Setup Instructions | Red Series Dimmer Switch - SmartThings
IMPORTANT: If you are here because you want to associate your switch directly to your bulb via Z-Wave, please follow the instructions to pair this switch non-securely (also make sure your bulb is paired non-securely).
While we try to keep this article up to date, it’s often hard due to the many updates of both our firmware and SmartThings firmware. If any updates/edits need to be made to this article, please comment on this thread: https://community.inovelli.com/t/wiki-general-feedback-suggestions-thread/7399
Overview
This page will discuss how to setup your Red Series Dimmer Switch on the SmartThings platform (hardware made by Samsung or Aeotec).
Make: Inovelli
Model #: LZW31-SN
Amazon ASIN: B07S1BMMGH
UPC: 850007431006
Prerequisites
For the best experience, we recommend downloading and installing the Inovelli device handler for your switch.
To access the device handler page as well as instructions, please see the below links:
Inclusion / Pairing Instructions
On SmartThings, there are a couple of ways you can pair your smart switch. In this example, the two ways are called, “Non-Secure” (ie: no security) or S2. The default method is S2.
NOTE: If you would like to take advantage of, “Smart Bulb Mode” via Z-Wave Associations, you will need to pair without security (ie: non-secure) as our bulbs do not support S2 and Associations need to be on the same security level.
Non-Secure Inclusion Method
Use this method if you want your smart switch to be directly associated (via Z-Wave) with your Inovelli smart bulb or if you prefer to include without security (sometimes your network can be faster without security).
To associate your switch with an Inovelli bulb, please click here: Inovelli Dimmer to Inovelli Bulb Association Instructions
Video Instructions
Written Instructions
NOTE: The below directions assume you have installed the device handler prior to pairing.
Step By Step Instructions
  1. Turn power back onto your switch (the LED bar should be a solid blue)
  2. Open your SmartThings App
  3. Press the (+) button at the top right of the screen
  4. Click on, “Device” (or, “Add Device” depending on the screen you’re on)
  5. Click, “Scan nearby” at the top right of the screen
  6. Press the configuration button 3x (within about 1-1.5 seconds)
  7. The LED bar should start to pulse blue indicating it’s in inclusion/pairing mode
  8. If successful, the LED bar will turn green (if unsuccessful, the LED bar will turn red)
  9. In addition, your app will show your switch (it will say, “Z-Wave device” with a bubble that says, “Secure setup” – DO NOT PRESS, “Secure setup”)
  10. Press the back arrow at the top of the screen to go back to the main menu – you will see a pop-up that says, “Skip secure setup?” – click, “OK”
  11. Next, click on the, “Devices” tab and look for your switch – it should show up under, “No room assigned”
  12. Feel free to rename it and assign it to the proper room (to do this click on the switch, then click on the three dots and select, “Edit”)
_____________
Secure Inclusion Method (S2)
Use this method if you want your smart switch to be paired with security. NOTE: This is the default way of pairing.
Video Instructions
Coming soon.
Coming soon.
Coming soon.
