFO Inovelli mmWave Red Series  2
2026-02-10T22:43:49.734729505Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={configuration_value=5, default=false, format=0, parameter_number=105, size=2}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x69\x02\x00\x05", src_channel=0, version=3}
2026-02-10T22:43:49.827025880Z TRACE Inovelli mmWave Red Series  Z-Wave command(aedeb800) queued for radio transmission: CC:Configuration, CID:0x05
2026-02-10T22:43:49.828265172Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={parameter_number=105}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="i", src_channel=0, version=1}
2026-02-10T22:43:49.921094672Z TRACE Inovelli mmWave Red Series  Z-Wave command(20a0541a) queued for radio transmission: CC:Association, CID:0x01
2026-02-10T22:43:49.922185213Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={grouping_identifier=1, node_ids={1}}, cmd_class="ASSOCIATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x01\x01", src_channel=0, version=1}
2026-02-10T22:43:49.991248547Z DEBUG Inovelli mmWave Red Series  Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:43:49.999327213Z TRACE Inovelli mmWave Red Series  Z-Wave command(f5415320) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:43:50.243938838Z TRACE Inovelli mmWave Red Series  Z-Wave command(aedeb800) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:43:50.417016088Z TRACE Inovelli mmWave Red Series  Z-Wave command(20a0541a) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:43:50.481601464Z TRACE Inovelli mmWave Red Series  Received event with handler unnamed
2026-02-10T22:43:50.482895005Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={configuration_value=5, parameter_number=105, size=2}, cmd_class="CONFIGURATION", cmd_id="REPORT", dst_channels={}, encap="S2_AUTH", payload="\x69\x02\x00\x05\x00\x00", src_channel=0, version=1}
2026-02-10T22:43:50.484199089Z TRACE Inovelli mmWave Red Series  Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:43:50.485230714Z DEBUG Inovelli mmWave Red Series  Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:44:04.105861548Z TRACE Inovelli mmWave Red Series  Received event with handler unnamed
2026-02-10T22:44:04.109684257Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={}, cmd_class="TIME", cmd_id="DATE_GET", dst_channels={}, encap="S2_AUTH", payload="", src_channel=0, version=1}
2026-02-10T22:44:04.112428548Z DEBUG Inovelli mmWave Red Series  Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:44:04.322681132Z TRACE Inovelli mmWave Red Series  Received event with handler unnamed
2026-02-10T22:44:04.323683548Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={}, cmd_class="TIME", cmd_id="GET", dst_channels={}, encap="S2_AUTH", payload="", src_channel=0, version=1}
2026-02-10T22:44:04.325001298Z DEBUG Inovelli mmWave Red Series  Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:44:09.716404966Z TRACE Inovelli mmWave Red Series  Received event with handler device_lifecycle
2026-02-10T22:44:09.796008216Z TRACE Inovelli mmWave Red Series  Z-Wave command(de0e1932) queued for radio transmission: CC:Configuration, CID:0x04
2026-02-10T22:44:09.797262257Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received lifecycle event: infoChanged
2026-02-10T22:44:09.798496341Z TRACE Inovelli mmWave Red Series  Found DeviceLifecycleDispatcher handler in zwave_switch
2026-02-10T22:44:09.799211257Z INFO Inovelli mmWave Red Series  info_changed function entered
2026-02-10T22:44:09.799853966Z INFO Inovelli mmWave Red Series  parameter106
2026-02-10T22:44:09.800461341Z INFO Inovelli mmWave Red Series  100
2026-02-10T22:44:09.801075966Z INFO Inovelli mmWave Red Series  2
2026-02-10T22:44:09.801707882Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={configuration_value=100, default=false, format=0, parameter_number=106, size=2}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x6A\x02\x00\x64", src_channel=0, version=3}
2026-02-10T22:44:09.892106591Z TRACE Inovelli mmWave Red Series  Z-Wave command(4819d90e) queued for radio transmission: CC:Configuration, CID:0x05
2026-02-10T22:44:09.893485549Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={parameter_number=106}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="j", src_channel=0, version=1}
2026-02-10T22:44:09.986296716Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> sending Z-Wave command: {args={grouping_identifier=1, node_ids={1}}, cmd_class="ASSOCIATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x01\x01", src_channel=0, version=1}
2026-02-10T22:44:09.993472508Z TRACE Inovelli mmWave Red Series  Z-Wave command(1c4624f8) queued for radio transmission: CC:Association, CID:0x01
2026-02-10T22:44:10.067761383Z DEBUG Inovelli mmWave Red Series  Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:44:10.075839924Z TRACE Inovelli mmWave Red Series  Z-Wave command(de0e1932) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:44:10.238529799Z TRACE Inovelli mmWave Red Series  Z-Wave command(4819d90e) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:44:10.410479341Z TRACE Inovelli mmWave Red Series  Z-Wave command(1c4624f8) transmit status: TRANSMIT_COMPLETE_OK
2026-02-10T22:44:10.480438424Z TRACE Inovelli mmWave Red Series  Received event with handler unnamed
2026-02-10T22:44:10.481701716Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={configuration_value=100, parameter_number=106, size=2}, cmd_class="CONFIGURATION", cmd_id="REPORT", dst_channels={}, encap="S2_AUTH", payload="\x6A\x02\x00\x64\x00\x00", src_channel=0, version=1}
2026-02-10T22:44:10.482988133Z TRACE Inovelli mmWave Red Series  Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:44:10.483740299Z DEBUG Inovelli mmWave Red Series  Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:44:32.262647510Z TRACE Inovelli mmWave Red Series  Received event with handler unnamed
2026-02-10T22:44:32.267213843Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={alarm_level=0, alarm_type=0, event="MOTION_DETECTION", event_parameter="", notification_status="ON", notification_type="HOME_SECURITY", v1_alarm_level=0, v1_alarm_type=0, z_wave_alarm_event=8, z_wave_alarm_status="ON", z_wave_alarm_type="BURGLAR", zensor_net_source_node_id=0}, cmd_class="NOTIFICATION", cmd_id="REPORT", dst_channels={}, encap="S2_AUTH", payload="\x00\x00\x00\xFF\x07\x08\x00", src_channel=0, version=3}
2026-02-10T22:44:32.296682177Z TRACE Inovelli mmWave Red Series  Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:44:32.311519635Z TRACE Inovelli mmWave Red Series  Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:44:32.317457302Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> emitting event: {"attribute_id":"motion","capability_id":"motionSensor","component_id":"main","state":{"value":"active"}}
2026-02-10T22:44:32.376206302Z DEBUG Inovelli mmWave Red Series  Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:44:32.965828302Z TRACE Inovelli mmWave Red Series  Received event with handler unnamed
2026-02-10T22:44:32.967651969Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={configuration_value=16777216, parameter_number=116, size=4}, cmd_class="CONFIGURATION", cmd_id="REPORT", dst_channels={0}, encap="S2_AUTH", payload="\x74\x04\x01\x00\x00\x00", src_channel=10, version=1}
2026-02-10T22:44:32.970215094Z TRACE Inovelli mmWave Red Series  Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:44:32.972487302Z DEBUG Inovelli mmWave Red Series  Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:44:33.494752344Z TRACE Inovelli mmWave Red Series  Received event with handler unnamed
2026-02-10T22:44:33.498742885Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={current_value=99, duration=0, target_value=99, value=99}, cmd_class="SWITCH_MULTILEVEL", cmd_id="REPORT", dst_channels={}, encap="S2_AUTH", payload="\x63\x63\x00", src_channel=0, version=4}
2026-02-10T22:44:33.501981969Z TRACE Inovelli mmWave Red Series  Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:44:33.504143510Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2026-02-10T22:44:33.515956177Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> emitting event: {"attribute_id":"level","capability_id":"switchLevel","component_id":"main","state":{"value":100}}
2026-02-10T22:44:33.528397552Z DEBUG Inovelli mmWave Red Series  Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:44:34.411258635Z TRACE Inovelli mmWave Red Series  Received event with handler unnamed
2026-02-10T22:44:34.416742510Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={precision=0, scale="LUX", sensor_type="LUMINANCE", sensor_value=61, size=4}, cmd_class="SENSOR_MULTILEVEL", cmd_id="REPORT", dst_channels={}, encap="S2_AUTH", payload="\x03\x0C\x00\x00\x00\x3D", src_channel=0, version=1}
2026-02-10T22:44:34.421432302Z TRACE Inovelli mmWave Red Series  Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:44:34.429518844Z TRACE Inovelli mmWave Red Series  Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:44:34.431677927Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> emitting event: {"attribute_id":"illuminance","capability_id":"illuminanceMeasurement","component_id":"main","state":{"unit":"lux","value":61}}
2026-02-10T22:44:34.443028927Z DEBUG Inovelli mmWave Red Series  Inovelli mmWave Dimmer Red Series 1 device thread event handled
2026-02-10T22:44:35.005518927Z TRACE Inovelli mmWave Red Series  Received event with handler unnamed
2026-02-10T22:44:35.009521969Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> received Z-Wave command: {args={delta_time=1642, meter_type="ELECTRIC_METER", meter_value=15.56, precision=2, previous_meter_value=0.0, rate_type="IMPORT", scale="WATTS", size=4}, cmd_class="METER", cmd_id="REPORT", dst_channels={}, encap="S2_AUTH", payload="\x21\x54\x00\x00\x06\x14\x06\x6A\x00\x00\x00\x00", src_channel=0, version=3}
2026-02-10T22:44:35.013482302Z TRACE Inovelli mmWave Red Series  Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:44:35.017946677Z TRACE Inovelli mmWave Red Series  Found ZwaveDispatcher handler in zwave_switch
2026-02-10T22:44:35.020203094Z INFO Inovelli mmWave Red Series  <ZwaveDevice: 0fa89eb6-6a71-44b1-b8bf-75c893194489 [2D] (Inovelli mmWave Dimmer Red Series 1)> emitting event: {"attribute_id":"power","capability_id":"powerMeter","component_id":"main","state":{"unit":"W","value":15.56}}
2026-02-10T22:44:35.032056552Z DEBUG Inovelli mmWave Red Series  Inovelli mmWave Dimmer Red Series 1 device thread event handled
Here is what the logs say was sent vs what was reported:
Parameter Size SET Value REPORT Value Match
101 2 0 0 :white_check_mark:
102 2 300 300 :white_check_mark:
103 2 300 300 :white_check_mark:
104 2 0 0 :white_check_mark:
105 2 5 5 :white_check_mark:
106 2 100 100 :white_check_mark:
I find interesting the values of 103 and 104. I think there might be an issue where it is expecting the lower value in 103. Are these the values you intended?
If so can you reverse those two numbers and try the process again?
So set 103 to 0 and 104 to 300. You are trying to capture the right side of the room right? To about 100cm Infront of the switch?
Also, I recommend 101 and 102 be -100 and 100 as I find that captures a good portion of the room where people are without having false positives for some fans or floors below or above.
Is there an angle that mmWave cannot see? I am almost 0 distance with 300 meter to the right of switch and switch cannot sense my presence.
