Fan/Light Switch Disconnection Issue Thread
Single gang, plastic box.
Single gang box, Fiberglass (from the 70’s)
I used to do RF engineering, and I know the 2.4ghz band is VERY noisy here. Noise floor is -85db average with signals up to -50dbm. I have 25+ wifi APs, and I have zigbee also. I can not use 2.4ghz for any real 802.11 throughput, and I get wireless drops if I use anything with a poor radio/receiver like a ESP8266, even with running high power directional antennas.
Switch is in a two-gang box, next to a red series dimmer.
Plastic box for the switch. Ceiling box is metal.
I’d tried a few times cutting off power to just the switch (they are on separate circuits), just the light, and both at the same time. None seemed to help restore the connection. It was interesting too, yesterday I tried putting the switch into module inclusion mode after turning the power back on (to both) and it flashed green for successful connection but still no response from the light/fan. Z-wave connection has remained throughout.
I do have another Fan/Light switch installed that has had no issue in a three-gang plastic box (next to two red series switches.) I thought that switch was going to be pushing the limit of the module range as the ceiling fan is mounted at the top of a ~20ft vaulted ceiling.
Date purchased - 4/27/2020.
Internal temperature - 65 to 75.
I use a smartings hub.
We have two switches installed in two fans in a 20 * 30 room.
The switches are about 12 to 15 ft away from the fan.
Current issues - the fans and lights completely stop working. Before moving these to these switches, they would atleast work when Triggered manually. Now nothing works.
And then magically, things start working some days - it’s been a bit of a lottery. Would love to understand more.
I have basically installed inovelli switches everywhere in the house. This has been my first sub optimal experience.
Just some questions:
  1. Does the antenna of the module need to be outside of the canopy of the fan in order to work? I don’t believe it was ever outside of the canopy when it was initially installed. Additionally, when troubleshooting the first time, I had the fan off the canopy bracket with the module exposed and the switch turned the light on/off with no issues.
  2. Shouldn’t the physical switch still turn the fan/fan light on/off even if I cannot control the fan through the Smartthings app?
  • Date switch was purchased
    • 01/23/2021
  • Approximate distance from switch to fan canopy
    • ~10ft
  • Approximate internal temperature (in house) and external temperature (outside)
    • Installed April 2021. Internal: 70-75F. External: 30s (April) 80-100F (June)
  • What is your hub/gateway (ie: SmartThings, Hubitat, etc)?
    • Smartthings
  • What firmware version are you on (if you don’t know, leave blank, but it’s helpful)?
    • 1.34
  • Have you made any parameter changes?
    • No
  • Approximate wattage of your bulbs
    • 18 watt LED
  • Does the disconnection happen when using the fan, the light or both?
    • Disconnection is random. Sometimes the fan works after pushing the physical button a few times. Light is also random. When fan won’t turn off, my last resort is to flip the circuit breaker
  • Do you notice any patterns (ie: time of day, time since last disconnection, etc)?
    • Have not noticed any patterns. This is a recent problem as of 6/20/21
    • 2021-01-19
    • installed 2021-02-22
    • 20’, but it’s not quite line of sight because there’s the edge of a door frame in the way. also, I have plaster walls.
    • internal 70-74, though it gets hotter up near the ceiling (hence the need for a fan). I’ve measured the canopy at 90 degrees on a record hot day when the fan isn’t running.
    • external 20-100. the problem has gotten worse as we’ve gone into spring/summer, but I don’t feel it is correlated to temperature.
    • SmartThings
    • 1.34
    • dimming speed = 1. I think I made this change after the problems began.
    • 20W LED
    • both. it seems to be all or nothing; I’ve never seen one work and the other fail. Normally it disconnects during a days-long period of inactivity. The only time I ever “witnessed” the disconnection was the very last time it ever worked: I was able to turn the fan on and couldn’t turn it back off again. I had to power-cycle the circuit to turn it off.
    • The switch worked flawlessly for months, then it became less and less reliable. When the problems first manifested, rebooting via the air gap would fix it temporarily (usually the rest of the day). Now it doesn’t work at all, and the air gap trick is no help. I also tried re-pairing with the canopy module and it fails (LEDs blink red and fan light keeps pulsing). I haven’t seen any pattern except a steady deterioration.
  • previous circuit
    • the fan previously had a different brand of wireless controller (a handheld remote). the canopy module looked almost identical to the Inovelli one. the previous controller was subject to random activations, I think because my neighbor has a similar model, which is the main reason I replaced it. I haven’t had a random activation since, but I haven’t had enough intentional ones either!
  • box
    • the switch is in a plastic 3-gang box, of which only the two end gangs are populated.
I posted slightly different info in the old thread before someone helpfully pointed me here.
Interesting adder. Last night I was trying to turn on and off the fan. Wouldn’t budge. I did it 3-4 cyctes and nothing.
So I tried the LEVEL setting, changing it from off to breeze mode, and it worked FIRST time. Then on/off worked reliably after that.
Just another data point!
Another data point:
Today I commanded the switch via z-wave to turn on, it would not for light or fan. The LED did change levels depending on what I set. Once I pressed the power button a couple of times, then it actually responded.
Just responding to say that I’ve read these – very helpful and we’re working on it. @EricM_Inovelli actually has a buggy fan/light switch at his house that he’s working with the engineers as well to debug.
For what it’s worth, I was having the same issue with the canopy not responding all of a sudden (neither fan nor light), even after flipping the breaker several times. I upgraded the firmware to 1.36 (I don’t know what it was before) and it started working again but I couldn’t tell you why.
Similar experience last night. Commanded via Alexa to set Living Room Fan to Medium.
The switch reacted, but the canopy unit did not turn on.
Commanded A to set to Low, switch reacted, canopy did nothing.
Walked over and pushed the “level up” button on the fan, and it IMMEDIATELY responded and set to Medium (since it had increased from Low per my button press).
Finnicky… but glad to hear they are on it.
Also, while @EricM_Inovelli is troubleshooting, could you also work with the software engineer to resolve the bug indicated here:
https://github.com/zwave-js/node-zwave-js/issues/2159
Temp fix here:
https://github.com/zwave-js/node-zwave-js/pull/2167
@blhoward2 knows way more about this than I do. Essentially the Supervision CC isn’t being closed out by the switch.
Date switch was purchased: June 14th
Approximate distance from switch to fan canopy: 5 feet
Approximate internal temperature (in house) and external: 72
temperature (outside): 80
What is your hub/gateway (ie: SmartThings, Hubitat, etc)?: Homeseer (although I haven’t ever paired this to it)
Have you made any parameter changes? No
Approximate wattage of your bulbs: LED bulbs at about 7W
Does the disconnection happen when using the fan, the light or both? Was disconnected from the day I hooked it up.
Do you notice any patterns (ie: time of day, time since last disconnection, etc)? None to note
New experience last night, made sure to log.
Commanded fan via switch press, no result, LED bar went to medium.
Commanded fan low via side switch, no result, LED bar went to low.
Commanded light on, no result, LED bar went to 100%.
Commanded light off, no result (already off), LED bar went to 0%.
Commanded light on via level up, LIGHT TURNED ON to 1%, and the switch started working for all commands after (turned fan on to medium, light up to 100%, etc.).
One 1-gang box, the other is a 2-gang box. Both have issues. The one with the 1-gang box is our bedroom so I notice the issues there more often.
Both are plastic.
It’s been a few days now, and I have to say the switch is behaving worse than before I updated (from 1.31). It fails to respond more frequently.
An update on my previous post: my switch has mysteriously started working again, just as mysteriously as it stopped. I tried turning the light on randomly about a week ago and it worked. I tried both light and fan again just now and it worked. I will continue to monitor it. I’m not aware of anything that has changed with the switch, my wifi network, or anything else in my house. It has been cooler and rainy lately.
My 2nd (of 2) fan switch has stopped working… more or less the same stats as my first from post #15 above.
EDIT: …and now 1/2, the one I posted about in post #15 above, is working. Light, fan, light dimming, fan speed, all work. I’ve made zero hardware changes since my original post in his thread. I’ve upgraded HA core and ZwaveJS to MQTT a few times. I’ve made no firmware changes to anything.
@rmeador - my first of two switches ‘randomly’ started working around the same time as yours did. Are you on HA? Did you upgrade to core 2021.7.1 today? I can’t think of anything else to ask that would explain two switches suddenly beginning to work at the same time in two separate networks.
@EricM_Inovelli – can you let people know what you did to fix yours step by step? I think you mentioned you tried a few times to reset the connection, right? Sorry, I would post it, but I honestly can’t remember what you did.
Just an update, the samples we sent to the manufacturer are finally through customs, so we should be getting some sort of preliminary report this week or early next. We have a call with them tomorrow.
Jun 26, 2020 from inovelli.com
14’
inside 22d C
outside 30d C
Home Assistant
1.31
Instant on, ramp rate, etc. Full current settings below.
4 x 8.5w (plus Aeotec Bypass)
It’s currently disconnected, not sure how/when
No pattern noticed, just not responding and can’t reconnect
Here’s my full node settings exported from Home Assistant/Z-Wave JS:
  "id": 32,
  "name": "Fan_Stairs",
  "loc": "Main_floor",
  "values": [
      "id": "32-38-0-targetValue",
      "nodeId": 32,
      "commandClass": 38,
      "commandClassName": "Multilevel Switch",
      "endpoint": 0,
      "property": "targetValue",
      "propertyName": "targetValue",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Target value",
      "stateless": false,
      "min": 0,
      "max": 99,
      "list": false,
      "value": 1,
      "lastUpdate": 1625963090162,
      "newValue": 1
      "id": "32-38-0-duration",
      "nodeId": 32,
      "commandClass": 38,
      "endpoint": 0,
      "property": "duration",
      "propertyName": "duration",
      "type": "duration",
      "readable": true,
      "writeable": true,
      "label": "Transition duration",
      "stateless": false,
      "list": false,
      "value": {
        "value": 0,
        "unit": "seconds"
      "lastUpdate": 1625963090164,
      "newValue": {
        "value": 0,
        "unit": "seconds"
      "id": "32-38-0-currentValue",
      "nodeId": 32,
      "commandClass": 38,
      "endpoint": 0,
      "property": "currentValue",
      "propertyName": "currentValue",
      "type": "number",
      "readable": true,
      "writeable": false,
      "label": "Current value",
      "stateless": false,
      "min": 0,
      "max": 99,
      "list": false,
      "value": 70,
      "isCurrentValue": true,
      "targetValue": "38-0-targetValue",
      "lastUpdate": 1626237872074,
      "newValue": 70
      "id": "32-38-0-Up",
      "nodeId": 32,
      "commandClass": 38,
      "endpoint": 0,
      "property": "Up",
      "propertyName": "Up",
      "type": "boolean",
      "readable": true,
      "writeable": true,
      "label": "Perform a level change (Up)",
      "ccSpecific": {
        "switchType": 2
      "stateless": false,
      "list": false,
      "lastUpdate": 1625963090250
      "id": "32-38-0-Down",
      "nodeId": 32,
      "commandClass": 38,
      "endpoint": 0,
      "property": "Down",
      "propertyName": "Down",
      "type": "boolean",
      "readable": true,
      "writeable": true,
      "label": "Perform a level change (Down)",
      "ccSpecific": {
        "switchType": 2
      "stateless": false,
      "list": false,
      "lastUpdate": 1625963090255
      "id": "32-50-0-value-65537",
      "nodeId": 32,
      "commandClass": 50,
      "commandClassName": "Meter",
      "endpoint": 0,
      "property": "value",
      "propertyName": "value",
      "propertyKey": 65537,
      "propertyKeyName": "Electric_kWh_Consumed",
      "type": "number",
      "readable": true,
      "writeable": false,
      "label": "Electric Consumed [kWh]",
      "ccSpecific": {
        "meterType": 1,
        "rateType": 1,
        "scale": 0
      "stateless": false,
      "unit": "kWh",
      "list": false,
      "value": 12.471,
      "lastUpdate": 1625963090258,
      "newValue": 12.471
      "id": "32-50-0-deltaTime-65537",
      "nodeId": 32,
      "commandClass": 50,
      "endpoint": 0,
      "property": "deltaTime",
      "propertyName": "deltaTime",
      "propertyKeyName": "65537",
      "type": "number",
      "readable": true,
      "writeable": false,
      "label": "Electric Consumed [kWh] (prev. time delta)",
      "ccSpecific": {
        "meterType": 1,
        "rateType": 1,
        "scale": 0
      "stateless": false,
      "unit": "s",
      "list": false,
      "value": 0,
      "lastUpdate": 1625963090261,
      "newValue": 0
      "id": "32-50-0-value-66049",
      "nodeId": 32,
      "commandClass": 50,
      "endpoint": 0,
      "propertyKey": 66049,
      "propertyKeyName": "Electric_W_Consumed",
      "type": "number",
      "readable": true,
      "writeable": false,
      "label": "Electric Consumed [W]",
      "ccSpecific": {
        "meterType": 1,
        "rateType": 1,
        "scale": 2
      "stateless": false,
      "unit": "W",
      "list": false,
      "value": 98.2,
      "lastUpdate": 1625963090262,
      "newValue": 98.2
      "id": "32-50-0-deltaTime-66049",
      "nodeId": 32,
      "commandClass": 50,
      "endpoint": 0,
      "propertyKeyName": "66049",
      "type": "number",
      "readable": true,
      "writeable": false,
      "label": "Electric Consumed [W] (prev. time delta)",
      "ccSpecific": {
        "meterType": 1,
        "rateType": 1,
        "scale": 2
      "stateless": false,
      "unit": "s",
      "list": false,
      "value": 0,
      "lastUpdate": 1625963090266,
      "newValue": 0
      "id": "32-50-0-reset",
      "nodeId": 32,
      "commandClass": 50,
      "endpoint": 0,
      "property": "reset",
      "propertyName": "reset",
      "type": "boolean",
      "readable": false,
      "writeable": true,
      "label": "Reset accumulated values",
      "stateless": false,
      "list": false,
      "lastUpdate": 1625963090268
      "id": "32-50-0-previousValue-65537",
      "nodeId": 32,
      "commandClass": 50,
      "endpoint": 0,
      "property": "previousValue",
      "propertyName": "previousValue",
      "type": "number",
      "readable": true,
      "writeable": false,
      "label": "Electric Consumed [kWh] (prev. value)",
      "ccSpecific": {
        "meterType": 1,
        "rateType": 1,
        "scale": 0
      "stateless": false,
      "unit": "kWh",
      "list": false,
      "lastUpdate": 1625963090271
      "id": "32-50-0-previousValue-66049",
      "nodeId": 32,
      "commandClass": 50,
      "endpoint": 0,
      "type": "number",
      "readable": true,
      "writeable": false,
      "label": "Electric Consumed [W] (prev. value)",
      "ccSpecific": {
        "meterType": 1,
        "rateType": 1,
        "scale": 2
      "stateless": false,
      "unit": "W",
      "list": false,
      "lastUpdate": 1625963090275
      "id": "32-91-0-slowRefresh",
      "nodeId": 32,
      "commandClass": 91,
      "commandClassName": "Central Scene",
      "endpoint": 0,
      "property": "slowRefresh",
      "propertyName": "slowRefresh",
      "type": "boolean",
      "readable": true,
      "writeable": true,
      "description": "When this is true, KeyHeldDown notifications are sent every 55s. When this is false, the notifications are sent every 200ms.",
      "label": "Send held down notifications at a slow rate",
      "stateless": false,
      "list": false,
      "value": true,
      "lastUpdate": 1625963090277,
      "newValue": true
      "id": "32-91-0-scene-001",
      "nodeId": 32,
      "commandClass": 91,
      "endpoint": 0,
      "property": "scene",
      "propertyName": "scene",
      "propertyKey": "001",
      "propertyKeyName": "001",
      "type": "number",
      "readable": true,
      "writeable": false,
      "label": "Scene 001",
      "stateless": true,
      "min": 0,
      "max": 255,
      "list": true,
      "states": [
          "text": "KeyPressed",
          "value": 0
          "text": "KeyReleased",
          "value": 1
          "text": "KeyHeldDown",
          "value": 2
          "text": "KeyPressed2x",
          "value": 3
          "text": "KeyPressed3x",
          "value": 4
          "text": "KeyPressed4x",
          "value": 5
          "text": "KeyPressed5x",
          "value": 6
      "lastUpdate": 1626237725284
      "id": "32-91-0-scene-002",
      "nodeId": 32,
      "commandClass": 91,
      "endpoint": 0,
      "propertyKey": "002",
      "propertyKeyName": "002",
      "type": "number",
      "readable": true,
      "writeable": false,
      "label": "Scene 002",
      "stateless": true,
      "min": 0,
      "max": 255,
      "list": true,
      "states": [
          "value": 0
          "value": 1
          "value": 2
          "value": 3
          "value": 4
          "value": 5
          "value": 6
      "lastUpdate": 1626237720672
      "id": "32-91-0-scene-003",
      "nodeId": 32,
      "commandClass": 91,
      "endpoint": 0,
      "propertyKey": "003",
      "propertyKeyName": "003",
      "type": "number",
      "readable": true,
      "writeable": false,
      "label": "Scene 003",
      "stateless": true,
      "min": 0,
      "max": 255,
      "list": true,
      "states": [
          "value": 0
      "lastUpdate": 1626019846460
      "id": "32-91-0-scene-004",
      "nodeId": 32,
      "commandClass": 91,
      "endpoint": 0,
      "propertyKey": "004",
      "propertyKeyName": "004",
      "type": "number",
      "readable": true,
      "writeable": false,
      "label": "Scene 004",
      "stateless": false,
      "min": 0,
      "max": 255,
      "list": true,
      "states": [
          "value": 0
      "lastUpdate": 1625963090290
      "id": "32-91-0-scene-005",
      "nodeId": 32,
      "commandClass": 91,
      "endpoint": 0,
      "propertyKey": "005",
      "propertyKeyName": "005",
      "type": "number",
      "readable": true,
      "writeable": false,
      "label": "Scene 005",
      "stateless": true,
      "min": 0,
      "max": 255,
      "list": true,
      "states": [
          "value": 0
      "lastUpdate": 1625963935348
      "id": "32-91-0-scene-006",
      "nodeId": 32,
      "commandClass": 91,
      "endpoint": 0,
      "propertyKey": "006",
      "propertyKeyName": "006",
      "type": "number",
      "readable": true,
      "writeable": false,
      "label": "Scene 006",
      "stateless": false,
      "min": 0,
      "max": 255,
      "list": true,
      "states": [
          "value": 0
      "lastUpdate": 1625963090294
      "id": "32-112-0-1",
      "nodeId": 32,
      "commandClass": 112,
      "commandClassName": "Configuration",
      "endpoint": 0,
      "property": 1,
      "propertyName": "Light Dimming Speed (Z-Wave)",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Light Dimming Speed (Z-Wave)",
      "default": 4,
      "stateless": false,
      "min": 0,
      "max": 98,
      "list": true,
      "allowManualEntry": true,
      "states": [
          "text": "Immediate",
          "value": 0
      "value": 0,
      "lastUpdate": 1625963090297,
      "newValue": 0
      "id": "32-112-0-2",
      "nodeId": 32,
      "endpoint": 0,
      "property": 2,
      "propertyName": "Light Dimming Speed",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Light Dimming Speed",
      "default": 99,
      "stateless": false,
      "min": 0,
      "max": 99,
      "list": true,
      "states": [
          "value": 0
          "text": "Synced with Parameter 1",
          "value": 99
      "value": 0,
      "lastUpdate": 1625963090300,
      "newValue": 0
      "id": "32-112-0-3",
      "nodeId": 32,
      "endpoint": 0,
      "property": 3,
      "propertyName": "Light Ramp Rate (Z-Wave)",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Light Ramp Rate (Z-Wave)",
      "default": 99,
      "stateless": false,
      "min": 0,
      "max": 99,
      "list": true,
      "states": [
          "value": 0
          "value": 99
      "value": 0,
      "lastUpdate": 1625963090303,
      "newValue": 0
      "id": "32-112-0-4",
      "nodeId": 32,
      "endpoint": 0,
      "property": 4,
      "propertyName": "Light Ramp Rate",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Light Ramp Rate",
      "default": 99,
      "stateless": false,
      "min": 0,
      "max": 99,
      "list": true,
      "states": [
          "value": 0
          "value": 99
      "value": 0,
      "lastUpdate": 1625963090309,
      "newValue": 0
      "id": "32-112-0-5",
      "nodeId": 32,
      "endpoint": 0,
      "property": 5,
      "propertyName": "Minimum Light Level",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Minimum Light Level",
      "default": 1,
      "stateless": false,
      "min": 1,
      "max": 45,
      "list": false,
      "value": 20,
      "lastUpdate": 1625963090313,
      "newValue": 20
      "id": "32-112-0-6",
      "nodeId": 32,
      "endpoint": 0,
      "property": 6,
      "propertyName": "Maximum Light Level",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Maximum Light Level",
      "default": 99,
      "stateless": false,
      "min": 55,
      "max": 99,
      "list": false,
      "value": 70,
      "lastUpdate": 1625963090314,
      "newValue": 70
      "id": "32-112-0-7",
      "nodeId": 32,
      "endpoint": 0,
      "property": 7,
      "propertyName": "Minimum Fan Level",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Minimum Fan Level",
      "default": 1,
      "stateless": false,
      "min": 1,
      "max": 45,
      "list": false,
      "value": 1,
      "lastUpdate": 1625963090318,
      "newValue": 1
      "id": "32-112-0-8",
      "nodeId": 32,
      "endpoint": 0,
      "property": 8,
      "propertyName": "Maximum Fan Level",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Maximum Fan Level",
      "default": 99,
      "stateless": false,
      "min": 55,
      "max": 99,
      "list": false,
      "value": 99,
      "lastUpdate": 1625963090320,
      "newValue": 99
      "id": "32-112-0-10",
      "nodeId": 32,
      "endpoint": 0,
      "property": 10,
      "propertyName": "Auto Off Light Timer",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Auto Off Light Timer",
      "default": 0,
      "stateless": false,
      "min": 0,
      "max": 32767,
      "unit": "seconds",
      "list": false,
      "value": 0,
      "lastUpdate": 1625963090326,
      "newValue": 0
      "id": "32-112-0-11",
      "nodeId": 32,
      "endpoint": 0,
      "property": 11,
      "propertyName": "Auto Off Fan Timer",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Auto Off Fan Timer",
      "default": 0,
      "stateless": false,
      "min": 0,
      "max": 32767,
      "list": false,
      "value": 0,
      "lastUpdate": 1625963090330,
      "newValue": 0
      "id": "32-112-0-12",
      "nodeId": 32,
      "endpoint": 0,
      "property": 12,
      "propertyName": "Default Light Level",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Default Light Level",
      "default": 0,
      "stateless": false,
      "min": 0,
      "max": 99,
      "list": true,
      "states": [
          "text": "Last State",
          "value": 0
      "value": 0,
      "lastUpdate": 1625963090335,
      "newValue": 0
      "id": "32-112-0-13",
      "nodeId": 32,
      "endpoint": 0,
      "property": 13,
      "propertyName": "Default Light Level (Z-Wave)",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Default Light Level (Z-Wave)",
      "default": 0,
      "stateless": false,
      "min": 0,
      "max": 99,
      "list": true,
      "states": [
          "value": 0
      "value": 0,
      "lastUpdate": 1625963090336,
      "newValue": 0
      "id": "32-112-0-14",
      "nodeId": 32,
      "endpoint": 0,
      "property": 14,
      "propertyName": "Default Fan Speed",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Default Fan Speed",
      "default": 0,
      "stateless": false,
      "min": 0,
      "max": 99,
      "list": true,
      "allowManualEntry": false,
      "states": [
          "value": 0
          "text": "Low",
          "value": 33
          "text": "Medium",
          "value": 66
          "text": "High",
          "value": 99
      "value": 0,
      "lastUpdate": 1625963090338,
      "newValue": 0
      "id": "32-112-0-15",
      "nodeId": 32,
      "endpoint": 0,
      "property": 15,
      "propertyName": "Default Fan Speed (Z-Wave)",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Default Fan Speed (Z-Wave)",
      "default": 0,
      "stateless": false,
      "min": 0,
      "max": 99,
      "list": true,
      "states": [
          "value": 0
          "text": "Low",
          "value": 33
          "text": "Medium",
          "value": 66
          "text": "High",
          "value": 99
      "value": 0,
      "lastUpdate": 1625963090340,
      "newValue": 0
      "id": "32-112-0-16",
      "nodeId": 32,
      "endpoint": 0,
      "property": 16,
      "propertyName": "Light Brightness After Power Restored",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Light Brightness After Power Restored",
      "default": 0,
      "stateless": false,
      "min": 0,
      "max": 100,
      "list": true,
      "states": [
          "text": "Off",
          "value": 0
          "value": 100
      "value": 100,
      "lastUpdate": 1625963090343,
      "newValue": 100
      "id": "32-112-0-17",
      "nodeId": 32,
      "endpoint": 0,
      "property": 17,
      "propertyName": "Fan Speed After Power Restored",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Fan Speed After Power Restored",
      "default": 0,
      "stateless": false,
      "min": 0,
      "max": 100,
      "list": true,
      "states": [
          "text": "Off",
          "value": 0
          "text": "Low",
          "value": 33
          "text": "Medium",
          "value": 66
          "text": "High",
          "value": 99
          "value": 100
      "value": 0,
      "lastUpdate": 1625963090345,
      "newValue": 0
      "id": "32-112-0-18",
      "nodeId": 32,
      "endpoint": 0,
      "property": 18,
      "propertyName": "Light LED Indicator Color",
      "type": "number",
      "readable": true,
      "writeable": true,
      "description": "Uses a scaled hue value (realHue / 360 * 255).",
      "label": "Light LED Indicator Color",
      "default": 170,
      "stateless": false,
      "min": 0,
      "max": 255,
      "list": true,
      "states": [
          "text": "Red",
          "value": 0
          "text": "Orange",
          "value": 21
          "text": "Yellow",
          "value": 42
          "text": "Green",
          "value": 85
          "text": "Cyan",
          "value": 127
          "text": "Blue",
          "value": 170
          "text": "Violet",
          "value": 212
          "text": "Pink",
          "value": 234
      "value": 170,
      "lastUpdate": 1625963090351,
      "newValue": 170
      "id": "32-112-0-19",
      "nodeId": 32,
      "endpoint": 0,
      "property": 19,
      "propertyName": "Light LED Strip Brightness",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Light LED Strip Brightness",
      "default": 5,
      "stateless": false,
      "min": 0,
      "max": 10,
      "list": true,
      "states": [
          "text": "Off",
          "value": 0
          "text": "10%",
          "value": 1
          "text": "20%",
          "value": 2
          "text": "30%",
          "value": 3
          "text": "40%",
          "value": 4
          "text": "50%",
          "value": 5
          "text": "60%",
          "value": 6
          "text": "70%",
          "value": 7
          "text": "80%",
          "value": 8
          "text": "90%",
          "value": 9
          "text": "100%",
          "value": 10
      "value": 5,
      "lastUpdate": 1625963090354,
      "newValue": 5
      "id": "32-112-0-20",
      "nodeId": 32,
      "endpoint": 0,
      "property": 20,
      "propertyName": "Fan LED Indicator Color",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Fan LED Indicator Color",
      "default": 170,
      "stateless": false,
      "min": 0,
      "max": 255,
      "list": true,
      "states": [
          "text": "Red",
          "value": 0
          "text": "Orange",
          "value": 21
          "text": "Yellow",
          "value": 42
          "text": "Green",
          "value": 85
          "text": "Cyan",
          "value": 127
          "text": "Blue",
          "value": 170
          "text": "Violet",
          "value": 212
          "text": "Pink",
          "value": 234
      "value": 170,
      "lastUpdate": 1625963090357,
      "newValue": 170
      "id": "32-112-0-21",
      "nodeId": 32,
      "endpoint": 0,
      "property": 21,
      "propertyName": "Fan LED Strip Brightness",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Fan LED Strip Brightness",
      "default": 5,
      "stateless": false,
      "min": 0,
      "max": 10,
      "list": true,
      "states": [
          "text": "Off",
          "value": 0
          "text": "10%",
          "value": 1
          "text": "20%",
          "value": 2
          "text": "30%",
          "value": 3
          "text": "40%",
          "value": 4
          "text": "50%",
          "value": 5
          "text": "60%",
          "value": 6
          "text": "70%",
          "value": 7
          "text": "80%",
          "value": 8
          "text": "90%",
          "value": 9
          "text": "100%",
          "value": 10
      "value": 5,
      "lastUpdate": 1625963090359,
      "newValue": 5
      "id": "32-112-0-22",
      "nodeId": 32,
      "endpoint": 0,
      "property": 22,
      "propertyName": "Light LED Strip Brightness When Off",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Light LED Strip Brightness When Off",
      "default": 1,
      "stateless": false,
      "min": 0,
      "max": 10,
      "list": true,
      "states": [
          "text": "Off",
          "value": 0
          "text": "10%",
          "value": 1
          "text": "20%",
          "value": 2
          "text": "30%",
          "value": 3
          "text": "40%",
          "value": 4
          "text": "50%",
          "value": 5
          "text": "60%",
          "value": 6
          "text": "70%",
          "value": 7
          "text": "80%",
          "value": 8
          "text": "90%",
          "value": 9
          "text": "100%",
          "value": 10
      "value": 1,
      "lastUpdate": 1625963090362,
      "newValue": 1
      "id": "32-112-0-23",
      "nodeId": 32,
      "endpoint": 0,
      "property": 23,
      "propertyName": "Fan LED Strip Brightness When Off",
      "type": "number",
      "readable": true,
      "writeable": true,
      "description": "This is the intensity of the Fan LED strip when the switch is off. This is useful for users to see the light switch location when the lights are off. Range: 0-10 Default: 1",
      "label": "Fan LED Strip Brightness When Off",
      "default": 1,
      "stateless": false,
      "min": 0,
      "max": 10,
      "list": true,
      "states": [
          "text": "Off",
          "value": 0
          "text": "10%",
          "value": 1
          "text": "20%",
          "value": 2
          "text": "30%",
          "value": 3
          "text": "40%",
          "value": 4
          "text": "50%",
          "value": 5
          "text": "60%",
          "value": 6
          "text": "70%",
          "value": 7
          "text": "80%",
          "value": 8
          "text": "90%",
          "value": 9
          "text": "100%",
          "value": 10
      "value": 1,
      "lastUpdate": 1625963090363,
      "newValue": 1
      "id": "32-112-0-26",
      "nodeId": 32,
      "endpoint": 0,
      "property": 26,
      "propertyName": "Light LED Strip Timeout",
      "type": "number",
      "readable": true,
      "writeable": true,
      "description": "When light LED strip intensity is set to 0, this setting allows the LED strip to turn on temporarily while being adjusted",
      "label": "Light LED Strip Timeout",
      "default": 3,
      "stateless": false,
      "min": 0,
      "max": 10,
      "unit": "seconds",
      "list": true,
      "states": [
          "text": "Disable",
          "value": 0
      "value": 3,
      "lastUpdate": 1625963090367,
      "newValue": 3
      "id": "32-112-0-27",
      "nodeId": 32,
      "endpoint": 0,
      "property": 27,
      "propertyName": "Fan LED Strip Timeout",
      "type": "number",
      "readable": true,
      "writeable": true,
      "description": "When the fan LED strip intensity is set to 0, this setting allows the LED strip to turn on temporarily while being adjusted.",
      "label": "Fan LED Strip Timeout",
      "default": 3,
      "stateless": false,
      "min": 0,
      "max": 10,
      "unit": "seconds",
      "list": true,
      "states": [
          "text": "Disable",
          "value": 0
      "value": 3,
      "lastUpdate": 1625963090370,
      "newValue": 3
      "id": "32-112-0-28",
      "nodeId": 32,
      "endpoint": 0,
      "property": 28,
      "propertyName": "Active Power Reports",
      "type": "number",
      "readable": true,
      "writeable": true,
      "description": "The power level change that will result in a new power report being sent.",
      "label": "Active Power Reports",
      "default": 10,
      "stateless": false,
      "min": 0,
      "max": 100,
      "unit": "%",
      "list": true,
      "states": [
          "text": "Disable",
          "value": 0
      "value": 10,
      "lastUpdate": 1625963090372,
      "newValue": 10
      "id": "32-112-0-29",
      "nodeId": 32,
      "endpoint": 0,
      "property": 29,
      "propertyName": "Periodic Power & Energy Reports",
      "type": "number",
      "readable": true,
      "writeable": true,
      "description": "Time period between consecutive power & energy reports being sent.",
      "label": "Periodic Power & Energy Reports",
      "default": 3600,
      "stateless": false,
      "min": 0,
      "max": 32767,
      "list": false,
      "value": 3600,
      "lastUpdate": 1625963090376,
      "newValue": 3600
      "id": "32-112-0-30",
      "nodeId": 32,
      "endpoint": 0,
      "property": 30,
      "propertyName": "Energy Reports",
      "type": "number",
      "readable": true,
      "writeable": true,
      "description": "The energy level change that will result in a new energy report being sent.",
      "label": "Energy Reports",
      "default": 10,
      "stateless": false,
      "min": 0,
      "max": 100,
      "list": false,
      "value": 10,
      "newValue": 10
      "id": "32-112-0-31",
      "nodeId": 32,
      "endpoint": 0,
      "property": 31,
      "propertyName": "Local Protection",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Local Protection",
      "default": 0,
      "stateless": false,
      "min": 0,
      "max": 3,
      "list": true,
      "states": [
          "text": "None",
          "value": 0
          "text": "light",
          "value": 1
          "text": "fan",
          "value": 2
          "text": "Both",
          "value": 3
      "value": 0,
      "lastUpdate": 1625963090379,
      "newValue": 0
      "id": "32-112-0-24-2130706432",
      "nodeId": 32,
      "endpoint": 0,
      "property": 24,
      "propertyName": "Light LED Effect Type",
      "propertyKey": 2130706432,
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Light LED Effect Type",
      "default": 0,
      "stateless": false,
      "min": 0,
      "max": 5,
      "list": true,
      "states": [
          "text": "Off",
          "value": 0
          "text": "Solid",
          "value": 1
          "text": "Slow Blink",
          "value": 2
          "text": "Fast Blink",
          "value": 3
          "text": "Chase",
          "value": 4
          "text": "Pulse",
          "value": 5
      "value": 0,
      "lastUpdate": 1625963090381,
      "newValue": 0
      "id": "32-112-0-24-16711680",
      "nodeId": 32,
      "endpoint": 0,
      "property": 24,
      "propertyName": "Light LED Effect Duration",
      "propertyKey": 16711680,
      "type": "number",
      "readable": true,
      "writeable": true,
      "description": "1 to 60 = seconds, 61 to 120 = minutes (minus 60), 121 - 254 = hours (minus 120), 255 = indefinitely",
      "label": "Light LED Effect Duration",
      "default": 255,
      "stateless": false,
      "min": 1,
      "max": 255,
      "list": false,
      "value": 0,
      "lastUpdate": 1625963090383,
      "newValue": 0
      "id": "32-112-0-24-65280",
      "nodeId": 32,
      "endpoint": 0,
      "property": 24,
      "propertyName": "Light LED Effect Brightness",
      "propertyKey": 65280,
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Light LED Effect Brightness",
      "default": 3,
      "stateless": false,
      "min": 0,
      "max": 10,
      "list": true,
      "states": [
          "text": "Off",
          "value": 0
          "text": "10%",
          "value": 1
          "text": "20%",
          "value": 2
          "text": "30%",
          "value": 3
          "text": "40%",
          "value": 4
          "text": "50%",
          "value": 5
          "text": "60%",
          "value": 6
          "text": "70%",
          "value": 7
          "text": "80%",
          "value": 8
          "text": "90%",
          "value": 9
          "text": "100%",
          "value": 10
      "value": 0,
      "lastUpdate": 1625963090384,
      "newValue": 0
      "id": "32-112-0-24-255",
      "nodeId": 32,
      "endpoint": 0,
      "property": 24,
      "propertyName": "Light LED Effect Color",
      "propertyKey": 255,
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Light LED Effect Color",
      "default": 0,
      "stateless": false,
      "min": 0,
      "max": 255,
      "list": true,
      "states": [
          "text": "Red",
          "value": 0
          "text": "Orange",
          "value": 21
          "text": "Yellow",
          "value": 42
          "text": "Green",
          "value": 85
          "text": "Cyan",
          "value": 127
          "text": "Blue",
          "value": 170
          "text": "Violet",
          "value": 212
          "text": "Pink",
          "value": 234
      "value": 0,
      "lastUpdate": 1625963090387,
      "newValue": 0
      "id": "32-112-0-25-2130706432",
      "nodeId": 32,
      "endpoint": 0,
      "property": 25,
      "propertyName": "Fan LED Effect Type",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Fan LED Effect Type",
      "default": 0,
      "stateless": false,
      "min": 0,
      "max": 5,
      "list": true,
      "states": [
          "text": "Off",
          "value": 0
          "text": "Solid",
          "value": 1
          "value": 2
          "value": 3
          "text": "Chase",
          "value": 4
          "text": "Pulse",
          "value": 5
      "value": 0,
      "lastUpdate": 1625963090391,
      "newValue": 0
      "id": "32-112-0-25-16711680",
      "nodeId": 32,
      "endpoint": 0,
      "property": 25,
      "propertyName": "Fan LED Effect Duration",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Fan LED Effect Duration",
      "default": 255,
      "stateless": false,
      "min": 1,
      "max": 255,
      "list": false,
      "value": 0,
      "lastUpdate": 1625963090393,
      "newValue": 0
      "id": "32-112-0-25-65280",
      "nodeId": 32,
      "endpoint": 0,
      "property": 25,
      "propertyName": "Fan LED Effect Brightness",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Fan LED Effect Brightness",
      "default": 3,
      "stateless": false,
      "min": 0,
      "max": 10,
      "list": true,
      "states": [
          "text": "Off",
          "value": 0
          "text": "10%",
          "value": 1
          "text": "20%",
          "value": 2
          "text": "30%",
          "value": 3
          "text": "40%",
          "value": 4
          "text": "50%",
          "value": 5
          "text": "60%",
          "value": 6
          "text": "70%",
          "value": 7
          "text": "80%",
          "value": 8
          "text": "90%",
          "value": 9
          "text": "100%",
          "value": 10
      "value": 0,
      "lastUpdate": 1625963090397,
      "newValue": 0
      "id": "32-112-0-25-255",
      "nodeId": 32,
      "endpoint": 0,
      "property": 25,
      "propertyName": "Fan LED Effect Color",
      "propertyKey": 255,
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Fan LED Effect Color",
      "default": 0,
      "stateless": false,
      "min": 0,
      "max": 255,
      "list": true,
      "states": [
          "text": "Red",
          "value": 0
          "text": "Orange",
          "value": 21
          "text": "Yellow",
          "value": 42
          "text": "Green",
          "value": 85
          "text": "Cyan",
          "value": 127
          "text": "Blue",
          "value": 170
          "text": "Violet",
          "value": 212
          "text": "Pink",
          "value": 234
      "value": 0,
      "newValue": 0
      "id": "32-112-0-51",
      "nodeId": 32,
      "endpoint": 0,
      "property": 51,
      "propertyName": "param051",
      "type": "any",
      "readable": true,
      "writeable": true,
      "label": "param051 (property)",
      "stateless": false,
      "list": false,
      "value": 0,
      "lastUpdate": 1625963090400,
      "newValue": 0
      "id": "32-114-0-manufacturerId",
      "nodeId": 32,
      "commandClass": 114,
      "commandClassName": "Manufacturer Specific",
      "endpoint": 0,
      "property": "manufacturerId",
      "propertyName": "manufacturerId",
      "type": "number",
      "readable": true,
      "writeable": false,
      "label": "Manufacturer ID",
      "stateless": false,
      "min": 0,
      "max": 65535,
      "list": false,
      "value": 798,
      "lastUpdate": 1625963090403,
      "newValue": 798
      "id": "32-114-0-productType",
      "nodeId": 32,
      "endpoint": 0,
      "property": "productType",
      "propertyName": "productType",
      "type": "number",
      "readable": true,
      "writeable": false,
      "label": "Product type",
      "stateless": false,
      "min": 0,
      "max": 65535,
      "list": false,
      "value": 14,
      "lastUpdate": 1625963090405,
      "newValue": 14
      "id": "32-114-0-productId",
      "nodeId": 32,
      "endpoint": 0,
      "property": "productId",
      "propertyName": "productId",
      "type": "number",
      "readable": true,
      "writeable": false,
      "label": "Product ID",
      "stateless": false,
      "min": 0,
      "max": 65535,
      "list": false,
      "value": 1,
      "lastUpdate": 1625963090408,
      "newValue": 1
      "id": "32-117-0-local",
      "nodeId": 32,
      "commandClass": 117,
      "commandClassName": "Protection",
      "endpoint": 0,
      "property": "local",
      "propertyName": "local",
      "type": "number",
      "readable": true,
      "writeable": true,
      "label": "Local protection state",
      "stateless": false,
      "list": true,
      "states": [
          "text": "Unprotected",
          "value": 0
          "text": "ProtectedBySequence",
          "value": 1
          "text": "NoOperationPossible",
          "value": 2
      "value": 0,
      "lastUpdate": 1625963090410,
      "newValue": 0
      "id": "32-134-0-libraryType",
      "nodeId": 32,
      "commandClass": 134,
      "commandClassName": "Version",
      "endpoint": 0,
      "property": "libraryType",
      "propertyName": "libraryType",
      "type": "any",
      "readable": true,
      "writeable": false,
      "label": "Library type",
      "stateless": false,
      "list": false,
      "value": 3,
      "lastUpdate": 1625963090413,
      "newValue": 3
      "id": "32-134-0-protocolVersion",
      "nodeId": 32,
      "endpoint": 0,
      "property": "protocolVersion",
      "propertyName": "protocolVersion",
      "type": "any",
      "readable": true,
      "writeable": false,
      "label": "Z-Wave protocol version",
      "stateless": false,
      "list": false,
      "value": "7.13",
      "lastUpdate": 1625963090415,
      "newValue": "7.13"
      "id": "32-134-0-firmwareVersions",
      "nodeId": 32,
      "endpoint": 0,
      "property": "firmwareVersions",
      "propertyName": "firmwareVersions",
      "type": "any",
      "readable": true,
      "writeable": false,
      "label": "Z-Wave chip firmware versions",
      "stateless": false,
      "list": false,
      "value": [
        "1.31"
      "lastUpdate": 1625963090417,
      "newValue": [
        "1.31"
      "id": "32-135-0-80-3",
      "nodeId": 32,
      "commandClass": 135,
      "commandClassName": "Indicator",
      "endpoint": 0,
      "property": 80,
      "propertyName": "Node Identify",
      "propertyKey": 3,
      "propertyKeyName": "On/Off Period: Duration",
      "type": "number",
      "readable": true,
      "writeable": true,
      "description": "Sets the duration of an on/off period in 1/10th seconds. Must be set together with \"On/Off Cycle Count\"",
      "label": "Node Identify - On/Off Period: Duration",
      "ccSpecific": {
        "indicatorId": 80,
        "propertyId": 3
      "stateless": false,
      "list": false,
      "value": 0,
      "lastUpdate": 1625963090419,
      "newValue": 0
      "id": "32-135-0-80-4",
      "nodeId": 32,
      "endpoint": 0,
      "property": 80,
      "propertyKey": 4,
      "propertyKeyName": "On/Off Cycle Count",
      "type": "number",
      "readable": true,
      "writeable": true,
      "description": "Sets the number of on/off periods. 0xff means infinite. Must be set together with \"On/Off Period duration\"",
      "label": "Node Identify - On/Off Cycle Count",
      "ccSpecific": {
        "indicatorId": 80,
        "propertyId": 4
      "stateless": false,
      "list": false,
      "value": 0,
      "lastUpdate": 1625963090421,
      "newValue": 0
      "id": "32-135-0-80-5",
      "nodeId": 32,
      "endpoint": 0,
      "property": 80,
      "propertyKey": 5,
      "propertyKeyName": "On/Off Period: On time",
      "type": "number",
      "readable": true,
      "writeable": true,
      "description": "This property is used to set the length of the On time during an On/Off period. It allows asymetic On/Off periods. The value 0x00 MUST represent symmetric On/Off period (On time equal to Off time)",
      "label": "Node Identify - On/Off Period: On time",
      "ccSpecific": {
        "indicatorId": 80,
        "propertyId": 5
      "stateless": false,
      "list": false,
      "value": 0,
      "lastUpdate": 1625963090424,
      "newValue": 0
      "id": "32-38-1-targetValue",
      "nodeId": 32,
      "commandClass": 38,
      "endpoint": 1,
      "type": "number",
      "readable": true,
      "writeable": true,
      "stateless": false,
      "min": 0,
      "max": 99,
      "list": false,
      "value": 0,
      "lastUpdate": 1625963090425,
      "newValue": 0
      "id": "32-38-1-duration",
      "nodeId": 32,
      "commandClass": 38,
      "endpoint": 1,
      "type": "duration",
      "readable": true,
      "writeable": true,
      "stateless": false,
      "list": false,
      "value": {
        "value": 0,
        "unit": "seconds"
      "lastUpdate": 1625963090427,
      "newValue": {
        "value": 0,
        "unit": "seconds"
      "id": "32-38-1-currentValue",
      "nodeId": 32,
      "commandClass": 38,
      "endpoint": 1,
      "type": "number",
      "readable": true,
      "writeable": false,
      "stateless": false,
      "min": 0,
      "max": 99,
      "list": false,
      "value": 99,
      "targetValue": "38-1-targetValue",
      "lastUpdate": 1626238265505,
      "newValue": 99
      "id": "32-38-1-Up",
      "nodeId": 32,
      "commandClass": 38,
      "endpoint": 1,
      "property": "Up",
      "type": "boolean",
      "readable": true,
      "writeable": true,
      "ccSpecific": {
        "switchType": 2
      "stateless": false,
      "list": false,
      "lastUpdate": 1625963090492
      "id": "32-38-1-Down",
      "nodeId": 32,
      "commandClass": 38,
      "endpoint": 1,
      "property": "Down",
      "type": "boolean",
      "readable": true,
      "writeable": true,
      "ccSpecific": {
        "switchType": 2
      "stateless": false,
      "list": false,
      "lastUpdate": 1625963090494
      "id": "32-38-2-targetValue",
      "nodeId": 32,
      "commandClass": 38,
      "endpoint": 2,
      "type": "number",
      "readable": true,
      "writeable": true,
      "stateless": false,
      "min": 0,
      "max": 99,
      "list": false,
      "value": 1,
      "lastUpdate": 1625963090497,
      "newValue": 1
      "id": "32-38-2-duration",
      "nodeId": 32,
      "commandClass": 38,
      "endpoint": 2,
      "type": "duration",
      "readable": true,
      "writeable": true,
      "stateless": false,
      "list": false,
      "value": {
        "value": 0,
        "unit": "seconds"
      "lastUpdate": 1625963090499,
      "newValue": {
        "value": 0,
        "unit": "seconds"
      "id": "32-38-2-currentValue",
      "nodeId": 32,
      "commandClass": 38,
      "endpoint": 2,
      "type": "number",
      "readable": true,
      "writeable": false,
      "stateless": false,
      "min": 0,
      "max": 99,
      "list": false,
      "value": 99,
      "targetValue": "38-2-targetValue",
      "lastUpdate": 1626238271335,
      "newValue": 99
      "id": "32-38-2-Up",
      "nodeId": 32,
      "commandClass": 38,
      "endpoint": 2,
      "property": "Up",
      "type": "boolean",
      "readable": true,
      "writeable": true,
      "ccSpecific": {
        "switchType": 2
      "stateless": false,
      "list": false,
      "lastUpdate": 1625963090589
      "id": "32-38-2-Down",
      "nodeId": 32,
      "commandClass": 38,
      "endpoint": 2,
      "property": "Down",
      "type": "boolean",
      "readable": true,
      "writeable": true,
      "ccSpecific": {
        "switchType": 2
      "stateless": false,
      "list": false,
      "lastUpdate": 1625963090593
  "groups": [
      "text": "Lifeline",
      "endpoint": 0,
      "value": 1,
      "maxNodes": 5,
      "isLifeline": true,
      "multiChannel": true
      "text": "Basic Set Light",
      "endpoint": 0,
      "value": 2,
      "maxNodes": 5,
      "isLifeline": false,
      "text": "Switch MultiLevel Set Light",
      "endpoint": 0,
      "value": 3,
      "maxNodes": 5,
      "text": "Switch MultiLevel Start/Stop Light",
      "endpoint": 0,
      "value": 4,
      "maxNodes": 5,
      "text": "Basic Set Fan",
      "endpoint": 0,
      "value": 5,
      "maxNodes": 5,
      "text": "Switch MultiLevel Set Fan",
      "endpoint": 0,
      "value": 6,
      "maxNodes": 5,
      "text": "Switch MultiLevel Start/Stop Fan",
      "endpoint": 0,
      "value": 7,
      "maxNodes": 5,
      "text": "Lifeline",
      "endpoint": 1,
      "value": 1,
      "maxNodes": 1,
      "isLifeline": true,
      "text": "On/Off Control",
      "endpoint": 1,
      "value": 2,
      "maxNodes": 5,
      "text": "Switch Multilevel Set",
      "endpoint": 1,
      "value": 3,
      "maxNodes": 5,
      "text": "Sw Multi Start/Stop",
      "endpoint": 1,
      "value": 4,
      "maxNodes": 5,
      "text": "Lifeline",
      "endpoint": 2,
      "value": 1,
      "maxNodes": 1,
      "isLifeline": true,
      "endpoint": 2,
      "value": 2,
      "maxNodes": 5,
      "endpoint": 2,
      "value": 3,
      "maxNodes": 5,
      "endpoint": 2,
      "value": 4,
      "maxNodes": 5,
  "neighbors": [
    1,
    6,
    19,
    22,
    23,
    24,
    27,
    28,
    29,
    31,
    33
  "ready": true,
  "available": true,
  "hassDevices": {
    "light_dimmer": {
      "type": "light",
      "object_id": "dimmer",
      "discovery_payload": {
        "command_topic": "homeassistant/Main_floor/Fan_Stairs/38/0/targetValue/set",
        "state_topic": "homeassistant/Main_floor/Fan_Stairs/38/0/currentValue",
        "state_value_template": "{{ 0 if value_json.value == 0 else 255 }}",
        "brightness_command_topic": "homeassistant/Main_floor/Fan_Stairs/38/0/targetValue/set",
        "brightness_scale": 99,
        "brightness_state_topic": "homeassistant/Main_floor/Fan_Stairs/38/0/currentValue",
        "brightness_value_template": "{{ value_json.value }}",
        "on_command_type": "last",
        "payload_on": 255,
        "payload_off": 0,
        "device": {
          "identifiers": [
            "zwavejs2mqtt_0xdb258b77_node32"
          "manufacturer": "Inovelli",
          "model": "Red Series Fan + Light Switch (LZW36)",
          "name": "Main_floor-Fan_Stairs",
          "sw_version": "1.31"
        "name": "Main_floor-Fan_Stairs_dimmer",
        "unique_id": "zwavejs2mqtt_0xdb258b77_32-38-0-currentValue"
      "discoveryTopic": "light/Main_floor-Fan_Stairs/dimmer/config",
      "values": [
        "38-0-currentValue",
        "38-0-targetValue"
      "persistent": false,
      "ignoreDiscovery": false
    "sensor_electric_kwh_value": {
      "type": "sensor",
      "object_id": "electric_kwh_value",
        "value_template": "{{ value_json.value }}",
        "device_class": "power",
        "unit_of_measurement": "kWh",
        "state_topic": "homeassistant/Main_floor/Fan_Stairs/50/0/value/65537",
        "json_attributes_topic": "homeassistant/Main_floor/Fan_Stairs/50/0/value/65537",
        "device": {
          "identifiers": [
        "name": "Main_floor-Fan_Stairs_electric_kwh_value",
        "unique_id": "zwavejs2mqtt_0xdb258b77_32-50-0-value-65537"
      "discoveryTopic": "sensor/Main_floor-Fan_Stairs/electric_kwh_value/config",
      "values": [
        "50-0-value-65537"
    "sensor_electric_kwh_deltatime": {
      "type": "sensor",
      "object_id": "electric_kwh_deltatime",
        "unit_of_measurement": "s",
        "state_topic": "homeassistant/Main_floor/Fan_Stairs/50/0/deltaTime/65537",
        "json_attributes_topic": "homeassistant/Main_floor/Fan_Stairs/50/0/deltaTime/65537",
        "device": {
          "identifiers": [
        "name": "Main_floor-Fan_Stairs_electric_kwh_deltatime",
        "unique_id": "zwavejs2mqtt_0xdb258b77_32-50-0-deltaTime-65537"
      "discoveryTopic": "sensor/Main_floor-Fan_Stairs/electric_kwh_deltatime/config",
      "values": [
        "50-0-deltaTime-65537"
    "sensor_electric_w_value": {
      "type": "sensor",
      "object_id": "electric_w_value",
        "unit_of_measurement": "W",
        "state_topic": "homeassistant/Main_floor/Fan_Stairs/50/0/value/66049",
        "json_attributes_topic": "homeassistant/Main_floor/Fan_Stairs/50/0/value/66049",
        "device": {
          "identifiers": [
        "name": "Main_floor-Fan_Stairs_electric_w_value",
        "unique_id": "zwavejs2mqtt_0xdb258b77_32-50-0-value-66049"
      "discoveryTopic": "sensor/Main_floor-Fan_Stairs/electric_w_value/config",
      "values": [
        "50-0-value-66049"
    "sensor_electric_w_deltatime": {
      "type": "sensor",
      "object_id": "electric_w_deltatime",
        "state_topic": "homeassistant/Main_floor/Fan_Stairs/50/0/deltaTime/66049",
        "json_attributes_topic": "homeassistant/Main_floor/Fan_Stairs/50/0/deltaTime/66049",
        "device": {
          "identifiers": [
        "name": "Main_floor-Fan_Stairs_electric_w_deltatime",
        "unique_id": "zwavejs2mqtt_0xdb258b77_32-50-0-deltaTime-66049"
      "discoveryTopic": "sensor/Main_floor-Fan_Stairs/electric_w_deltatime/config",
      "values": [
        "50-0-deltaTime-66049"
    "sensor_electric_kwh_previousvalue": {
      "type": "sensor",
      "object_id": "electric_kwh_previousvalue",
        "state_topic": "homeassistant/Main_floor/Fan_Stairs/50/0/previousValue/65537",
        "json_attributes_topic": "homeassistant/Main_floor/Fan_Stairs/50/0/previousValue/65537",
        "device": {
          "identifiers": [
        "name": "Main_floor-Fan_Stairs_electric_kwh_previousvalue",
        "unique_id": "zwavejs2mqtt_0xdb258b77_32-50-0-previousValue-65537"
      "discoveryTopic": "sensor/Main_floor-Fan_Stairs/electric_kwh_previousvalue/config",
      "values": [
        "50-0-previousValue-65537"
    "sensor_electric_w_previousvalue": {
      "type": "sensor",
      "object_id": "electric_w_previousvalue",
        "state_topic": "homeassistant/Main_floor/Fan_Stairs/50/0/previousValue/66049",
        "json_attributes_topic": "homeassistant/Main_floor/Fan_Stairs/50/0/previousValue/66049",
        "device": {
          "identifiers": [
        "name": "Main_floor-Fan_Stairs_electric_w_previousvalue",
        "unique_id": "zwavejs2mqtt_0xdb258b77_32-50-0-previousValue-66049"
      "discoveryTopic": "sensor/Main_floor-Fan_Stairs/electric_w_previousvalue/config",
      "values": [
        "50-0-previousValue-66049"
    "sensor_scene_state_slowrefresh": {
      "type": "sensor",
      "object_id": "scene_state_slowrefresh",
        "state_topic": "homeassistant/Main_floor/Fan_Stairs/91/0/slowRefresh",
        "value_template": "{{ value_json.value | default('') }}",
        "json_attributes_topic": "homeassistant/Main_floor/Fan_Stairs/91/0/slowRefresh",
        "device": {
          "identifiers": [
        "name": "Main_floor-Fan_Stairs_scene_state_slowrefresh",
        "unique_id": "zwavejs2mqtt_0xdb258b77_32-91-0-slowRefresh"
      "discoveryTopic": "sensor/Main_floor-Fan_Stairs/scene_state_slowrefresh/config",
      "values": [
        "91-0-slowRefresh"
    "sensor_scene_state_scene_001": {
      "type": "sensor",
      "object_id": "scene_state_scene_001",
        "state_topic": "homeassistant/Main_floor/Fan_Stairs/91/0/scene/001",
        "json_attributes_topic": "homeassistant/Main_floor/Fan_Stairs/91/0/scene/001",
        "device": {
          "identifiers": [
        "name": "Main_floor-Fan_Stairs_scene_state_scene_001",
        "unique_id": "zwavejs2mqtt_0xdb258b77_32-91-0-scene-001"
      "discoveryTopic": "sensor/Main_floor-Fan_Stairs/scene_state_scene_001/config",
      "values": [
        "91-0-scene-001"
    "sensor_scene_state_scene_002": {
      "type": "sensor",
      "object_id": "scene_state_scene_002",
        "state_topic": "homeassistant/Main_floor/Fan_Stairs/91/0/scene/002",
        "json_attributes_topic": "homeassistant/Main_floor/Fan_Stairs/91/0/scene/002",
        "device": {
          "identifiers": [
        "name": "Main_floor-Fan_Stairs_scene_state_scene_002",
        "unique_id": "zwavejs2mqtt_0xdb258b77_32-91-0-scene-002"
      "discoveryTopic": "sensor/Main_floor-Fan_Stairs/scene_state_scene_002/config",
      "values": [
        "91-0-scene-002"
    "sensor_scene_state_scene_003": {
      "type": "sensor",
      "object_id": "scene_state_scene_003",
        "state_topic": "homeassistant/Main_floor/Fan_Stairs/91/0/scene/003",
        "json_attributes_topic": "homeassistant/Main_floor/Fan_Stairs/91/0/scene/003",
        "device": {
          "identifiers": [
        "name": "Main_floor-Fan_Stairs_scene_state_scene_003",
        "unique_id": "zwavejs2mqtt_0xdb258b77_32-91-0-scene-003"
      "discoveryTopic": "sensor/Main_floor-Fan_Stairs/scene_state_scene_003/config",
      "values": [
        "91-0-scene-003"
    "sensor_scene_state_scene_004": {
      "type": "sensor",
      "object_id": "scene_state_scene_004",
        "state_topic": "homeassistant/Main_floor/Fan_Stairs/91/0/scene/004",
        "json_attributes_topic": "homeassistant/Main_floor/Fan_Stairs/91/0/scene/004",
        "device": {
          "identifiers": [
        "name": "Main_floor-Fan_Stairs_scene_state_scene_004",
        "unique_id": "zwavejs2mqtt_0xdb258b77_32-91-0-scene-004"
      "discoveryTopic": "sensor/Main_floor-Fan_Stairs/scene_state_scene_004/config",
      "values": [
        "91-0-scene-004"
    "sensor_scene_state_scene_005": {
      "type": "sensor",
      "object_id": "scene_state_scene_005",
        "state_topic": "homeassistant/Main_floor/Fan_Stairs/91/0/scene/005",
        "json_attributes_topic": "homeassistant/Main_floor/Fan_Stairs/91/0/scene/005",
        "device": {
          "identifiers": [
        "name": "Main_floor-Fan_Stairs_scene_state_scene_005",
        "unique_id": "zwavejs2mqtt_0xdb258b77_32-91-0-scene-005"
      "discoveryTopic": "sensor/Main_floor-Fan_Stairs/scene_state_scene_005/config",
      "values": [
        "91-0-scene-005"
    "sensor_scene_state_scene_006": {
      "type": "sensor",
      "object_id": "scene_state_scene_006",
        "state_topic": "homeassistant/Main_floor/Fan_Stairs/91/0/scene/006",
        "json_attributes_topic": "homeassistant/Main_floor/Fan_Stairs/91/0/scene/006",
        "device": {
          "identifiers": [
        "name": "Main_floor-Fan_Stairs_scene_state_scene_006",
        "unique_id": "zwavejs2mqtt_0xdb258b77_32-91-0-scene-006"
      "discoveryTopic": "sensor/Main_floor-Fan_Stairs/scene_state_scene_006/config",
      "values": [
        "91-0-scene-006"
    "light_dimmer_1": {
      "type": "light",
      "object_id": "dimmer_1",
        "command_topic": "homeassistant/Main_floor/Fan_Stairs/38/1/targetValue/set",
        "state_topic": "homeassistant/Main_floor/Fan_Stairs/38/1/currentValue",
        "brightness_command_topic": "homeassistant/Main_floor/Fan_Stairs/38/1/targetValue/set",
        "brightness_state_topic": "homeassistant/Main_floor/Fan_Stairs/38/1/currentValue",
        "payload_on": 255,
        "payload_off": 0,
        "device": {
          "identifiers": [
        "name": "Main_floor-Fan_Stairs_dimmer_1",
        "unique_id": "zwavejs2mqtt_0xdb258b77_32-38-1-currentValue"
      "discoveryTopic": "light/Main_floor-Fan_Stairs/dimmer_1/config",
      "values": [
        "38-1-currentValue",
        "38-1-targetValue"
    "light_dimmer_2": {
      "type": "light",
      "object_id": "dimmer_2",
        "command_topic": "homeassistant/Main_floor/Fan_Stairs/38/2/targetValue/set",
        "state_topic": "homeassistant/Main_floor/Fan_Stairs/38/2/currentValue",
        "brightness_command_topic": "homeassistant/Main_floor/Fan_Stairs/38/2/targetValue/set",
        "brightness_state_topic": "homeassistant/Main_floor/Fan_Stairs/38/2/currentValue",
        "payload_on": 255,
        "payload_off": 0,
        "device": {
          "identifiers": [
        "name": "Main_floor-Fan_Stairs_dimmer_2",
        "unique_id": "zwavejs2mqtt_0xdb258b77_32-38-2-currentValue"
      "discoveryTopic": "light/Main_floor-Fan_Stairs/dimmer_2/config",
      "values": [
        "38-2-currentValue",
        "38-2-targetValue"
  "failed": false,
  "inited": true,
  "hexId": "0x031e-0x000e-0x0001",
  "dbLink": "https://devices.zwave-js.io/?jumpTo=0x031e:0x000e:0x0001:1.31",
  "manufacturerId": 798,
  "productId": 1,
  "productType": 14,
  "productLabel": "LZW36",
  "productDescription": "Red Series Fan + Light Switch",
  "firmwareVersion": "1.31",
  "protocolVersion": 3,
  "zwavePlusVersion": 2,
  "zwavePlusNodeType": 0,
  "zwavePlusRoleType": 5,
  "nodeType": 1,
  "endpointsCount": 2,
  "endpointIndizes": [
    1,
    2
  "isSecure": false,
  "supportsSecurity": false,
  "supportsBeaming": true,
  "isControllerNode": false,
  "isListening": true,
  "isFrequentListening": false,
  "isRouting": true,
  "keepAwake": false,
  "maxDataRate": 100000,
  "deviceClass": {
    "basic": 4,
    "generic": 17,
    "specific": 0
  "deviceId": "798-1-14",
  "status": "Alive",
  "interviewStage": "Complete",
  "statistics": {
    "commandsTX": 24,
    "commandsRX": 104,
    "commandsDroppedRX": 0,
    "commandsDroppedTX": 0,
    "timeoutResponse": 1
  "lastActive": 1626238271337,
  "_name": "Fan_Stairs (Main_floor)"
