Apologies, I am new to these forums so I don’t know how to properly tag my posts, but this is for:
VZW30-SN Red Series On/Off switch with Humidity sensing
I use Homeassistant and Zwave JS UI
I am in the US on 120v/60hz electricity
What is the latest firmware for the red series On/off switch? I can’t find the firmware on the GitHub repository or the inovelli firmware websites.
I have had issues where I have successfully installed and included the switches to my Home Assistant instantiation through Zwave JS UI. At first, the switch seems to be working normally and I can turn it on using the physical buttons or homeassistant, but then the physical buttons stop working and the LED bar turns off after the first time.
The Zwave radio is still responding since the switches show as alive and respond to pings. When I try re-interviewing the node, it drops the information it knows about the switch like the manufacturer. I want to try doing an OTA update to the latest stable firmware, but I can’t find it.
I have had similar variations of this issue now on a couple of these switches. For context, I’m trying to install in a bathroom with a broan fan that was installed cerca 2018. I have checked the wiring and the voltages several times and that doesn’t seem to be the problem.
I did notice that on this last switch, parameter 33 did show an “overheat fault” for a bit and then the physical buttons stopped working, but I don’t understand what is happening. The switch itself had just been turned on and wasn’t warm to the touch. I tried turning off the breaker for a few minutes and then refreshed the parameter and it claimed the overheat was cleared, but the physical buttons and led never came back online.
I’m out of ideas on what might be causing this unless somehow that Broan residential bathroom fan is somehow putting too much of an inductive load on the switch at start-up. That being said, it looks like the broan fans usually do not exceed 4-5amps of inductive load at start-up and are usually at .9amp so it seems like this shouldn’t pose a problem for this switch.
Any ideas or suggestions for what is happening and how/if it can be fixed would be greatly appreciated.
Hi @csd132, this sounds similar to a problem that we saw on the release of the VTM30 (matter on/off) that was resolved by optimizing the shut off timing in the firmware. The same optimization was put into the VZW30 but since the MCU is different maybe there needs to be another adjustment made. We didn’t see it occur in our beta testing, but now that the load types will be more diverse (many more users), it is possible that we might see it. I see that you have a Broan residential bathroom fan, but can you provide the model number?
Thanks, @EricM_Inovelli! I appreciate any insights and advice on this issue. I’m glad to hear you might have some ideas on what is happening. It’s a Broan 688-K. When I was researching it a bit, a lot of the articles said that they are electrically messy and that I might want to look into an RC Snubber but I’m curious on your thoughts if that would help or not to isolate the start-up/shut down induction or not.
As always, I really appreciate everything the Inovelli team is doing and I love your products!
3 of my 5-pack bathroom fan switches died when I tried to set this up this weekend.
Similar pattern as what you mentioned csd132 - it works until the first time you turn it off, then it never works again. Just a normal ‘contractor grade’ fan that was preinstalled when we bought the house year ago - nothing modern/quiet/fancy.
Home Assistant’s chart of the ‘overheat detected’ is always ‘false’ and the ‘internal temperature’ was always 27C for the entire time that the switch was installed. The ‘electric consumption [W]’ was 60 watts for the period that the fan ran.
@DonP , I’ll wait for @EricM_Inovelli to confirm, but the more I have looked into it, I think it’s the inductive load from the brush motor on the fan is frying the MCU. I found the beta firmware and when I attempted to upload it to the switch, it kept failing. This makes me think that the MCU is dead, but the Zwave radio which is a different chip is still working.
So far, the on/off switch seems to be working. The inductance didn’t fry the switch’s MCU so far with the RC Snubber in the loop and the humidity and temperature sensor are continuing to report values. I’ll keep monitoring it to see if everything remains ok, but it’s now been 2 days with no further issues.
in some of the other bathrooms, I’m going to upgrade to a slightly better fan kit such as the broan BKR60 so that it has lower chances of having issues. I’ll still likely install the RC Snubber circuit in parallel with it anyway just to make sure.
@DonP can you get the manufacturer and model of your fan? Just to confirm, the switch will get stuck when turning off (but the LED bar will stay on), and will not respond to physical button presses? It can still be controlled via Z-Wave though but the LED bar always stays on? Rebooting with the air gap will fix it until the process is done again?
Or is it something similar to this but somewhat different?
I can try to take it out of the ceiling this weekend. I see NuTone on the bezel.
the switches completely die. The second I turn the fan off for the first time, the light bar dies, the switch no longer responds to local or remote control, and the transmitter goes in to a weird state where Home Assistant says it is alive and it updates the “last seen” timer, and the temperature / humidity charts claim they work but they actually are just stuck resending the last value sent before the switch broke.
I’ve disconnected power and flipped the air gap multiple times, it stays dead
@csd132@DonP this sounds different than what we have seen with other switches. You are saying after the switch enters this state you cannot recover it even after an airgap reboot or a circuit breaker reboot? Could you test with the load disconnected to see if in that state the relay clicks on / off? If it is not recoverable I will PM you because I would like to inspect the state the switch is in.
Correct, the switches are all effectively dead after the first time I turn the fan off.
Load disconnected, only power: no lights, no relay sounds
Power disconnected and then reconnected: no lights, no relay sounds, no fan activation
Air gap pulled, power disconnected, reconnected, air gap pressed: no lights, no relay sounds, no fan activation
Home Assistant state:
‘Last seen’ seems to update every hour or so
‘Node status’ is set to ‘alive’
‘Air temperature’ and ‘Humidity’ seem to occasionally be sent but it is not a real value, it is the last value that was ‘real’ at the time the switch died on Sunday.
I have a similar experience to DonP. Removing the load, pulling and reseating the airgap, and resetting the breaker doesn’t change anything. The LED is dead and the relay doesn’t appear to be alive/engaging. Effectively, the Zwave Chip is still on so there is some limited reporting, but using Zwave commands or the physical switch don’t work and firmware updates fail.
@EricM_Inovelli Has there been any updates to this issue. I also have a switch that became unresponsive after being connected to a nutone bathroom fan? This switch replaced an old LZW30 which has been working well with this fan for years.
I just installed one of these (Z-Wave On/off switch, VZW30-SN) and barring some general Z-Wave routing issues (which are probably not the fault of the hardware, but of the distance to controller and antenna placement), things seem to be working well.
The major inconvenience which does seems to be from the switch itself, is that while the switch is a pure-switch (no dimming) it seems to advertise itself over Z-wave as if it is a dimmer.
For example, In home assistant, this switch appears as if it’s a dimmer, allowing me to adjust the dim level, and looking directly in Z-Wave JS UI, it has a “Multilevel Switch v4” command class which lets me see specific dim levels (“current value”) as well as target dim level (“target value”) (and it accepts these values and then says it is at that dim level). Additionally, it has a wide variety of configuration parameters which are clearly for dimmers (e.g., dimming speed, ramp rate, double up level, double down level, dimmer mode).
Can the firmware be updated to make this switch make it clear it is in fact a switch? It’s definitely confusing to wade through a sea of configuration parameters that don’t do anything at all, as well as it seeming like the switch respects set dim levels, even though it does not.
Thank you very much, and I hope to see these switches improved ever better!
While I don’t have this one, I do have the Blue version (VZM31-SN)…
It can work as a dimmer for bound/associated devices, just not for loads directly controlled by it, so it needs the capability in the firmware. I (and I am assuming others) use this functionality and would likely be very disappointed and upset if it were to be removed.
Unfortunately, we have not been able to dial in a firmware update to resolve the issue. It is still possible if we can get the timing of the shutoff process in-sync with these types of fans. We do this with our white and blue series and are pretty successful but haven’t been able to with the red series. We do have a hardware solution that we are testing. I will PM you with the details and we can go from there.
