I’m trying to run a HA automation each time the up button is pressed on a Blue Series switch. Parameter 50 switch delay is set to 0ms but there is a delay after releasing that a new press event will be sent. I can press the up button 20 times and only the first press is sent to HA even though P50 is set to 0ms. I’ve explained as much as I could in this post here:
https://community.inovelli.com/t/delay-between-button-presses/18764
Edit: I think parameter 258 switch mode may be contributing to the issue as well. I have it set to on/off so the switch shouldn’t be looking for hold events. I still think a press event should be sent regardless of what settings are enabled/disabled. It’s been asked for before.
https://community.inovelli.com/t/lzw30-sn-activate-the-light-on-button-press-not-button-release/6554
It would be amazing if Inovelli switches functioned like the Hue remote I mentioned in that post.
